Writing EEPROM from USB-ISP progr.
nisse
PostPosted: Fri Sep 07, 2007 12:37 pm    Post subject: Writing EEPROM from USB-ISP progr. Reply with quote
Hi all
Just got my USB-ISP programmer from MCS and it's alot faster then my o ld200/300
However, I cant write EEPROM contents from the Bascom AVR ISP Programmer.
If I change a value, press Write buffer to EEPROM or Auto program chip, it looks ok, but when I read back the data, nothing is changed... :S
Anyone have any ideas as to what is wrong?
Flash programming works fine.
Nisse
nisse
PostPosted: Wed Sep 19, 2007 8:09 am    Post subject: Reply with quote
Found out that you have to load a saved EEPROM image from disk for it to work.
If you just enter the programmer, edit some bytes and try to write, it doesn't work.
But if you save that after editing and then reloads it, it writes ok...
