TSEYFARTH
Posted: Thu May 03, 2007 1:19 am Post subject: What graphical LCD controllers work with BASCOM? |
Hi all...
I am looking to do a project that includes a touch screen graphical LCD. There is an ap note on one but the LCD is too small. I need one that is at least as large as a 12 key touchpad.
LEDSEE has one that uses a SED1335 controller - which although not color is pricey but large enough.
Can anyone suggest a different part and tell me which controllers interface easily with BASCOM?
Thank you!
Tim |
juanen
Posted: Fri May 04, 2007 12:04 am Post subject: |
bascom-avr only support 256x256 resolution, for example, 320x240 not supported, but 240x128 is supported.
chip T6963C for example is very easy. |
TSEYFARTH
Posted: Fri May 04, 2007 12:25 am Post subject: |
Any idea when Marc plans to support the larger resolution?
Any suggestions on a graphical LCD with touch screen that meets the largest supported resolution?
Tim |
Posted: Sun May 13, 2007 8:21 pm Post subject: |
Hi Tim,
Niels from Ledsee has added 2 touchscreen's today;
192x64 with an KS0108 controller and
240x128 with an T6963C.
Both controllers are supported by Bascom, so you can create very simple an touchscreen.
THIS is an 240x128 touchscreen that i have created in the past, and as you can see 12 buttons is no problem. |
Gbowky
Posted: Sun May 13, 2007 9:02 pm Post subject: |
Hello Evert
These displays look good, and cheap
The data sheet does not give details of the touchscreen, are these supplied when purchased or have you got them.
Cheers
geoff |
Gbowky
Posted: Sun May 13, 2007 9:33 pm Post subject: |
Hello Evert
Thanks that looks good,will give it a go.
Geoff |
pe1oxp
Posted: Sat Jun 16, 2007 4:27 am Post subject: |
Both controllers are supported by Bascom, so you can create very simple an touchscreen. |
How do i connect the 192x64, this display isn't supported by the compiler?
The driver only supports 2 Chip Select lines?
Or is this supported with an update of BASCOM-AVR and not mentioned in the Help-file?
Harry |
TSEYFARTH
Posted: Sun Jun 17, 2007 12:59 am Post subject: |
I bought one of the 240x128 LCD's from him. Nice device. But I have not begun to play with it yet...
Tim |
Stefan_Z
Posted: Tue Jun 19, 2007 11:53 am Post subject: |
Bascom supports several displays, but with proper documentation you can also write you own drivers. In the display-datasheets youŽll find all information - electrical and communication specs.
Usually you need a clock (CLK) and a data line. Also there is a select line to tell the display if a command (like contrast+ or invert) or data is being sent.
Sending the commands/data is done by SPIOUT or SHIFTOUT.
Displays with parallel datalines also work, you just need more pins.
I wrote a driver myself last month... for this display: http://www.pollin.de/shop/detail.php?pg=NQ==&a=NjY3OTc4OTk=
Since I started with ”C only a year ago, I would never have dreamed about being able to write the driver, but it works!
Again: if thereŽs a controller onboard with the display and you got a datasheet, it will be possible to use the display somehow. |
Rolf_H
Joined: 17 Mar 2007 Posts: 24 Location: Augsburg, Bavaria
Posted: Sat Sep 15, 2007 3:17 pm Post subject: Ledsee 240x128 T6963 ? |
Hi all.
I used a 128x128 SED-controlled lcd display from Ledsee.com in a DDS controlled oscillator application. The display was introduced by Evert Dekker in AN #148. Although the display works perfect I finally found the 128x128 size was too small for my application. Therefore I bought the Ledsee 240x128 display:
http://ledsee.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=144&category_id=23&manufacturer_id=0&option=com_virtuemart&Itemid=27
Has anyone played with this display? They sell it as a T6963 controlled display but I detected T6A39/T6A40 line/row controllers on it instead of T6963. I'm not very familiar with programming lcd displays. Therefore I would be very thankful for any answer.
Thanks for helping.
Rolf |
Posted: Sat Sep 15, 2007 5:02 pm Post subject: |
Hi Rolf,
Have the same screen from Ledsee up and running here.
240x128 Touchscreen will work fine in Bascom with the T6963.
Config Graphlcd = 240 * 128 , Dataport = Porta , Controlport = Portc , Ce = 3 , Cd = 0 , Wr = 2 , Rd = 1 , Reset = 4 , Fs = 5 , Mode = 6
For more information (schematic) check out THIS |
Rolf_H
Posted: Mon Sep 17, 2007 10:52 am Post subject: Hi evert. |
Hello Evert.
Thank you for the reply and all your information. Your info helped me very much. Your idea how to wire the touch-screen to the ADC is great. I use the display in a home made amateur radio transceiver - just one more building site... )
Rolf |
mucek
Posted: Mon Oct 08, 2007 1:51 pm Post subject: |
Hello everybody!
I am looking for 240x128 LCD, which will work with Bascom (so, no new lib to create...) AND will have negative yellow/orange/red illumination (that means: black display and yellow/... characters + graphic).
I check display from previous mail, but it's only avalible in "modern" white/blue combination. Well, I need something more "traditional" (will be built in wooden casing)... Does anybody have some suggestion where to look? I also checked www.lc-design.de (where I already ordered them several times), but their 240x128 LCDs have other controller + also wrong backlight color...
If there is such display that also has touchscreen, then I would be more than happy!!! (touchscreen is not 100% necessarry, but would be very useful to have it!)
Regards,
Gregor
p.s. I already programmed graphic LCDs with Toshiba T6963), but those were "only" 128x64 pixels... _________________ Programmer's life: When 1 bug is solved, another 3 appears... |
tang
Posted: Tue Dec 25, 2007 9:53 pm Post subject: |
Looking at the pinout for the Ledsee touch screens, it appears 9 volts is required for LCD drive. Is there any way to power these screens with just 5 volts? |
