Posted: Thu Aug 31, 2006 3:52 pm Post subject: timer2 Capture calculation
Hello
I want to use the timer2 as a time base for my system. I need an interrupt every 50 milisecond. What will be the capture value if i use a 10 mhz crystal
Dim capture as Integer
Capture = XXXXX
Config Timer2 , = Timer , Gate = Internal , Mode = 0 , Direction = Down
On Timer2 Timer2_int
Load Timer2 , capture ' Interrupt arrive lorsque capture= 0
Enable Timer2
