Am I going mad?
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
clive
PostPosted: Sat Nov 17, 2007 10:19 pm    Post subject: Am I going mad? Reply with quote
Please help me with a problem I have using Timers.
When I use the following code and simulate it,
I get the right value in variable A (i.e A=1001)
$regfile="reg51.dat"
$crystal=12000000
$noinit
disable interrupts
Dim A as word
Set Tmod.0
Reset Tmod.1
TL0=1
TH0=0
Start Timer0
Waitms 1
A = Counter0
But when I use the following code as recomended in the help
file of Bascom, I get a hopelessly incorrect value (A=65535)
$crystal=12000000
$noinit
disable interrupts
Dim A as word
Config Timer0=counter , Gate=Internal , Mode=1
Load Timer0 , 1
Start Timer0
Waitms 1
A = Counter0
What am I doing wrong?
Gianni
PostPosted: Sun Nov 18, 2007 10:21 am    Post subject: Reply with quote
$crystal=12000000
$noinit
disable interrupts
Dim A as word
Set Tmod.0
Reset Tmod.1
You can't do that! Tmod is not bit addressable
TL0=1
TH0=0
Start Timer0
Waitms 1
A = Counter0
$crystal=12000000
$noinit
disable interrupts
Dim A as word
I suppose this can't works with simulator
Timer0=counter means you use an external clock at T0 pin
You should use
Config Timer0=timer , Gate=Internal , Mode=1
Load Timer0 , 1
Load works for autoreload mode only
You must use Counter=1
Start Timer0
Waitms 1
A = Counter0
clive
PostPosted: Sun Nov 18, 2007 10:41 am    Post subject: I an sane again! (I think) Reply with quote
Thank you, now I know where I went wrong.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
