ADC value to voltage
hobby
PostPosted: Mon Dec 27, 2004 7:07 pm    Post subject: ADC value to voltage Reply with quote
I try to using the ADC on Mega32.
I read without problem the data form adc, but why converting the value (0-1024 10bit) to the voltage ?
Thanks
Olivier
Thanks
Olivier
PostPosted: Mon Dec 27, 2004 7:25 pm    Post subject: Reply with quote
Hi olivier,
ADC converter give you an digital view of a voltage :
take care you have to remenber Ux must be lower than AVCC
you have 1024 points of mesures for AVCC (5volts ? if you does'nt use AREF)
you want to mesure 3V
3/5 =X/1024
a nice alternative is to use the analog compare interrupts AIN0 and AIN1
I hope it is the answers to your question
JP
hobby
PostPosted: Mon Dec 27, 2004 8:02 pm    Post subject: Reply with quote
Hi JP,
It's not clear for me, sorry.
I use STK500 whit VTARGET 5.0 and AREF 5.0V.
I connect small pot to +5v and GND (AVR Power suply) and the center to ADC pin.
Wat the 'formule' for converting ?
Thanks
Olivier
Thanks
Olivier
PostPosted: Mon Dec 27, 2004 9:50 pm    Post subject: Reply with quote
well
Dim W As Word, value as single
'now read A/D value from channel 0
W = Getadc(channel)
'W give you a value of 0 for 0V and 1024 for 5V
'example
W=128
value=5/1024
value=value x w 'value=0.625 volts
'Value must be a single to have flotting point
JP
hobby
PostPosted: Mon Dec 27, 2004 11:10 pm    Post subject: Reply with quote
Many Thanks JP.
I have understood.
Now i test with ATMEGA 8L in 3.3V.
Thanks
Olivier
Thanks
Olivier
