Ip to long conversion question
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
pistoleross
PostPosted: Wed Mar 12, 2008 2:03 pm    Post subject: Ip to long conversion question Reply with quote
hallo,
i have a convertion question about a long variable.
when i use this syntax
result = socketconnect( socket, ip, port) i read this in Bascom's Help
The IP number of the server you want to connect to.
This may be a number like 141.100.250.141 or a LONG variable that is assigned with an IP number.
Note that the LSB of the LONG, must contain the MSB of the IP number.
i want to know,how we make the conversion from ip in this form(141.100.250.151) to a long variable, and from a long variable to a ip in this form(141.00.250.151).
thanks
bzijlstra
Bascom Ambassador
PostPosted: Sun Apr 06, 2008 11:05 am    Post subject: Conversion Reply with quote
Check this for conversion IP to LONG and Vise Versa...
&H19 = 25
&H00 = 0
&HA8 = 168
&HC0 = 192
Have fun
Ben Zijlstra
Frankeman
PostPosted: Sun Apr 06, 2008 11:35 am    Post subject: Reply with quote
To make a conversion from 141.100.250.141 to a variable of the type word use the MAKETCP command.
Frank.
Arera
PostPosted: Mon Apr 07, 2008 7:09 am    Post subject: Reply with quote
Frankemann wanted to say
To make a conversion from 141.100.250.141 to a variable of the type LONG use the MAKETCP command..
Just to avoid confusion...
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
