' BASCOM version of Elektor TinyRGB LED flasher
' Using 8MHz int RC osc
' RED = OC0A = PORTB.0 = PIN5
' GRN = OC0B = PORTB.1 = PIN6
' BLU = OC1B = PORTB.4 = PIN3
$regfile = "ATtiny45.DAT"
$hwstack = 16
$swstack = 16
$framesize = 24
'speed is number of ms to wait between pwm updates
const speed = 40
dim i as byte
dim table(100) as byte
red_led alias PORTB.0
green_led alias PORTB.1
blue_led alias PORTB.4
red_pwm alias pwm0a
green_pwm alias pwm0b
blue_pwm alias ocr1b
reset red_led
reset green_led
reset blue_led
Config Pinb.0 = Output
Config Pinb.1 = Output
Config Pinb.4 = Output
'set up PWM on OC0A, OC0B, OC1B at approx 250Hz
Config Timer0 = Pwm , Prescale = 64 , Compare A Pwm = Clear up , Compare B Pwm = Clear up
set wgm01 'change mode to fast pwm
'config Timer1 (can't use "config timer1"), PWM, prescale=64
tccr1 = &B0000_0111 'disable OCR1A, set prescale=64
gtccr = &B0110_0000 'PWM mode for OCR1B, clear OC1B on match
'ocr1c = 255 'full count range
'load pwm lookup table
restore pwm_table
for i = 1 to 99
read table(i)
next i
'set pwm's to initial state
red_pwm = table(1)
green_pwm = table(1)
blue_pwm = table(1)
'ramp up red
for i = 1 to 99
red_pwm = table(i)
waitms speed
next i
'plain cycle R -> R+G -> G -> G+B -> B -> B+R -> repeat
'ramp up green
for i = 1 to 99
green_pwm = table(i)
waitms speed
next i
'ramp down red
for i = 99 to 1 step -1
red_pwm = table(i)
waitms speed
next i
'ramp up blue
for i = 1 to 99
blue_pwm = table(i)
waitms speed
next i
'ramp down green
waitms speed
next i
'ramp up red
for i = 1 to 99
red_pwm = table(i)
waitms speed
next i
'ramp down blue
blue_pwm = table(i)
waitms speed
next i
'look-up table to provide semi-log output from linear ramp (gives better apparent brightness than linear duty cycle ramp)
'99 entries in lookup table
pwm_table:
'idx 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
data 10 , 11 , 11 , 12 , 13 , 14 , 15 , 16 , 17 , 18 , 19 , 20 , 21 , 22 , 23 , 25 , 26 , 27 , 28 , 30 , 31 , 33 , 34 , 35 , 37 , 39 , 40 , 42 , 43 , 45 , 47 , 49 , 50 , 52 , 54 , 56 , 58 , 60 , 62 , 64 , 66 , 68 , 70 , 73 , 75 , 77 , 79 , 82 , 84 , 87 , 89 , 91 , 94 , 97 , 99 , 102 , 105 , 107 , 110 , 113 , 116 , 119 , 121 , 124 , 127 , 130 , 133 , 137 , 140 , 143 , 146 , 149 , 153 , 156 , 159 , 163 , 166 , 170 , 173 , 177 , 181 , 184 , 188 , 192 , 196 , 199 , 203 , 207 , 211 , 215 , 219 , 223 , 227 , 231 , 236 , 240 , 244 , 248 , 250
END |
