DC Motor control
Post new topic   Reply to topic    www.mcselec.com Forum Index -> Robotics
stadham
PostPosted: Thu Jul 27, 2006 2:39 am    Post subject: DC Motor control Reply with quote
am trying to control the speed of 2 dc motors on my robot. I am using an Atmega 168 and 2 L9110 h-bridges to drive them. I know that I can use timer1 for PWM but the problem is the pins that control the motors are connected to pd4 pin, pd5 pin, pd6 pin, pd7 pin. So how do I get PWM to work on pd5 pin and pd6 pin. I know that those pins can be changed to timer0. But I don’t know how to do that in Bascom nor do I know how to set timer0 to PWM.
Have I got any of that right??
Any advice would be more than welcome.
Thanks,
Randy
DJD XTREEM
PostPosted: Tue Nov 07, 2006 1:03 pm    Post subject: Reply with quote
Well you could use something like this:
Config Timer1 = Timer , Prescale = 64
On Timer1 Myisr                                             'Op interrupt ga naar myisr
Enable Timer1
start Timer1
Myisr:
set portd.x
Waitms 10
reset portd.x
It's pretty dirty.. But it could give you a head start.. You have to look in the help files for further help to get this to fit you application..
This is a bit of code in a huge programm that generated a 0.5 seconds interrupt. By using a counter it counted till a few minutes and then released a relay. But in the meanwhile it had to check constant if there where no IR instructions.. So working on interupts helped me out..
Bascom AVR 1.11.8.8 full version
STK500 Programmer
ISP Programmer
Post new topic   Reply to topic    www.mcselec.com Forum Index -> Robotics All times are GMT + 1 Hour
