gunnebo
Posted: Sat Oct 13, 2007 1:38 am Post subject: Read sms message |
Iīm trying to read sms message from Sony Ericsson K700 with AT commands using attiny2313 and Bascom.
I have connected the phone and a LCD-display to attiny2313 and the communication works and is plotted on the display.
But somehow I can not read message. If I print ATCMGR=? I get OK but then what? How do I find the latest message? If I type something else then ?, I get ERROR. |
kimmi
Posted: Sat Oct 13, 2007 2:16 am Post subject: |
to read the sms try Print "AT+CMGR=1" = read sms 1
or use the +CMTI: command to get new sms and sms index number
Do you use TEXT or PDU format ?
AT+CNMI=x New message indications to TE , x = see your phone AT Commands for right setup for the +CMTI: command
AT+CMGF=0 = PDU
AT+CMGF=1 = TEXT
more info about your phone here Developers' Guidelines - AT Commands
Read the dg_at_2004_r6b PDF then you know more about your phone AT commands _________________ / Kim |
gunnebo
Posted: Sat Oct 13, 2007 12:10 pm Post subject: |
Hi Kimmi
History:
I have a small VB6 program (send sms works, not tried receiving yet) that I wanīt to use to send sms to an application somewhere, and that app. receives the message and returns an answer depending on the message.
My old SE-mobiles support only PDU-format.
I have all the PDF's from SE.
I have done some programming in VB6 and VB.net but Iīm a newbie with AVR and Bascom.
Print "AT+CMGR=1" returns ERROR
Print "AT+CNMI?" returns +CNMI: 2,0,0,0,0 and I havenīt been able to change this. I probably write it in the wrong way.
Print "AT+CNMI=2,1,0,0,0" doesnīt change anything. |
kimmi
Posted: Sat Oct 13, 2007 12:57 pm Post subject: |
Hej Gunnebo,
You need to setup you Message Storage to
(AT+CPMS Preferred Message Storage) ME = phone
here is my setup for Siemens
Print "ATE0" ' Echo off
Print "AT+CSCS=GSM" 'Select The Character Set
Print "AT+CPMS=ME" Preferred Message Storage
Print "AT+CNMI=2,1,0,0,0" 'New Messages Indication to TE
To read PDU you need to convert the PDU string to Text
or use simple commands in your program and use the PDU as command _________________ / Kim |
gunnebo
Posted: Sat Oct 13, 2007 2:44 pm Post subject: |
Hi Kimmi
Print "AT+CPMS=ME" returns ERROR
From SE pdf:
Set command: AT+CPMS=<mem1>[,<mem2>[,<mem3>]]
Hmmm? Donīt understand this. Do I need to select a specific memory cell?
Print AT+CPMS? returns +CPMS: "SM",0,25,"SM",0,25,"ME",16,118 |
kimmi
Posted: Sat Oct 13, 2007 2:50 pm Post subject: |
Sorry
The SE use "ME"
so try this way
Print "AT+CPMS=" ; Chr(34) ; "ME" ; Chr(34) 'Select Phone Memory _________________ / Kim |
pratik
Posted: Sat Oct 13, 2007 9:23 pm Post subject: |
Hi ,
Sorry to disturb u but which Sony Ericsson mobile phone support
AT+CMGF=1 = TEXT command
& pin out of mobile phone to connect to serial port of micro controller |
gunnebo
Posted: Sat Oct 13, 2007 9:35 pm Post subject: |
>pratik: Donīt know if any SE mobile phones support text command, maybe some new models.
>kimmi: That did the trick. I thought that I was writing the command in the wrong way and I tried it in anyway I could think of, but not that one.
Now I just have to convert PDU to text.
(Sorry about Spain ) |
kimmi
Posted: Sat Oct 13, 2007 9:57 pm Post subject: |
Thats nice you got it to work..
Pdu is no big deal the problem is the 2313 it dont have alot of sram
but if you can make it simple then use the PDU format of the text only
like use sms commands 8 chars long (for all) then you just read the last 14 chars of the PDU and use them as commands
12345678 is in PDU 31D98C56B3DD70
SEE more ...HERE
About Spain ! well the best did win so cool
Add : bas test file for the SMS TEXT<>PDU part not full PDU date time smsc ect try run it in bascom simulator . _________________ / Kim |
