MAX7219 & 7 Seg Display
Xeus
PostPosted: Fri Jan 28, 2005 3:53 pm    Post subject: MAX7219 & 7 Seg Display Reply with quote
Hi
The Problem:
I'd like to build an counter with an ATmega8, MAX 7219 and a 3 Digit 7 Segment Display.
The hardware is already running, and I m able to show a single-figure number.
for examle:
0 to 9
But how does it work, to show a two figure number like 10,11...
How does it work to jump in the next digit??
Thanks,
xeus
SORRY FOR MY POOR ENGLISH Crying or Very sad
PostPosted: Fri Jan 28, 2005 5:23 pm    Post subject: Reply with quote
Well, how I do , maybe another method exists,
for a chrono, I created 2 arrays of data:
where the data was 0 to nine (values sent to the ports to light bar)
'--------[restaure data]----------------------------
'seconde
Restore Seconde
For J = 1 To 10
Read Tabseconde(j)
'minute
Restore tenseconde
For J = 1 To 10
Read Tabtenseconde(j)
'write at the end of program
'that is my data you must write ours !
----[data]--------------------------------------------------------
Seconde:
Data 72 , 115 , 107 , 108 , 47 , 62 , 73 , 127 , 109 , 95
tenseconde:
Data 34 , 155 , 186 , 106 , 248 , 233 , 50 , 251 , 122 , 243
then I compare my total of seconde against timer
and I increment my total of "10seconde"
if seconde =10 then
seconde=0
tenseconde=tenseconde+1
endif
Portb = Not Tabseconde(seconde)
Portd = Not Tabtenseconde(tenseconde)
For 3 you add one....
I hope you understand my frenchy english !
bon courage
JP
Xeus
PostPosted: Fri Jan 28, 2005 5:35 pm    Post subject: Reply with quote
does it already in the one wire mode work?
the communication between the mc and the max7219 needs just one port of the mc
thanks for your help
xeus
Twenty
PostPosted: Fri Jan 28, 2005 10:36 pm    Post subject: Reply with quote
Xeus,
I'm using the max7219 in one of my projects. The max7219 requires you to send a number 0-9 to a specific digit. You cannot send a number bigger than 9. What I do is to first convert the number (0-99) to bcd and then extract each didgit from it by using the AND operator.
Let NUMBER be the number to be displayed and
NUMBER_BCD the BCD version of it
Use var1=BCD_NUMBER AND &B00001111 for the first digit and
use var2=BCD_NUMBER AND &B11110000 for the second digit. Remember to shift var2 four places to the right before sending it to the max7219
Here is an extract of my code that works:
Dim Dis as integer
Dis = Makebcd(dis)
Dig_val1 = Dis And &B00001111 : W = Makeint(dig_val1 , 1) : Call Show(w) ' Data for digit 1 and send to max7219
Dig_val2 = Dis And &B11110000 : Shift Dig_val2 , Right , 4: W = Makeint(dig_val2 , 2): Call Show(w) ' Data for Digit 2 and send to nax7219
Sub Show(var As Word) ' send data to max7219
Data_out = Var
Reset Cs
For N = 1 To 16
Reset Clk
Y = Data_out And &H8000
Shift Data_out , Left , 1
If Y = &H8000 Then
Set Dout
Else
Reset Dout
Set Clk
Set Cs
End Sub
Good luck
Twenty
PostPosted: Sat Jan 29, 2005 10:43 am    Post subject: Reply with quote
sorry,
my program doesnt use 1 wire communication but the old but cheap 4511 drivers
JP
Xeus
PostPosted: Sun Jan 30, 2005 6:54 pm    Post subject: Reply with quote
Thank you
i'm will try it
Xeus
PostPosted: Sun Jan 30, 2005 6:55 pm    Post subject: Reply with quote
Sorry for the mistakes!!!
