'BASCOM-AVR IDE Version : 1.11.7.7
'Compiler: Version 1.11.7.7
'Serial : Serial DEMO
'Author: Luciano
'Processor: AT90S2313 / Select Chip = 2313def.dat from the IDE
'Code Purpose: Showing a stack problem. No other purpose.
'Forum Post: "Error in Frame Space (Stack problem)".
'Where to run the test: BASCOM AVR Simulator or AVRStudio Simulator.
'Calculations based on the information found in the Help file.
''(See help file topic "Options Compiler Chip").
'When you run the code with the simulator, open the
'memory window from the address $00DF downward to the address $0060.
'The memory window will display the HW stack,
'SW stack, Frame space and global variable space. (The whole SRAM).
''(My comments are based on the AT90S2313 data address space).
'The directives $hwstack, $swstack and $framesize override the
'values from the IDE Options/Compiler/Chip.
$hwstack = 32
$swstack = 10 'see comments in the Sub
$framesize = 41 'see comments in the Sub
Declare Sub My_sub(my_parameter As String)
Dim My_string_global As String * 10
Dim My_byte_global As Byte
My_string_global = "ABCDEFGHIL" 'stored from 0060 to 006A 11 bytes (10+1)
My_byte_global = 255 'stored at address 006B 1 byte
''(The address 0060 will be visible in the
''simulator memory window at the beginning of the Soft stack).
Call My_sub(my_string_global)
Sub My_sub(my_parameter As String) 'the parameter is passed by reference
Local First_number As Integer 'will use 2 bytes of Frame
Local Second_number As Integer 'will use 2 bytes of Frame
Local Addition_result As Integer 'will use 2 bytes of Frame
Local My_string_local As String * 10 'will use 11 bytes of Frame (10+1)
'FRAME SIZE REQUIREMENTS for this test=33 bytes
'Bascom AVR internal conversion routines need a maximum of 16 bytes.
'Therefore the minimal needed frame size for this test should be:
'2+2+2+11+16=33 bytes ($framesize=33)
'SOFT STACK SIZE REQUIREMENTS for this test=10 bytes
'Each local variable uses 2 bytes: We have 4 local variables so we need 8 bytes.
'Each parameter that is passed to a sub uses 2 bytes: so we need 2 more bytes.
'Therefore the minimal needed Soft Stack size for this test should be:
'2+2+2+2+2=10 bytes ($swstack=10).
First_number = 10011 'HEX 271B
Second_number = 20022 'HEX 4E36
Addition_result = 13330 'HEX 3412 just to see where written in the mem.window
My_string_local = "1234567890"
Addition_result = First_number + Second_number
Print "Result=" ; Addition_result ; " (Result should be 30033)"
''''''P r i n t with internal conversion.
'The Print below will only print the string >1234567890< when the
'$framesize is set bigger than 40.
Print ">" ; My_string_local ; "<"
''''''P r i n t without internal conversion.
' THE PROBLEM
' The Frame start address for the Bascom AVR internal conversion
' routines is correctly set at the address 8D. (After the first
' Print you will see that data output of the internal routines is
' written in the frame space starting at the address 8D).
' What is wrong is the address (location) where the local variables are
' stored in the frame space. The first byte used to store local data is
' at the address A5.(The simulator shows that in the mem.window).
' The first byte used to store locals should be at address 9D, not at A5.
' This because only 16 bytes before location 9D should be reserved by
' the compiler for the internal conversion routines.In this example
' the reserved 16 bytes are at the following addresses:
' 8D,8E,8F,90,91,92,93,94,95,96,97,98,99,9A,9B,9C where the byte
' at address 8D is the first byte of the frame space.If you run this
' example you will see that the compiler is reserving 24 bytes instead
' of 16 bytes for the internal conversion routines.
' If I follow the instructions in the Bascom AVR Help file, the
' above code should run with a Frame Size set to 33 bytes.
' (See comments in the above Sub).If you try a Frame Size of 33 bytes
' you will see that the data of the local variables will override the
' SW stack where the addresses are stored.If you try this example, start
' with a Frame Size = 41. (With 41 the code will run fine). If you set
' the Frame Size to 40, you will see that the address of the local string
' is overridden and therefore the second Print will print nothing.If you
' set the Frame Size to 33 you will see that all the addresses of the local
' variables are overridden, so that the first Print will print 0 and the
' second Print will print nothing.
' In the Bascom AVR report, the value Framestart also gives an indication
' of the problem.The values Space left and S-Stackstart are wrong in the
' report.(During simulation the S-Stackstart address is OK).
' (See the end of this text for part of the report with added comments).
' With the Frame Size set to 41 there is a frame overflow signaled by
' the Bascom AVR simulator with the checkbox "Frame overflow".
' I don't know why we get this warnig because the 10 bytes of the
' SW stack are not overridden by the data of the local variable.
' (With the Frame Size set to 41 the code runs fine).
' Data memory space of the above example.
' ($hwstack = 32, $swstack = 10, $framesize = 41).
' I have calculated all the values and compared them with the values
' displayed in the simulator memory window of Bascom AVR and AVRstudio.
'| HW stack | (Hardware stack grows downward)
'| First byte=DF |
'| Last byte=C0 |
'| Size HEX =20 | $hwstack = 32
'| SW stack | (Software stack grows downward)
'| First byte=BF |
'| Last byte=B6 |
'| Size HEX =0A | $swstack = 10
'| Frame | (Frame space grows upward)
'| First byte=8D |
'| Last byte=B5 |
'| Size HEX =29 | $framesize = 41
'| Global | My_string_global uses = 11 bytes (10 + null)
'| First byte=60 | My_byte_global uses = 1 byte
'| Last byte=8C | Free space left = 33 bytes
'| Size HEX =2D | -----------
'| | Total space for global = 45 bytes
' TOTAL SRAM = 32+10+41+45 = 128 bytes
' THE BASCOM AVR Report
'Report : STACKTEST
'Date : 03-05-2005
'Time : 16:25:04
'Compiler : BASCOM-AVR LIBRARY V 1.11.7.7, DEMO Edition
'Processor : 90S2313
'SRAM : 80 hex
'EEPROM : 80 hex
'ROMSIZE : 800 hex
'ROMIMAGE : 258 hex -> Will fit into ROM
'ROMIMAGE : 600 dec
'FLASH USED : 29 %
'BAUD : 9600 Baud
'XTAL : 4000000 Hz
'BAUD error : 0.16%
'Stack start : DF hex (OK, same as my value, same in the sim.mem.window).
'Stack size : 20 hex (OK, same as my value, same in the sim.mem.window).
'S-Stacksize : A hex (OK, same as my value, same in the sim.mem.window).
'S-Stackstart : C0 hex (Should be BF hex, in the sim.mem.window it is at BF).
'Framesize : 29 hex (OK, same as my value, same in the sim.mem.window).
'Framestart : 96 hex (Should be 8D hex, read the problem description).
'Space left : 34 dec (Should be 33,if you add 34 to the rest you get 129)
'LCD DB7 : PORTB.7
'LCD DB6 : PORTB.6
'LCD DB5 : PORTB.5
'LCD DB4 : PORTB.4
'LCD E : PORTB.3
'LCD RS : PORTB.2
'LCD mode : 4 bit
'Variable Type Address(hex) Address(dec)
'HWSTACK Word 005D 93
'SWSTACK Word 001C 28
'FRAME Word 0004 4
'COUNTER1 Word 004C 76
'TIMER1 Word 004C 76
'CAPTURE1 Word 0044 68
'COMPARE1A Word 004A 74
'PWM1A Word 004A 74
'ERR Bit 0006 6
'MY_STRING_GLOBAL String (OK) 0060 (OK) 96 (OK)
'MY_BYTE_GLOBAL Byte (OK) 006B (OK 107 (OK)
