Posted: Thu May 25, 2006 3:45 am Post subject: Comparing port bit
I'm trying to compare the polarity of a port pin and the bascic does'nt allow me to do it. I want th check if the port pin status as change
Dim Gear_previous As Bit
Gear_in Alias P0.4
gear_previous = gear_in
set gear_in
call gear_check()
Sub Gear_check
If Gear_in <> Gear_previous
Then
Waitms 25
If Gear_in <> Gear_previous Then
Gear_previous = Gear_in
Call Position_
Bascom give me an error on this line : If Gear_in <> Gear_previous
Joined: 25 May 2004 Posts: 190 Location: Ljubljana, Slovenia
Posted: Tue Sep 19, 2006 9:18 am Post subject: My answer might be not correct, but
When compare is made and one of arguments in portpin you need to take in consideration this:
I think, that bascom does not read port in if statement. I think, that bascom supposes that the value of Px.y is that, last used when portpin was writen.
The best way to verify my opinion is to try. I am not able to do this now, because of my hardware is down.
Try this way:
Write to port:
P1 = 255
then push some bit of port1 down with a switch connected between pin and ground then
if P1 = 255 then
print "Vilko is right "
else
print "Vilko is wrong"
endif
