kimmi
Posted: Mon Aug 07, 2006 10:02 pm Post subject: How to split string |
Hi all ...
Working on the last part on my GPS Tracker and need help
Now I cant see how to get a largs string split up using (,) as split
here is my string
Code: | GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45 |
the len betwin to (,) can variat from 0 to 6 chr
in vb it is easy just use Split have read the help finl but don´t get it in to my littel head ( sorry)
need to split it in 15 parts here is smal info about parts
NMEA 0183 Datensätze
GGA - Global Positioning System Fix Data, Time, Position and fix related data fora GPS receiver.
11
1 2 3 4 5 6 7 8 9 10 | 12 13 14 15
$--GGA,hhmmss.ss,llll.ll,a,yyyyy.yy,a,x,xx,x.x,x.x,M,x.x,M,x.x,xxxx*hh<CR><LF>
Field Number:
1) Universal Time Coordinated (UTC)
2) Latitude
3) N or S (North or South)
4) Longitude
5) E or W (East or West)
6) GPS Quality Indicator,
0 - fix not available,
1 - GPS fix,
2 - Differential GPS fix
7) Number of satellites in view, 00 - 12
Horizontal Dilution of precision
9) Antenna Altitude above/below mean-sea-level (geoid)
10) Units of antenna altitude, meters
11) Geoidal separation, the difference between the WGS-84 earth
ellipsoid and mean-sea-level (geoid), "-" means mean-sea-level
below ellipsoid
12) Units of geoidal separation, meters
13) Age of differential GPS data, time in seconds since last SC104
type 1 or 9 update, null field when DGPS is not used
14) Differential reference station ID, 0000-1023
15) Checksum
is it posibel ?
 _________________ / Kim |
ATIU
Posted: Mon Aug 07, 2006 11:14 pm Post subject: |
These are fix lenght, use MID function and Val to get the value from string. |
Luciano
Posted: Mon Aug 07, 2006 11:41 pm Post subject: |
EDIT:
I have removed my code with INSTR and MID.
See next post from Josef which is exactly what you need.
By the way, I just realized that Bascom has also similar function which is SPLIT.
Below is a sample using it.
Best regards,
Luciano
SPLIT sample:
Code: |
Dim Gps_data as string * 100
Dim My_Array(20) As String * 15
Dim Bcount As Byte
Dim I As Byte
gps_data = "GPGGA,191410,4735.5634,,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45"
Print gps_data
Print "======================================="
Bcount = Split(gps_data , My_Array(1) , ",")
For I = 1 To Bcount
print My_Array(I)
End |
The output:
Code: | GPGGA,191410,4735.5634,,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45
GPGGA
191410
4735.5634
00739.3538
E
1
04
4.4
351.5
M
48.0
M
*45
oe9vfj
Joined: 17 Jun 2004 Posts: 269 Location: Austria, Hard
Posted: Tue Aug 08, 2006 12:41 pm Post subject: |
As I am going to play with GPS in near future, I thought about a function to separate token from such a string.
I wrote a function for that reason and put it in a Library.
You can use it this way:
Code: | Declare Function GetToken (strInput as String, byval bSeparator as Byte, byval bCount as Byte ) as String
$LIB "GetToken.Lib"
$EXTERNAL GetToken
Dim str1 as String * 100
Dim str2 as String * 20
Dim StrSep as Byte
strSep = asc(",")
Dim i As byte
str1 = "GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45"
for i = 1 to 20
str2 = Gettoken(str1, strSep, i)
print ">" ; str2 ; "<"
next
end |
The output of the example will look like this:
Quote: | >GPGGA<
>191410<
>4735.5634<
>N<
>00739.3538<
>E<
>1<
>04<
>4.4<
>351.5<
>M<
>48.0<
>M<
>*45<
> and < are used in the output to show empty strings too.
In simple way, if you want the seventh token from a string (separeted by , ) you can use:
Code: | str2 = GetToken(str1,44 ,7) ' 44 is ASCII-Value of comma (,) |
Copy the file GetToken.Lib to your Lib-Path of BASCOM-AVR
I hope you can use it. _________________ regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel |
Luciano
Posted: Wed Aug 09, 2006 11:46 am Post subject: |
Code: |
' Luciano 8/9/2006
' (See first the LIB posted by Josef in this thread).
' With this code I have tried to replicate in Basic what the LIB
' posted by Josef does. The function in the LIB is written
' in assembly so it is much faster than the code below.
' When I have more time I will compare the speed of the
' two solutions and post the results.(Just a call without PRINT).
' The function Get_Token_X
' - The input string is passed by reference.
' - The separator character and the token number are passed by value so that
' the separator character can be a string constant "," or a string variable.
' Same for the token number which can be a constant or a byte variable.
' (The sample code below uses both).
$regfile = "M128def.dat"
$crystal = 16000000
$hwstack = 40
$swstack = 40
$framesize = 32
$baud = 9600
Declare Function Get_Token_X(Input_String As String , Byval Separator_Chr As String , Byval Token_Nr As Byte) As String
Dim Gps_Data As String * 80
Dim My_Field As String * 15
Dim Chr_Sep As String * 1
Dim I As Byte
Gps_Data = "GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45"
Print "Input string: " ; Gps_Data
Print ""
Print " Get tokens 1 to 20 "
Print ""
For I = 1 To 20
My_Field = Get_Token_X(Gps_Data , "," , I)
Print "Token #" ; I ; ": >" ; My_Field ; "<"
Print " Get tokens random"
Print ""
Chr_sep = ","
My_Field = Get_Token_X(Gps_Data , "," , 1)
Print "Token #1: >" ; My_Field ; "<"
My_Field = Get_Token_X(Gps_Data , Chr_Sep , 3)
Print "Token #3: >" ; My_Field ; "<"
My_Field = Get_Token_X(Gps_Data , Chr_Sep , 14)
Print "Token #14: >" ; My_Field ; "<"
My_Field = Get_Token_X(Gps_Data , Chr_Sep , 15)
Print "Token #15: >" ; My_Field ; "<"
My_Field = Get_Token_X(Gps_Data , Chr_Sep , 16)
Print "Token #16: >" ; My_Field ; "<"
My_Field = Get_Token_X(Gps_Data , Chr_Sep , 17)
Print "Token #17: >" ; My_Field ; "<"
'Token # = 0 is not a valid value. (1-255)
My_Field = Get_Token_X(Gps_Data , "," , 0)
Print "Token #0: >" ; My_Field ; "<"
Function Get_Token_X(Input_String As String , Separator_Chr As String , Token_Nr As Byte) As String
Local Token_Count As Byte
Local String_Pos As Byte
Local Input_String_Length as Byte
Local Current_Chr As String * 1
Input_String_Length = Len(Input_String)
String_Pos = 0
Token_Count = 0
Get_Token_X = ""
Incr String_Pos
Current_Chr = Mid(Input_String , String_Pos , 1)
If Current_Chr = Separator_Chr Then
Incr Token_Count
If Token_Count = Token_Nr Then
Exit Function
Else
Get_Token_X = ""
End if
Else
Get_Token_X = Get_Token_X + Current_Chr
Loop Until String_Pos = Input_String_Length
Incr Token_Count
' If the user asks for more than the tokens present in the string
If Token_Nr > Token_Count Then
Get_Token_X = "Not present"
' Get_Token_X = "" 'use that to return an empty string
' The token # must be 1-255. This will print Error if the user ask token # 0.
If Token_Nr = 0 Then
Get_Token_X = "Error"
End Function
The output:
Code: | Input string: GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45
Get tokens 1 to 20
Token #1: >GPGGA<
Token #2: >191410<
Token #3: >4735.5634<
Token #4: >N<
Token #5: >00739.3538<
Token #6: >E<
Token #7: >1<
Token #8: >04<
Token #9: >4.4<
Token #10: >351.5<
Token #11: >M<
Token #12: >48.0<
Token #13: >M<
Token #14: ><
Token #15: >*45<
Token #16: >Not present<
Token #17: >Not present<
Token #18: >Not present<
Token #19: >Not present<
Token #20: >Not present<
Get tokens random
Token #1: >GPGGA<
Token #14: ><
Token #15: >*45<
Token #0: >Error< |
oe9vfj
Posted: Wed Aug 09, 2006 1:12 pm Post subject: |
Hi Luciano
Here is the Speed Compare (CPU-Cycles) with the above mentioned string.
Token# - Basic / ASM(Lib)
1 - 1707 / 157
8 - 14201 / 419
15 - 26673 / 602
I adapted my routine according to idea of Luciano to check for token# between 1 and 255 and separator ASCII-Value between 1 and 255 (No empty String)
Not matching parameter (Token# = 0 or ASCII-Value of separator character = 0 or empty string) with return an empty string.
You can download new version here.
BTW: You can passing a String(1) to the function for the parameter "Separator Character" with following declaration:
Code: | Declare Function GetToken (strInput as String, byval bSeparator as String, byval bCount as Byte ) as String |
to use it like:
Code: | str2 = GetToken ( str1, ",", 7) |
The first character of the passed string will taken as Separation Character. This increase CPU-Cycles of 63 cycles if the string is passed byval. _________________ regards Josef
oe9vfj
Posted: Wed Aug 09, 2006 2:12 pm Post subject: |
I have just seen, that there is just a function implemented in BASCOM-AVR, which splits such a GPS String into an array.
Check the function SPLIT. _________________ regards Josef
Luciano
Posted: Wed Aug 09, 2006 11:51 pm Post subject: |
Hi Josef,
I am aware of the Bascom function SPLIT. SPLIT works well but
you need a string array with array elements big enough to
hold the largest field present in the input string.
In our case here (GPS) the used RAM would be:
10 bytes * 15 fields = 150 bytes
I have written a new version of my function in Basic.
Your assembly function is still 10x faster.
Best regards,
Luciano
Code: |
' Luciano 8/9/2006
' Get_Token_X
' New version of the function Get_Token_X written in Basic.
' The new version of the function does not use MID and avoids
' the use of strings where possible. The function is 4x faster
' than the previous version when token #15 is retrieved.
' SPEED TEST
' Input string : GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45
' Used call: Get_Token_X(Gps_Data , "," , 15) [See sample below].
' Get Token #1 = 939 CPU-Cycles (Old version 1707 CPU-Cycles)
' Get Token #8 = 3896 CPU-Cycles (Old version 14201 CPU-Cycles)
' Get Token #15 = 6067 CPU-Cycles (Old version 26673 CPU-Cycles)
' The assembly version written by Josef is still 10 times faster.
' Get Token #1 = 157 CPU-Cycles (6x faster than my Basic code)
' Get Token #8 = 417 CPU-Cycles (9.3x faster than my Basic code)
' Get Token #15 = 602 CPU-Cycles (10x faster than my Basic code)
$crystal = 16000000
$hwstack = 40
$swstack = 40
$framesize = 32
$baud = 9600
Dim I As Byte
Print ""
Print ""
For I = 1 To 20
Print ""
Chr_sep = ","
' Token # = 0 is not a valid value. (1-255)
Local String_Pointer As Word
Local Byte_Read As Byte
Local Separator_Byte As Byte
Token_Count = 1
Get_Token_X = ""
Separator_byte = Asc(Separator_Chr)
String_Pointer = Varptr(Input_String)
Byte_Read = Inp(String_Pointer)
Incr String_Pointer
If Byte_Read = Separator_Byte Then
Exit Function
End if
Incr Token_Count
Else
Get_Token_X = Get_Token_X + Chr(Byte_Read)
Loop Until Byte_Read = 0
End Function |
kimmi
Posted: Fri Aug 11, 2006 12:20 am Post subject: |
Hi Luciano & Josef ..
tnx. for the help now i try to make the last part
time is critial have 0.7 sec between update on gsp right now
using a M128 at 16 mhz baud 19200 the ( AVR-MT-128 board from spark )
40*4 lcd
here is the strings i have to handle and split up
date - time line 1 on lcd
latitude - longitude line 2
speed -
save every 1 min in eeprom if (save is enable thu sms) in eeprom to use for sending reply sms
may have to set GPS to update every 2 sec insted of 1 sec
$GPGGA,230439.175,5729.4504,N,00956.3053,E,1,07,2.1,51.8,M,42.1,M,0.0,0000*42
$GPVTG,,T,,M,0.000000,N,0.000000,K*4
again Tnx
Have a nice Weekend
Peter Klein
Posted: Fri Aug 11, 2006 12:40 pm Post subject: |
Hello Joseph,
how do I get the library "GetToken.Lib". I cannot find a link to download it.
Best Regards, Peter |
kimmi
Posted: Fri Aug 11, 2006 12:45 pm Post subject: |
Hi Peter ...
check if your are login
else you cant see the files
