ISP programming inc fuses
jasreb
PostPosted: Fri May 30, 2008 4:40 pm    Post subject: ISP programming inc fuses Reply with quote
Hope this is not a stupid Q, I am having to ISP prog batches of ATtiny13s (100 at a time) and it becomes rather tedious having to go to the Lock and Fuse Bit tab, change CLK/8 from ON to OFF, Write FS, then prog the device.
Q: Is there a quick way to include the fusebit E (CLK/Cool in the Bascom file, and it will get written automatically at the same time as the program code gets written? Or perhaps configure the bascom programmer to write fusebit E at the same time as the program file?
thanks in advance for any advice
jasreb
PostPosted: Fri May 30, 2008 5:06 pm    Post subject: Reply with quote
I'm guessing I can use Config Clockdiv=1 (seems to work) although the CLK/8 fuse remains ON..?
Is there any technical difference between setting the Fusebit in the programmer, vs using Config Clockdiv=1 ? The device is being used for servo pulse decoding, so I need to be sure it will work correctly Smile
Frankeman
PostPosted: Fri May 30, 2008 6:57 pm    Post subject: Reply with quote
Take a look at the $PROG directive in the help.
Frank.
