Display 3000 2.1"
PostPosted: Thu Jan 17, 2008 7:25 pm    Post subject: Display 3000 2.1" Reply with quote
hello,
I discover the Display3000, it nice but I have a problem, the line is difficult to draw, I have a solution but it is a little bit heavy: draw dot by dot.
I explain to draw a line the X1, Y1 coordinate must be in the upper left corner, and the X2, Y2 in the lower right corner.
My problem is to make an analogic clock so I need to have the center of circle X1, Y1 and I dont find the method to draw the line for 7 hours for example
Bascom 9.0, atmega128
Many thanks
JP
AdrianJ
PostPosted: Thu Jan 17, 2008 10:05 pm    Post subject: Reply with quote
In fact all lines are drawn dot-by-dot, you just need a good way of figuring out where the dots go. Lookup "Bresenham algorithm" on the net. This is the standard line drawing technique.
Adrian Jansen
Arera
PostPosted: Fri Feb 29, 2008 12:21 pm    Post subject: Reply with quote
Hi JP,
I using a D072 2.1" display since monday. Itīs great!
Why donīt you use the commands from display3000?
Include a few .bas files from display3000 into your prog, and draw a line:
call ldc_draw (x1,y1, x2,y2, [thickness], [color])
Read the display3000 software-manual!
