ApplicationNote AN135 flowmeter.bas fails to compile[solved]
GKnops
PostPosted: Thu Jun 02, 2005 9:37 pm    Post subject: ApplicationNote AN135 flowmeter.bas fails to compile[solved] Reply with quote
I tried to compile the AN135 file flowmeter.bas with Bascom-AVR 1.11.7.7 and it fails to create a .hex and .bin file.
In the report file there is the warning:
  Warnings:
  HWSTACK                          not used
  SWSTACK                          not used
  FRAME                            not used
  ADCD                             not used
  DATE$                            not used
  TIME$                            not used
  Source string could be too big to fit into target string  in line  79
  Source string could be too big to fit into target string  in line  82
  Source string could be too big to fit into target string  in line  93
Can anybody tell me how to fix this?
I tried to change the stacks but with no result.
DToolan
PostPosted: Thu Jun 02, 2005 10:23 pm    Post subject: Reply with quote
Hmmm... I just downloaded AN135 and compiled it without error making no changes other than chip type. (1.11.7.7)
View user's profile Yahoo Messenger
PostPosted: Fri Jun 03, 2005 4:04 pm    Post subject: Reply with quote
I wrote the AN135, and it is working well Wink , I hope, because my friend is still alive ! Wink
the warning you saw are very common in basic-bascom but it is only warning not a error.
the variable tank is dimensionnsed as :
Dim Tank As String * 8
and use as:
Tank = Format(tank , "00.0") : only with 4 byte.
this apply is working with an ATMEGA8, at 8MHz, a LCD 2 lines is added.
If you have some trouble again, send me a mail please
Bon courage
JP
GKnops
PostPosted: Fri Jun 03, 2005 8:18 pm    Post subject: Reply with quote
Thank you for your reply.
Compiling the .bas file still doesn't create a .bin and .hex file.
Other .bas files were compiled fine in the same directory, so there is nothing wrong with any of the settings.
Maybe it has something to do with the fact that I use the demoversion?
How many kB is the .bin file you get? In the report file it is stated that it would be 2862 byte. This is not bigger than the 4kB which the demo version can produce. So from this point of view it would not be the origin of the problem.
DToolan
PostPosted: Fri Jun 03, 2005 9:44 pm    Post subject: Reply with quote
Yes... this is your problem. The current demo verson (although it says it compiles 4K code) will only compile code size of 2K or less. The program you are attempting to compile results in a 4K bin / 10K hex file.
PostPosted: Sat Jun 04, 2005 8:28 am    Post subject: Reply with quote
epending was demo version you use,
JP
Luciano
PostPosted: Sat Jun 04, 2005 9:49 am    Post subject: Reply with quote
The BASCOM-AVR DEMO 1.11.7.7 generates 2KB and not the 4KB.
See this post how to fix that:
http://www.grote.net/bascom/frm23958.html
You can download the file bascavr.exe ( DEMO 1.11.7.8 ) from:
www.mcselec.com/download/avr/11178/bascavride.zip
Just rename the original bascavr.exe file (1.11.7.7) to
bascavr_7.exe and put the new bascavr.exe (from the zip file)
in the program folder. When you run the program you will get
a warning about incompatible dll, but you can ignore it.
Best regards,
Luciano
GKnops
PostPosted: Sat Jun 04, 2005 4:19 pm    Post subject: Reply with quote
Yes, it works. I downloaded the new 1.11.8 bascavr.exe and now a .bin (nearly 3kB) and .hex (nearly 8kB) is created. Very Happy
Thanks for your help.
Juergen
PostPosted: Sat Jun 04, 2005 5:27 pm    Post subject: Reply with quote
Where did you find a 1.11.8 update? I just checked with auto update and there's nothing newer then the 1.11.7.7 I have installed.
Juergen
-- In a world without fences and walls, who needs Windows and Gates? --
GKnops
PostPosted: Sat Jun 04, 2005 5:46 pm    Post subject: Reply with quote
See the post of Luciano:
I couldn't find anything on the MCS site also
Frankeman
PostPosted: Sat Jun 04, 2005 5:49 pm    Post subject: Reply with quote
There is only a demo 1.11.7.8
The commercial version is 1.11.7.7.
Juergen
PostPosted: Sat Jun 04, 2005 7:17 pm    Post subject: Reply with quote
Does that mean that the commercial version lacks behind the free demo? Not good!
Same applies to some patches which are needed to run 7.7 but have never been added to the updates.
Weird to say the least.
Juergen
Frankeman
PostPosted: Sat Jun 04, 2005 10:48 pm    Post subject: Reply with quote
The 1.11.7.8 demo is the same as the commercial 1.11.7.7
The 1.11.7.7 demo has a little bug with the size of the generated hex file
In the .8 version this is fixed.
