I'm also curious about the optimizations. Code size is usually slightly smaller with optimizations enabled, but what about execution speed? One poster reported on some testing and said optimization made his test program run slower.
There doesn't seem to be any documentation about optimizations, except for a tiny bit in the manual which isn't much help:
This options does additional optimization of the generated code.
Since it takes more compile time it is an option.
_________________ If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.5
Joined: 01 Feb 2008 Posts: 12 Location: NW Arkansas, USA.
Posted: Sun Feb 03, 2008 8:05 pm Post subject: Optimization speed.
I'm having a weird effect but it has to do with the fiuse settings;
I had the /8 fuse set on a ATMEGA88 (default) and if you turned on optimization the program ran 8X slower, and the delays were off by a factor of 8X. Once I flipped the bit then the difference between optimization or not optimizing went away. So it kind of looks like optimization and the fuses are combining to gang up on my little program, so I have it turned optimization off until someone figures out why it's acting so weird. _________________ Cecil
k5nwa
"Blessed are the cracked, for they shall let the light in."
