Posted: Tue Jun 29, 2004 1:07 pm Post subject: 1wire & interrupts
Hi!
Is that true that 1wire bus will not work with interrupts enabled? I need to use Timer0 interrupt together with 1wire bus and I'm confused.. _________________ Regards
Grzegorz
Yes, as the 1wire does not use system resources like a timer, it means the timing is created by a software loop. This loop may not be interrupted.
So there are 2 options :
- modify the 1 wire code so it uses a timer
- disable the interrupts while using 1wire.
In general, the idea is not to use system resources like timers because they are needed by the user. When a statement uses a system resource, it is mentioned in the help. _________________ Mark
