Tripwire
Posted: Sun Jun 17, 2007 2:27 pm Post subject: Need help with person counter project |
Hi guys i'm doing a project for school and i need to make a person counter. Now i have wrote the most of the program needed for te project.
The only thing i need now is to write a program that transfers the numbers from the counter to my 7 segment diplays and in between there are 74hc4094 as datashifters registers. Now i learned to write bascom in a month so i don't know much about how to write most things. I heard i needed to write an array or something but i don't know how to start . Can someone plz help me a bit to start creating an array for my project?
here's my program (i use an 89c2051 uc btw)
Dim Bteller As Byte
Dim Bingave As Byte
Bteller = 00
P1.5 = 1
P1.7 = 0
P1.6 = 0
If P1.7 = 1 And P1.6 = 0 Then
Bteller = Bteller + 1
Print "persoon in" ; Bteller
Waitms 50
P1.5 = 0
Waitms 10
If P1.6 = 1 And P1.7 = 0 Then
Bteller = Bteller - 1
If Bteller = 255 Then
Bteller = 0
Print "person out " ; Bteller
Waitms 50
P1.5 = 0
Waitms 10
End |
Gianni
Posted: Mon Jun 18, 2007 8:19 am Post subject: |
With a single 4094 you can count until 99; simply use makebcd and shiftout statement.
Do not forget to limit your counter to 99.
Regards |
Tripwire
Posted: Mon Jun 18, 2007 10:23 am Post subject: |
can you give me an example, how to use makebcd and shiftout statements? because the examples in bascom are a bit unclear on how it works. We used 2 4094 btw. |
Gianni
Posted: Mon Jun 18, 2007 2:01 pm Post subject: |
Makebcd works from 0 to 99 decimal
To convert number greater then 99 a different approach is necessary.
I do not remember how the 4094 clock works;
eventually try shiftout Datapin,Clockpin,ones,4
Code: | dim Tmp1 as byte
dim Tmp2 as byte
dim hundreds as byte
dim tens as byte
dim ones as byte
dim value as byte
Datapin alias P1.7 'serial data input
Clockpin alias P1.6
Latch alias P1.5 '4094 latch enable
latch = 0
datapin = 0
clockpin = 0
input "value ",value
Tmp1 = value
hundreds = Tmp1 / 100
Tmp2 = hundreds * 100
Tmp1 = Tmp1 - Tmp2
tens = Tmp1 / 10
Tmp2 = tens * 10
ones = Tmp1 - Tmp2
print hundreds;tens;ones;" = "; value
shiftout Datapin,Clockpin,ones,3
shiftout Datapin,Clockpin,tens,3
shiftout Datapin,Clockpin,hundreds,3
latch = 1
nop 'update 4094 output
nop
latch = 0
loop |
Tripwire
Posted: Mon Jun 18, 2007 2:49 pm Post subject: |
thx man! but i only need to count to 99 so if you can give me an example of makebcd then i can get to work!! |
Gianni
Posted: Tue Jun 19, 2007 7:30 am Post subject: |
Quote: | but i only need to count to 99 |
I suppose you do not use a bcd to 7 segment decoder but directly drive the display with the 4094.
Is that right ? |
Tripwire
Posted: Tue Jun 19, 2007 8:01 am Post subject: |
Hey here is a link to our schematic of the counter. We don't use a decoder like you said.
u4 and u5 are the 7 segment display's |
Gianni
Posted: Tue Jun 19, 2007 9:05 am Post subject: |
Ok!
Try this.
Code: | Tmp1 = makebcd(value)
Tmp1 = Tmp1 and 15
Tmp1 = lookup(Tmp1,Bcd2_7seg)
shiftout Datapin,Clockpin,Tmp1,3 'send ones
shift Tmp1,right,4
shiftout Datapin,Clockpin,Tmp1,3 'send tens
const Sa = 1 'segment a d0
const Sb = 2 'segment b d1
const Sc = 4
const Sd = 8
const Se = 16
const Sf = 32
const Sg = 64
const Sdot = 128 'dot d7
Bcd2_7seg:
data Sa+Sb+Sc+Sd+Se+Sf 'digit 0
data Sb+Sc 'digit 1
data Sa+Sb+Sg+Se+Sd 'digit 2
data Sa+Sb+Sc+Sd+Sg 'digit 3
'digit 4
'digit 5
'digit 6
'digit 7
'digit 8
'digit 9
Tripwire
Posted: Wed Jun 20, 2007 7:35 am Post subject: |
i don't get it :S i used your program to controll the display but i don't get anything on my displays not even 1 segment lights up.
i did this:
Code: | Dim Bteller As Byte
Dim Tmp1 As Byte
Dim A As Byte , C As Byte
Bteller = 00
P1.5 = 1
P1.7 = 0
P1.6 = 0
Print "persoon binnen " ; Bteller
Waitms 50
P1.5 = 0
Waitms 10
Bteller = 0
Print "persoon weg " ; Bteller
Waitms 50
P1.5 = 0
Waitms 10
If Bteller = 99 Then
Bteller = 00
A = 63
C = 6
Tmp1 = Makebcd(a)
Tmp1 = Tmp1 And 15
Tmp1 = Lookup(tmp1 , Bcd2_7seg)
Shiftout P3.3 , P3.4 , Tmp1 , 3 'send ones
Tmp1 = Makebcd(c)
Shift Tmp1 , Right , 4
Shiftout P3.3 , P3.4 , Tmp1 , 3 'send tens
Const Sa = 1 'segment a d0
Const Sb = 2 'segment b d1
Const Sc = 4
Const Sd = 8
Const Se = 16
Const Sf = 32
Const Sg = 64
Const Sdot = 128 'dot d7
Bcd2_7seg:
Data Sa + Sb + Sc + Sd + Se + Sf 'digit 0
Data Sb + Sc 'digit 1
Data Sa + Sb + Sg + Se + Sd 'digit 2
Data Sa + Sb + Sc + Sd + Sg 'digit 3
Data Sb + Sc + Sf + Sg 'digit 4
Data Sa + Sc + Sd + Sf + Sg 'digit 5
Data Sa + Sc + Sd + Se + Sf + Sg 'digit 6
Data Sa + Sb + Sc 'digit 7
Data Sa + Sb + Sc + Sd + Se + Sf + Sg 'digit 8
Data Sa + Sb + Sc + Sd + Sf + Sg 'digit 9
End |
Gianni
Posted: Wed Jun 20, 2007 12:11 pm Post subject: |
You forget to latch data into 4094; pulse pin 1
P3.2 = 1
nop
nop
P3.2 = 0
Pin 15 of 4094 must be High; connect to +5v
IMHO is not a good idea drive all the 7 leds with a single resistor; use separate resistors
Regards |
Tripwire
Posted: Thu Jun 21, 2007 7:39 am Post subject: |
well the thing is when i program a microcontroller with a program i got from my teacher (last project) the displays work. so it has to do something with the program. |
Tripwire
Posted: Wed Jun 27, 2007 10:24 am Post subject: |
hey got another question for you:
why do you do tmp1 = tmp1 and 15 ?
btw i'm getting a few segments that are lighting up so the program almost works |
subar
Joined: 31 May 2007 Posts: 142 Location: kurdistan region
Posted: Wed Jun 27, 2007 1:50 pm Post subject: |
this is the code you can get benifet from and i had excuted it works correctly...
' port A 7 segment
' 0 -----------> a
' 1 -----------> b
' 2 -----------> c
' 3 -----------> d
' 4 -----------> e
' 5 -----------> f
' 6 -----------> g
$regfile = "m16def.dat"
Config Porta = Output
Porta = 255
Dim I As Byte
Dim X(16) As Byte
Restore Value_table
For I = 1 To 16
Read X(i)
For I = 1 To 16
Porta = Not X(i)
'Porta = X(i)
Waitms 500
Value_table:
Data &H40 , &H79 , &H24 , &H30 , &H19 , &H12 , &H02 , &H78
Data , &H00 , &H10 , &H08 , &H03 , &H46 , &H21 , &H06 , &H0E _________________ many people know what to do,But few people do what they know.
subar |
Tripwire
Posted: Thu Jun 28, 2007 7:32 am Post subject: |
thx man but can you give me m16def.dat? i don't have the file  |
sakaz
Posted: Thu Oct 15, 2009 12:18 am Post subject: |
Hi forum,
Hope you are doing well all. I have been working with Bascom AVR for last 2 years and i am so glad to learn alot of things from this great forum. I must thank all of you.
These days i am working on a project with the 7 Segment (Liquid Crystal Display) 6 1/2". and trying to drive with the Cd4094, CD4543 & CD4514 as per attached schematic.
I want to display my result on the 6 digit display but i am having some problem.
I want to lacht the CD4514 first to select the digit and then CD4543 to show the data but i cant.
'name : shift.bas
'copyright : (c) 1995-2005, MCS Electronics
'purpose : example for SHIFTIN and SHIFTOUT statement
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
$regfile = "m8def.dat" ' specify the used micro
$crystal = 4000000 ' used crystal frequency
$baud = 19200 ' use baud rate
Dim L As Long
Config Pinb.0 = Output
Config Pinb.1 = Output
Config Pinb.2 = Output
Sipo_sck Alias Portb.0 'port for sck 74hc
Sipo_din Alias Portb.1 'data serial input
Sipo_latch Alias Portb.2 'latch pin
Sipo_sck = 0 'initial out
Sipo_din = 0
Sipo_latch = 0
Dim Data_sipo As Byte
Data_sipo = 0
Shiftout Sipo_din , Sipo_sck , Data_sipo , 1
Sipo_latch = 1
Waitms 100
Sipo_latch = 0
Shiftout Sipo_din , Sipo_sck , Data_sipo , 2 <---- LSB Shifted out first when Clock goes low.
Sipo_latch = 1
Waitms 100
Sipo_latch = 0
Waitms 100
Incr Data_sipo
But i inverse the data input lines as per:
11 ----- 2
12 ----- 3
13 ----- 21
14 ---- 22
Then it does work fine. Why i cant find the reason. please help.
Regards, |
