LCD connections
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive
rosco
PostPosted: Wed Jul 14, 2004 11:23 am    Post subject: LCD connections Reply with quote
I have a PCB with the LCD R/W line connected to a Port pin. It is used in 4bit mode. Is there a way to reset this Port pin (R/W = 0) before attempting to perform the Config Lcd function so that it will work ok? It works fine with the R/W line hardwired to 0v.
I need to do this to avoid cutting tracks. Crying or Very sad
Regards Ross
Vilko
PostPosted: Thu Jul 15, 2004 7:18 am    Post subject: How about Reply with quote
Well how about
portpin = 0
if it does not work, then simply hard connect R/W to GND, it will not harm portpin at all. (I think)
Vilko
rosco
PostPosted: Thu Jul 15, 2004 10:07 am    Post subject: Reply with quote
Thanks Vilko
I have allready tried that, both as a BASIC and assembler command but neither work.
I think the compiler must perform the "Config Lcd" first and then sort the rest of the code.
If I connect my scope to the LCD E & R/W pins I can see the E line active high pulses before the R/W line is driven low, allthough the instruction to reset the portpin is placed before the "Config Lcd".
You are right though, it is probably ok to tie the pin to ground, especially if I reset it in my program. It is only like using it as an input.
Ross
PostPosted: Sun Jul 18, 2004 11:53 pm    Post subject: Reply with quote
Set the pin to 0, and use LCDINIT command to re-init the display.
rosco
PostPosted: Mon Jul 19, 2004 9:12 am    Post subject: Reply with quote
Thank you Mark, I knew I had seen a way to do it. Just could not remember where!
As usual a case of RTFM. (Read The Flipping Manual).
Regards Ross
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive All times are GMT + 1 Hour
