Data exchange between PC and EASY TCP/IP
Arera
PostPosted: Tue Oct 09, 2007 9:01 pm    Post subject: Data exchange between PC and EASY TCP/IP Reply with quote
Hi everyone!
Iīm at the very beginning with my EASY TCP/IP experiances.
In fact, the board isnīt soldered yet...
But Iīm impatient!
There one aspect, I do not really understad:
How will I exchange data between my PC and the EASY TCP/IP Module?
I imagine something similar to Hyperterminal (for RS232):
Establish a connection, then send and receive data.
Can I use Telnet?
Do I really need VB-Web servers and clients? Shocked
Thanks for any hints, tipps and ideas!
Marc
Bascom Ambassador
PostPosted: Wed Oct 10, 2007 11:26 am    Post subject: UDP... Reply with quote
Check UDP
With an acknowledge from the receiver it can be very good.
Ben Zijlstra
Arera
PostPosted: Wed Oct 10, 2007 12:12 pm    Post subject: Reply with quote
Yes, I read about the the differences between UDP an TCP.
But my question is on a "lower level":
What programm do I use on my PC to UDP-connetct to the EASY TCP/IP module? Confused
Bascom Ambassador
PostPosted: Wed Oct 10, 2007 8:53 pm    Post subject: EDTP Internet Test Panel... Reply with quote
There is a UDP-client you can use. It is called the EDTP Internet test panel and the source in Visual Basic 6.0 can be downloaded from www.edtp.com
http://www.edtp.com/download/testpnl/testpanel_cur.zip
It uses PORT 7 to do a echo of the received characters and it uses PORT 5000 to do some one-way action.
Have fun
Ben Zijlstra
Arera
PostPosted: Thu Oct 11, 2007 7:28 am    Post subject: Reply with quote
That means (at least to me...) data exchange between PC an EasyTcpIp is not THAT easy Rolling Eyes
Thank you Ben for the links, but I need an .exe!
I donīt know anything about VB Embarassed
I expected it to be as easy as RS232 via Hyperterminal.
Am I right so far?
Thanx, Marc
Bascom Ambassador
PostPosted: Thu Oct 11, 2007 8:41 am    Post subject: EXE can be found here Reply with quote
I compiled the Visual Basic source and the source + EXE file can be downloaded at http://members.home.nl/bzijlstra/software/communication/testpanel_cur.zip
After starting the EXE you can change the IP-number.
Give it a try
Ben Zijlstra
Arera
PostPosted: Thu Oct 11, 2007 3:38 pm    Post subject: Reply with quote
Sounds good to me.
But the link doesnīt work.
Could you please check it?
Thanks a lot for your help!
Marc
Bascom Ambassador
PostPosted: Thu Oct 11, 2007 4:49 pm    Post subject: Reply with quote
Ssssorry, my fault...
There was a S after communication that shouldn't be there.
Ssssssssssssssssssssilly me
Ben Zijlstra
