ATtiny26L....problems
grzeniua
PostPosted: Tue Jun 08, 2004 1:48 pm    Post subject: ATtiny26L....problems Reply with quote
Hello everybody.
I'm new on this forum so please be polite Smile
My name is Grzegorz and I work for Whirlpool Europe/Poland.
I'm using demo version of Bascom AVR ver. 1.11.7.4 and currently ATtiny microcontrollers. O.K. - I think that's enough for an introduction
I know from internet (don't remember exactly where did I find it) that sometimes Bascom has problems with tiny uC...maybe that's not true but anyway - I have Confused
I've built quite simple board to start with: uC without reset (tiny 26 has a Power-Up reset) and without an external oscillator. I've just connected a LED in serial with 220Ohm resistor to +Vcc and was truing to make it blink (at least - lit) but it doesn't work.....
I've used internal oscillator (Fuse bits) and flash the uC with a simple STK200 programmer (from Bascom Very Happy ). It seem to program correctly because the state on pin is changing (when measured without LED) but WITH LED IT'S DEAD!
Maybe some bits were wrongly set or something else happens....
I'm including the short source code but I'm quite sure that it's correct:
$regfile = "at26def.dat"
$crystal = 1000000
Config Portb = Output
Config Porta = Input
Main:
Portb = 255
Porta = 0
Portb = 0
Porta = 255
That's it...do you have any comments???
Another thing is that I plan to use 1wire iButtons and I would like to ask if it's better to use for example AT89C2051 or ATtiny26. If it doesn't matter (if noone have found any problems with tiny) then I would prefer the AVRs.
Waiting for answers...
Grzegorz
ZbeeGin
PostPosted: Wed Jun 09, 2004 12:48 pm    Post subject: Reply with quote
According to help file the Tiny chips aren't fully supported by BASCOM AVR.
Try to add $TINY directive, but don't expect that your code will work as you wish.
ZbeeGin
PostPosted: Sun Jun 13, 2004 1:20 pm    Post subject: Reply with quote
Aiii!!
Ignore my previous reply. $TINY directive applies only to RAM-less chips like Tiny11/12.
First at all, if your LEDs are connected to PORTA you should use: CONFIG PORTA = OUTPUT.
When you configure PORTA as input (just like in your code), PORTA = 255 enable internal pull-ups and PORTA = 0 disable it. So when you measure voltage everythnig seems OK - pin state changes.
If your LEDs are connected to PORTB, make sure that LEDs are fitted correct. Wink
grzeniua
PostPosted: Tue Jun 15, 2004 6:46 am    Post subject: Reply with quote
Ok - thanks I'll try but I'm quite sure that I did it correctly. Anyway, maybe it would be better for me to start with '51... We'll see.
Grzegorz
ZbeeGin
PostPosted: Tue Jun 15, 2004 11:51 am    Post subject: Reply with quote
I'm shure, that you wrongly configure PORTA in your program.
Jeremy Wempren
PostPosted: Sat Jun 19, 2004 12:09 am    Post subject: Reply with quote
why are you even using 2 pins and whats the input for. there is no need for an input in a pure output system.
input is to read data. thats it. output is what you send out thats what will drive your led. remove the input config. and make sure your on the right pins with your circuit.
pin----res--led--vcc
or
pin---led--res--vcc
you can go the other way as well and change vcc for gnd but the output pins can't source alot, still it should be able to drive an led on every pin.
also i think the tiny even with no ram versions will still work with this simple program, it only will flake out if you try in any way to use memory, (ie variables) you can use io locations but not storage of anything very well.
hope this helps
jw
PostPosted: Sat Jun 19, 2004 10:57 pm    Post subject: Reply with quote
tiny26 is supported.
Make sure you sink current : connect anode of LED to VCC, kathode of LED to resistor, and other side of resistor to POR PIN.
When you make the pin low, the LEDd should emit light.
grzeniua
PostPosted: Wed Jun 23, 2004 10:11 am    Post subject: Reply with quote
Hi everybody Wink
In the beginning - thanks for all answers.
I've discovered that there are some problems with programmer. On all schemes I haven't found an option with an external oscillator - I did it and it finally works! Very Happy
The problem was that these uC were previously flashed in a different way and then the communication was lost...
Now everything works but.. I have new problems. Now it's according to 1Wire bus - it doesn't work.
First I've connected the thermometer DS1820 with a pull-up resistor 5,1kOhm and then with 4,3kOhm
The code of procedure (from Elektronika Dla Wszystkich Smile ) that reads the DS1820 is as follows (maybe you can take a look Shocked )
The result is T and 1wire defined as: Config 1wire = Pina.7
Sub Readds1820
1wreset
1wwrite &HCC
1wwrite &HBE
Bd(1) = 1wread(9)
1wreset
Tmp = Bd(1) And 1
If Tmp = 1 Then Decr Bd(1)
T = Makeint(bd(1) , Bd(2))
T = T * 50
T = T - 25
T1 = Bd(Cool - Bd(7)
T1 = T1 * 100
T1 = T1 / Bd(Cool
T = T + T1
T = T / 10
The result is always "-12"
Another thing - I was trying with DS1990 and..guess what! DOESN'T WORK! Crying or Very sad
this is a code (1wire as previously)
Waitms 100
1wreset
If Err = 1 Then
Lcd "No device!" ; Num
Call Read_numbers
Sub Read_numbers
1wwrite &H33
Lcd "reading..."
For R = 1 To 8
Number(r) = 1wread()
Next R
Lcd "number:"
Waitms 1
For R = 1 To 8
Lcd Number(r)
Wait 2
Next R
PLEASE - HELP ME!!!
Grzegorz
grzeniua
PostPosted: Wed Jun 23, 2004 12:07 pm    Post subject: Reply with quote
I forgot to add..this could be important: I'm using an internal oscillator (CKSEL = 0001). If I need to use the external oscillator is it O.K. to use 4MHz?
thanks in advance
Grzegorz
grzeniua
PostPosted: Wed Jun 23, 2004 1:11 pm    Post subject: Reply with quote
I've tested with 4MHz XTAL - still dead... Crying or Very sad
Grzegorz
PostPosted: Fri Jun 25, 2004 11:57 am    Post subject: Reply with quote
It is important that you use the proper crystal. Tiny26 has an internal osc. So when you use 4 MH xtal, make sure the chip runs on this xtal.
Always try to measure this :
$crystal=4000000
config portb=output
toggle portb
waitms 1000
Now measure the time. You now if the internal osc runs or the external.
1wire depends on proper xtal/$crystal
grzeniua
PostPosted: Mon Jun 28, 2004 9:51 am    Post subject: Reply with quote
Thanks a lot - now it works;)
It seems that the port was wrongly configured. I've used to set-up the port this: Config Portb = &B11111101.
However I have a new issue (or just a simple question):
how to display a binary number on LCD, because normally it's decimal displayed.
thank to everybody for your support
Grzegorz
