Software UART question
Alexander
PostPosted: Thu Apr 03, 2008 1:51 pm    Post subject: Software UART question Reply with quote
Hello experts,
I want to send serial data via the software UART. The data to be sent consists only of a few command strings, e. g. there is no constant data flow. I've already done this with a serial LC display at 9.6kBaud. Now I need 115,2kBaud.
Is it realistic to get 115,2kBaud with the SW-UART using a Mega32 with 8 or 16MHz?
Thanks for your help.
Alexander
ecoology
PostPosted: Thu Apr 03, 2008 4:11 pm    Post subject: Reply with quote
According to Bascom, when you select 115.2k baud rate, and 16 mHz, you get a 7.84% error rate. I would call that unacceptable and unrealistic.
entry2
PostPosted: Thu Apr 03, 2008 7:36 pm    Post subject: use other crystals as 8 or 16 MHz Reply with quote
Dear Alexander,
if you can/have, use 7,3728 / 9,8304 / 11,0592 / 12,?? / 14,7456 MHz.
Look by farnell or digikey (or segor) and buy.
If you divide the top MHz then you must have a real count without comma (ganze Zahl).
I use at moment a 7,3728 MHz crystal and it works with an ATmega168 (SW UART).
A tip: don't use long stings to send, because many interupt's can destroy the sending data.
MfG Stefan
Alexander
PostPosted: Thu Apr 03, 2008 7:57 pm    Post subject: Reply with quote
Hello Stefan,
thanks for your answer. I'm totally free with the choice of the oscillator frequency, so I can also use a 14,7456 MHz crystal to get the correct baud rate.
My concern was that the Software-UART might not be fast enough for the 115,2kBaud. The strings to be sent are short, e. g. pos=5, nothing more.
Regards,
Alexander
Arera
PostPosted: Fri Apr 04, 2008 9:20 am    Post subject: Reply with quote
Hi Alexander,
befor sending strings, have a look at this topic:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=5267
Skip the first page, the last 3 or 4 replies are the most important.
Be clever:
say NO to Strings! Join the Anti-String Coalition and do the 12 step program.
Visit www.justsayno2strings.com today (donations accepted)
