Next Problem 8.4
Joshua314
PostPosted: Wed Jan 24, 2007 5:17 pm    Post subject: Next Problem 8.4 Reply with quote
Hello all,
if have made a update to 8.4 at computer 1 ok
second computer ok third computer ok.
Upps .... second computer next open the bascom.exe i have a empty window
No Icon No line of File edit Program only the little window for the error on the screen. ok -- i think is my error .. Deinstall all version of bascom
delete directories clean registry .
Install 7.9 from cd make step by step update 8.0 to 8.3 all fine
every update i habe the complett IDE. now update to 8.4 and i have a empty window
What's happend ?? --> now i downgrade to 8.3 by copy bascom.exe
ok thats is working fine ....
Next BUG 8.4 at F1 --> Help no result......
Best Regard Thomas
Luciano
PostPosted: Wed Jan 24, 2007 5:37 pm    Post subject: Reply with quote
Try to delete the file bascom-avr.xml.
The Bascom settings are stored in this XML file.
If you delete the file, Bascom will create a new one.
Make sure that Bascom is not running when you delete the file.
See this thread:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=2703
If you use the Bascom AVR IDE version 1.11.8.3, the file
bascom-avr.xml is located under:
C:\Documents and Settings\<your user name>\Application Data\
If you use the Bascom AVR IDE version 1.11.8.4 or later version, the file
bascom-avr.xml is now located under:
C:\Documents and Settings\<your user name>\Application Data\MCS Electronics
Luciano
tomi
PostPosted: Wed Jan 24, 2007 5:56 pm    Post subject: Reply with quote
or simplest way :
del "%USERPROFILE%\Application Data\MCS Electronics\bascom-avr.xml"
or
del "%USERPROFILE%\Application Data\bascom-avr.xml"
from command line.
/Tomi
