pminmo
Joined: 02 Dec 2004 Posts: 8 Location: St. Louis Missouri, USA
Posted: Thu Dec 02, 2004 11:58 pm Post subject: AVR ISP and Wizzard Problems |
I finnaly got around to trying my Atmel AVRISP programmer (about a year old). It works with AVR Studio 4, but I can't seem to get it running with Bascom. Up to now I've been using a Futurlec bitbanger with win98. My Bascom Version is 1.11.7.3. I got the AVRISP to go completely to WinXP and get away from the parallel port. I selected AVR ISP for the programmer setup, is this the wrong programmer setting?
2nd problem, I downloaded the update wizzard, it gives me a "no product found" window. It's a legit version I bought from Dontronics. The license file is in the same directory as the wizzard. What am I missing?
Thanks |
Frankeman
Posted: Fri Dec 03, 2004 9:27 pm Post subject: |
What do you mean with the licence file?
This is not the file you get with Bascom to activate it.
It is a .lic file you get after registering your Bascom.
Take a look at http://www.mcselec.com/forum/viewtopic.php?t=189 for more information.
Frank. |
pminmo
Posted: Sat Dec 04, 2004 12:00 am Post subject: |
Ok I'm confused. I bought it in Jan 03 from Dontronics, a dll file came with the instructions that had to be installed in the same directory as the setup file. In rereading the instructions for installation, it refers to this dll, but doesn't say anything else about a license file. There is nothing in BASCOM help about registering. I can't remember of any issues since the purchase, it runs ok and I build over 2K of code. So I assume I did everything correctly. What am I missing?
Phil
p.s. There are several .lic files on my computer. Two of which are under a directory DRM, but I can't say the dates correspond. But one interesting correlation is one of them is dated exaxtly one year earlier than the email from Dontroincs, I suppose I could have had the wrong year in. |
Frankeman
Posted: Sat Dec 04, 2004 12:13 am Post subject: |
Hi Phil,
What you are missing is the AutoUpdate Wizzard.
This program is developed later in time than the compiler so there is no info about it in the helpfile.
Go to http://www.mcselec.com/register.htm and register yourself.
You will receive (if all is OK) a licence file by email wich you must put in the same directory as the wizzard.
Run the wizzard and your Bascom AVR wil be updated.
Frank. |
pminmo
Posted: Sat Dec 04, 2004 12:45 am Post subject: |
I did do that the same night as my first post above, I haven't received any info from MCS?
Phil
p.s. I'm not really immediately concerned about the latest version, I'd really like to get my AVRISP working with BASCOM. |
pminmo
Posted: Sat Dec 04, 2004 2:09 am Post subject: |
Ok I got the AVRISP to work. Needed to select the STK500 extended.
Now just need to figure out the upgrade issues.
Phil |
sonero
Posted: Sat Dec 04, 2004 4:19 am Post subject: |
Just wait a bit, it takes some time until you get the mail with the .lic file from Mark.
But be aware, that the latest release is 1.11.7.4, the newest 1.11.7.6 is still beta.
Norbert |
Posted: Mon Dec 06, 2004 10:23 pm Post subject: |
Yes, as the registration entries are partial manual processed, it can take up to a week. _________________ Mark |
pminmo
Posted: Wed Dec 08, 2004 5:16 am Post subject: |
Got the lic file, ISPAVR is working. Was able to upgrade to the Beta version.
Thanks,
Phil |
butsch
Posted: Tue Dec 28, 2004 5:55 pm Post subject: BASCOMAVR 1.11.7.3 and AVRISP |
following problem in BASCOM: choose OPTIONS->PROGRAMMER, in PROGRAMMER TAB select AVR ISP Programmer. When select F4 to send compiled program to chip i see in the title bar of programmer window: "AVR ICP910 programmer", in fact no programming is working.
What is wrong ? ... AvrStudio 4 ist also installed... |
sonero
Posted: Tue Dec 28, 2004 6:02 pm Post subject: |
Are you using the 910 programmer?
Which hardware are you using for programming?
Norbert |
butsch
Posted: Tue Dec 28, 2004 6:09 pm Post subject: |
no there is no 910 programmer installed, i have only installed Atmel AVRISP via COM3. AVRISP works with AvrStudio 4 perfectly.
kindly
stephan |
Posted: Tue Dec 28, 2004 6:10 pm Post subject: |
HI
did you install a printer in the option/programmer/parallel/lpt adress ?
it is necessary for the STK200/300 and others ISP programmers
butsch
Posted: Tue Dec 28, 2004 6:17 pm Post subject: |
BASCOM: i see in programmer option, parallel lpt adress the value 378. But i can not change it. On pc parallel port is a GALEP-4 programmer installed.
kindly
stephan |
sonero
Posted: Tue Dec 28, 2004 7:02 pm Post subject: |
Forget the printer and the parallel thing. You are using a programmer connected to the serial port.
I'm not sure but I think your AVRISP is the programmer I meant with 910. It's based on the Appnote 910 from Atmel.
Norbert |
