rileyesi
Posted: Fri Mar 23, 2007 8:14 pm Post subject: Problems printing to SD card |
Hi.
Yesterday, I wrote a small program to write some garbage data to an SD card to learn how to do it. And, it worked! I wanted to add a menu to the program, so today, I added a menu loop and suddenly it won't print data to the SD card. Here is the latest code:
Code: |
' This is MyAVRDOS Second Try.bas
$regfile = "M128def.dat"
$crystal = 7372800
$hwstack = 128
$swstack = 128
$framesize = 128
$baud1 = 19200
Config Clock = Soft
Config Date = Dmy , Separator = /
Dim Btemp1 As Byte
Dim Count As Word
Dim A As Word
Dim Choice As Byte
Open "Com1:" As Binary As #1 ' use #1 for fs_interpreter
Config Serialin = Buffered , Size = 20
Print #1 , "Heeere we go!"
$include "Config_MMC.bas"
' Include AVR-DOS Configuration and library
If Gbdriveerror = 0 Then
$include "Config_AVR-DOS.BAS"
Beginning:
' Clear Screen
Print #1 , Chr(27)
' Display main menu and get choice
Print #1 , "MAIN MENU FOR DATA LOGGER" : Print #1,
Print #1 , "What do you want to do?" : Print #1 , : Print #1,
Print #1 , "1 To read the system time"
Print #1 , "2 To set the system time"
Print #1 , "3 To exit menu and log data" : Print #1,
Input "Enter Choice => " , Choice
Select Case Choice
Case 1
Print #1 , Time$
Input "Hit any key to go back to main menu"
Goto Beginning
Case 2
Goto Settime
Case 3
Goto Mainprog
Case Else
Print #1 , "Bad Choice. Try Again. "
Wait 1
Goto Beginning
End Select
Mainprog:
Count = 0
A = 0
Print #1 , "Starting the loop"
Open "Test.txt" For Append As #10
Print #1 , "Opened Test.txt"
Print #10 , "Count" ; "{009}" ; "A"
Print #1 , "Wrote headings to file"
For Count = 1 To 100 Step 1
Print #10 , Count ; "{009}" ; A
Print #1 , Count ; "{009}" ; A
A = A + Count
Waitms 100
Next Count
Close #10
Print #1 , "Loop done!"
Settime:
' Clear Screen
Print #1 , Chr(27)
Goto Beginning
Else
Print #1 , "Error during Drive Init: " ; Gbdriveerror
All the Print #1 statements work (i.e. send data to the serial port and read on the terminal emulator) and the menu loop works (i.e. the program branches where I want), but the program hangs up at the Print #10 statements. I added more Print #1 to see where is stops.
One other thing, I see in the manual that using the print statement in AVR-DOS you must use strings. Yesterday, it ran using the numeric values and the data showed up as numbers in the spreadsheet I imported the data into. However, as one of my fix tries, I changed the Print #10 statement as follows:
Code: |
Print #10 , str(Count) ; "{009}" ; str(A )
Anybody see a problem??
Thanks and Regards,
Pete
EDIT:
Forgot to mention that converting the variables to strings in the print statement had no effect. |
rileyesi
Posted: Tue Mar 27, 2007 6:36 pm Post subject: |
Hi.
Just an update on my problem. Still not able to print to the SD card.
I changed cards (two time, in fact!), ran the BASCOM update wizard (none found), ran a virus scan on my computer (getting despirate!), and the problem remains.
One more clue, if I comment out the PRINT #10 commands, the program works fine. I get no errors and all the "PRINT #1" commands work (i.e. I can see the output on the terminal emulator). However, when I look on the SD card there is no "test.txt" file. I assumed that there would be a file, but of 0 size. I opened the file (using both APPEND and OUTPUT at different times) and the file apparently is not created.
What am I doing wrong??
I'm coming to the conclusion that my BASCOM might be corrupted just like my 1.11.8.3 version was. To remind you, I had a program that Luciano and Ian were able to compile and run, they e-mailled me their compiled version and it ran, but my compiled version did not. My next step is to try my latest fixes on my BASCOM version I have at home.
Thanks for your time. Any suggestions would be appreciated.
Regards,
Pete |
oe9vfj
Joined: 17 Jun 2004 Posts: 269 Location: Austria, Hard
Posted: Wed Mar 28, 2007 8:48 am Post subject: |
Every AVR-DOS command fills the variable gbDOSError with the information about the success-information.
0 is successful.
> 0 is an error.
Check after each command beginning with the InitFileSystem this variable.
I suppose, that there is a problem with the card. Can you work with this card on a PC. Probably try to reformat them. _________________ regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel |
rileyesi
Posted: Wed Mar 28, 2007 7:08 pm Post subject: |
Josef,
Thank you for your reply.
As you suggested, I checked the value of gbDOSError after every line of the program. In all cases, the value is 0 except I cannot check the value after my 'PRINT #10' commands. The program halts at that line. So, I remarked those print statements out and all the gbDOSErrors are 0 including when I open and close test.txt.
And, yes, the SD cards work on my PC. I can write and read files to and from them using Windows Explorer.
One other thing I did not consider is that my test PCB might have been damaged somehow. My program worked last week, and suddenly stopped working. I should have thought of the board being bad. It will take me some time to get a replacement. I'll let you know any results.
Thank you again and Regards,
Pete |
rileyesi
Posted: Wed May 09, 2007 7:13 pm Post subject: |
Josef,
I am returning to this problem because I finally got my new boards!
I have the same problem with the new boards, so it is an error on my part.
To further investigate, I modified your Test_DOS_Drive.bas from the samples directory changing the $CRYSTAL and the $BAUD lines. I commented out line #17 ($Include "Config_HardDisk_M128.bas") because I am using a 256 MB SD card. Here's the code:
Code: |
$crystal = 7372800
' Adjust HW Stack, Soft-Stack and Frame size to 128 minimum each!!!
$hwstack = 128
$swstack = 128
$framesize = 128
$baud = 19200
Config Clock = Soft
Config Date = Mdy , Separator = .
Dim Btemp1 As Byte
Print #1 , "Wait for Drive"
' Include here you driver for Compactflash/HardDisk or other
$include "Config_CompactFlash_M128.bas" ' Does drive init too
'$Include "Config_HardDisk_M128.bas"
Print #1 , "Init File System ... ";
Btemp1 = Initfilesystem(1) ' Partition 1
' use 0 for drive without Master boot record
If Btemp1 <> 0 Then
Print #1 , "Error: " ; Btemp1 ; " at Init file system"
Else
Print #1 , " OK"
Print #1 , "Filesystem: " ; Gbfilesystem
Print #1 , "FAT Start Sector: " ; Glfatfirstsector
Print #1 , "Root Start Sector: " ; Glrootfirstsector
Print #1 , "Data First Sector: " ; Gldatafirstsector
Print #1 , "Max. Cluster Nummber: " ; Glmaxclusternumber
Print #1 , "Sectors per Cluster: " ; Gbsectorspercluster
Print #1 , "Root Entries: " ; Gwrootentries
Print #1 , "Sectors per FAT: " ; Glsectorsperfat
Print #1 , "Number of FATs: " ; Gbnumberoffats
Else
' If you want to test with File-System Interpreter uncomment next line
'$include "FS_Interpreter.bas"
I got an error 206 in line 115 Library file not found (this is the CF_HD.lbx called out in Config_CompactFlash_M128.bas). I found the file on your web site and created the lbx file.
The program then compiled with no errors. However, when I ran it on my board, here is the output:
Quote: |
Wait for Drive
Error during Drive Init: 225
225Wait for Drive
225Wait for Drive
225Wait for Drive
The output simply runs non-stop.
I looked at the manuals but I could not find out what it means when Gbdriveerror has a value of 225.
As always, thank you for your time.
Regards,
Pete
EDIT:
I should mention that I am running BASCOM 1.11.8.7 registered version. |
oe9vfj
Posted: Fri May 11, 2007 9:39 am Post subject: |
If you want to write on a SD Card, you have to use the driver for SD/MMC Card.
use
Code: | $Include "Config_MMC.bas" |
instead $include "Config_CompactFlash_M128.bas"
check also hardware-setting in the file Config_MMC.bas according to your wiring. _________________ regards Josef
rileyesi
Posted: Fri May 11, 2007 8:00 pm Post subject: |
Joseph,
Thank you. That change you suggested worked.
However, I still can't write or print to the SD card. Here's my code:
Code: |
$crystal = 7372800
$hwstack = 128
$swstack = 128
$framesize = 128
$baud1 = 19200
Config Clock = Soft
Dim Btemp1 As Byte
Dim Count As Word
Dim A As Word
Dim Choice As Byte
Beginning:
' Clear Screen
Print #1 , Chr(27)
Select Case Choice
Case 1
Print #1 , Time$
Goto Beginning
Case 2
Goto Settime
Case 3
Goto Mainprog
Case Else
Wait 1
Goto Beginning
End Select
Mainprog:
Count = 0
A = 0
A = A + Count
Waitms 100
Next Count
Close #10
Settime:
' Clear Screen
Print #1 , Chr(27)
Goto Beginning
Else
The program simply stops at line #69 which reads
Code: |
If I comment out all the Print #10 statements, the program runs to the end.
Also, I checked the connections on my board with those used in Config_MMC.bas and they match (i.e. port b.0 is the chip select, port b.2 is the MOSI, etc.)
I'm pretty sure that the SD card is good because I can use it with my PC and I can run your Test_DOS_Drive.bas program using the cards.
Any other ideas or tests I can run??
As always, thank you for your time and patients!
Pete |
