Atmega 8 hangup
sakaz
PostPosted: Sun Apr 27, 2008 6:29 pm    Post subject: Atmega 8 hangup Reply with quote
Hi forum,
I have been working with some projects but i dont know why the AVR hangs after some time. I made the system which works with phone calls and turn on./off switch with the DTMF tones Everything is working fine my codes but after make 5 or 6 calls the system restart or stop to receive anything on the USART. I have tried to change stack settings too but still not working.
$regfile = "m8def.dat"
$crystal = 4000000
$baud = 19200
$hwstack = 150
$swstack = 32
$framesize = 32
Rs232_isr:
Chrx = Udr
Select Case Chrx
Case 0
Case 13
Case 10 : Kk = Str2$
Str2$ = ""
Flag_data_ready = 1
Case Else
If Len(str2$) < Max_buf_len Then 'Filter out LF and CR etc
Str2$ = Str2$ + Chr(chrx)
Else
End Select
I am totally fade up why the system is not working and i need to always working the system. waiting for your quick reply.
Shan
Arera
PostPosted: Wed Apr 30, 2008 10:59 am    Post subject: Reply with quote
itīs never a good idea to do many things in an ISR.
Try to change your prog in an way like this:
Rs232_isr:
Chrx = Udr
Flag_new_data = 1
return
let the rest be done in your main loop, depending on Flag_new_data.
Itīs just an idea, but give it a try!
And post the result, please!
sakaz
PostPosted: Wed Apr 30, 2008 4:16 pm    Post subject: Reply with quote
Hi Arera,
Thank you very much for your reply with your advice to make the ISR shorter. I have been working on my project and reading code for last whole night and finally i got the error and problem why the AVR is going to Reset or Hang up. Ok i try to tell you the reason. As per my main loop below:
If Flag_data_ready = 1 Then
If Len(kk) > 2 Then
Flag_data_ready = 0
If Mid(kk , 1 , 4) = "RING" Then
Incall_flag = 0
Start Timer1
Gosub Glock
Else
Gosub Doorcheck
Set Portd.6
Waitms 500
Reset Portd.6
Waitms 500
When we detect "RING" from Modem then it call the SUB GLOCK so it take 2 bytes from the HWSTACK and the problem was i used the GOTO Statement instead of RETURN because. When we call a sub it take 2 bytes from HWSTACK and when we use RETURN then it give back the 2 bytes and the error was here when i called once the SUB GLOCK then it take 2 bytes then again 2 + + + and the result was ..
The HWSTACK grow down first to the SWSTACK then FREME and then DATA Area and which make the AVR hangup or Reset / Restart.
I hope that would be helpful for others who are facing problem with overflow and avoid that problem.
Regards,
Shan
