Jeremy Wempren
Posted: Fri Jun 18, 2004 11:56 am Post subject: need more info |
i think a bit more info is needed.
first read this:
MASTER: The device that generates the serial clock.
SLAVE: Because the Serial Clock pin (SCK) is always an input, the AT25128A/256A
always operates as a slave.
TRANSMITTER/RECEIVER: The AT25128A/256A has seperate pins designated for
data transmission (SO) and reception (SI).
MSB: The Most Significant Bit (MSB) is the first bit transmitted and received.
SERIAL OP-CODE: After the device is selected with CS going low, the first byte will
be received. This byte contains the op-code that defines the operations to be performed.
INVALID OP-CODE: If an invalid op-code is received, no data will be shifted into the
AT25128A/256A, and the serial output pin (SO) will remain in a high impedance state
until the falling edge of CS is detected again. This will reinitialize the serial
communication.
CHIP SELECT: The AT25128A/256A is selected when the CS pin is low. When the
device is not selected, data will not be accepted via the SI pin, and the serial output pin
(SO) will remain in a high impedance state.
HOLD: The HOLD pin is used in conjunction with the CS pin to select the
AT25128A/256A. When the device is selected and a serial sequence is underway,
HOLD can be used to pause the serial communication with the master device without
resetting the serial sequence. To pause, the HOLD pin must be brought low while the
SCK pin is low. To resume serial communication, the HOLD pin is brought high while the
SCK pin is low (SCK may still toggle during HOLD). Inputs to the SI pin will be ignored
while the SO pin is in the high impedance state.
WRITE PROTECT: The write protect pin (WP) will allow normal read/write operations
when held high. When the WP pin is brought low and WPEN bit is “1”, all write operations
to the status register are inhibited. WP going low while CS is still low will interrupt a
write to the status register. If the internal write cycle has already been initiated, WP
going low will have no effect on any write operation to the status register. The WP pin
function is blocked when the WPEN bit in the status register is “0”. This will allow the
user to install the AT25128A/256A in a system with the WP pin tied to ground and still be
able to write to the status register. All WP pin functions are enabled when the WPEN bit
is set to “1”.
The AT25128A/256A is designed to interface directly with the synchronous serial
peripheral interface (SPI) of the 6800 type series of microcontrollers.
The AT25128A/256A utilizes an 8-bit instruction register. The list of instructions and
their operation codes are contained in Table 1. All instructions, addresses, and data are
transferred with the MSB first and start with a high-to-low CS transition..
WRITE ENABLE (WREN): The device will power-up in the write disable state when VCC
is applied. All programming instructions must therefore be preceded by a Write Enable
instruction.
WRITE DISABLE (WRDI): To protect the device against inadvertent writes, the Write
Disable instruction disables all programming modes. The WRDI instruction is independent
of the status of the WP pin.
READ STATUS REGISTER (RDSR): The Read Status Register instruction provides
access to the status register. The READY/BUSY and Write Enable status of the device
can be determined by the RDSR instruction. Similarly, the Block Write Protection bits
indicate the extent of protection employed. These bits are set by using the WRSR
instruction.
Table 1. Instruction Set for the AT25128A/256A
Instruction Name Instruction Format Operation
WREN 0000 X110 Set Write Enable Latch
WRDI 0000 X100 Reset Write Enable Latch
RDSR 0000 X101 Read Status Register
WRSR 0000 X001 Write Status Register
READ 0000 X011 Read Data from Memory Array
WRITE 0000 X010 Write Data to Memory Array
Table 2. Status Register Format
Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0
WPEN X X X BP1 BP0 WEN RDY
Table 3. Read Status Register Bit Definition
Bit Definition
Bit 0 (RDY) Bit 0 = 0 (RDY) indicates the device is READY.
Bit 0 = 1 indicates the write cycle is in progress.
Bit 1 (WEN) Bit 1 = 0 indicates the device is not WRITE ENABLED. Bit 1 = 1 indicates
the device is WRITE ENABLED.
Bit 2 (BP0) See Table 4.
Bit 3 (BP1) See Table 4.
Bits 4 - 6 are 0s when device is not in an internal write cycle.
Bit 7 (WPEN) See Table 5.
Bits 0 - 7 are 1s during an internal write cycle.
it's the data sheet. make sure your following the instructions and specifications.
JW |
Posted: Sat Jun 19, 2004 11:00 pm Post subject: |
You forgot the SPIINIT after the config statement. _________________ Mark |
Posted: Mon Jun 21, 2004 11:39 pm Post subject: |
You need to use the NOSS option of CONFIG SPI.
Then you need to use a custom pin for the CS.
All SPI statements will reset CS and SET it after the commands is completed. But as you need to spiin/spiout etc, you need to make CS low before you start the communication, and make it high when you are done.
It is also a good idea to explicit tell which mode you use, if MSB is sent first, etc. _________________ Mark |
