pcexperte
Posted: Tue Nov 20, 2007 11:16 am Post subject: WIZ810MJ Board and litte Webserver in Bascom |
Hello all together,
i build a little PCB for ATMEGA168 (with internal 8MHz Clock) and space for a WIZ810MJ Module.
It works with 3,3V so it can be very little
I read the Datasheet and build a little webserver to switch the onboard LED on and off.
Access http://heldt-intern.dyndns.org:81
I implement authentification so you must log in with username admin and password demo !
I have at the moment 2 PCB to give away for 11 EUR with shipping, only in EU!
More about the PCB you can found by follow the link on the webserver site (german language!)
The Bascom code is my first version, so you can change it to be much smaller.
Within the Code you can enable/disable authentification, set the username and passwort, set ip gateway and subnet and mac-adress.
In this little version only one socket is used.
Sorry for my bad english.
Thanks to ben for his great website where i learn so much so i can build this own webserver software!
If you have ideas to make it better please post it.
Greetings from germany
Thomas Heldt |
pcexperte
Posted: Tue Nov 20, 2007 10:35 pm Post subject: |
Here are a new version, a little bit faster |
pcexperte
Posted: Wed Nov 21, 2007 2:42 pm Post subject: |
Hi folks,
more information and the latest software release are still on
my little hobby homepage at http://heldt-intern.dyndns.org
(german language). |
bzijlstra
Posted: Wed Nov 21, 2007 7:17 pm Post subject: Circuit Cellar contest.... |
Circuit Cellar AVR contest 2006. And the winner is Alberto Ricci Bitti. Used programming language Bascom-AVR.
And now? Circuit Cellar started a contest with the W5100. Used on the WIZ810MJ module. Perhaps this year again, the winner is.... and the used programming language is Bascom-AVR.....
Thomas, think you did a great job. Both on hardware and on software.
Have fun
Ben Zijlstra |
bzijlstra
Posted: Mon Nov 26, 2007 9:59 am Post subject: Real hardware... |
Here a picture of the board. And Bascom-AVR-code is running fine.
Have fun
Ben Zijlstra |
