serial <-> PC
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive
achzoll
PostPosted: Wed Jun 21, 2006 8:32 pm    Post subject: serial <-> PC Reply with quote
hallo zusammen
bin neu und denke darüber wurde schon geschrieben, aber ich brauche eine verbindung zum PC. mit print sende ich einen string aber mit input bleibt der mc stehen daher habe ich inkey benutz aber damit kann ich nur ein byte empfangen. ich würde gerne RI abfragen ob eine neue nachricht angekommen ist und dann diese lesen.
danke im vorraus
my problem is the serial port to the pc. i send a string with print but with input stand the mc. with inkey i can get one string but i want to get about RI the informatio for a new string from pc and then i want to read this string.
thanks for help
Achim
Vilko
PostPosted: Tue Sep 19, 2006 9:09 am    Post subject: I use Serial Interrupt Reply with quote
I use serial interrupt routine to accept info from Serial.
The serial interrupt routine gets control for each byte if info and puts into RAM, it might detect Newline charater and set a bit, when transmition is over, main program tests the bit and if set evaluate received information.
I am not very good at bascom, it might be a competent bascom statement to do the work instead.
Funci
PostPosted: Tue Sep 19, 2006 4:35 pm    Post subject: Reply with quote
Hi achzoll,
I am thinking that you don't have problems, because commands that you were used working just like you said.
So, if you want to use Inkey statement you must write routine that will wait for strings that are comming and analyse them.
Vilko
PostPosted: Tue Sep 19, 2006 4:54 pm    Post subject: bascom help says Reply with quote
Bascom help says about Inkey:
Returns the ASCII value of the first character in the serial input buffer.
var = INKEY()
var = INKEY(#channel)
Var Byte, Integer, Word, Long or String variable.
Channel The channel number of device
If there is no character waiting, a zero will be returned.
So, it says about character, not string. You must intercept each byte of a string separately.
(I my be wrong.)
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive All times are GMT + 1 Hour
