kimmi
Posted: Fri Aug 04, 2006 1:20 am Post subject: Inkey OR Ischarwaiting |
Hello all ...
I am working on a serial prog and got some confligts Mega32
I use Config Serialin = Buffered , Size = 254
and it works fine for B = Inkey()
talking to my gsm phone
but i have a terminal on same port (only 1 serial) i M32
it is calld by set portb.0 =1 relay shift off phone from RX/TX and connect terminal to RX/TX
in terminal mode i use Ischarwaiting()
but here my problems start do to Config Serialin = Buffered , Size = 254 I THINK
is ther away to set Config Serialin = Buffered , Size = 254 off while terminal is in use ?
or what can I do ´
in terminal mode i send (1 char) to navigate in to menu then i use INPUT do to sub menu
can i fix this problem ? or do i have to stop using the ( 1 Char send ) in menu ?
 _________________ / Kim |
DToolan
Posted: Fri Aug 04, 2006 2:39 am Post subject: |
Quote: | I use Config Serialin = Buffered , Size = 254 |
Seems like an awfully large buffer but, OK... as long as it works for you.
Quote: | is there a way to set Config Serialin = Buffered , Size = 254 off while terminal is in use? |
Not easily, No
Quote: | in terminal mode i send (1 char) to navigate in to menu then i use INPUT do to sub menu. Can i fix this problem? or do i have to stop using the ( 1 Char send ) in menu? |
I don't understand what the problem is? Post some of your (1 char send) menu code to further explain.
I am just guessing..., but are you trying to say that your problem is because the INPUT statement waits for a carriage return and line feed before it will move on to the next line of your code? Or maybe your problem is that the INPUT statement echos characters back at the terminal? |
kimmi
Posted: Fri Aug 04, 2006 11:18 am Post subject: |
hi DToolan ...
my problem is only i dont get terminal send char into case select if cerialin=buffered
here is a snip of code :
Code: | Config Serialin = Buffered , Size = 169
'the main program for phone ect
'.this is just for this test
If Portb.0 = 1 Then Call Ee_menue
Sub Setup_ee()
Lcd " Wait setup running"
Call Ee_menue
A = 0
Smsc = ""
Print
Print "Enter command 0 = exit > : "
A = Ischarwaiting()
If A = 1 Then
Getcr Agr 'filter out Cr Lf
Clearbuf '´(emty buffer and get string if not emty for gsm )
Waitms 200
Select Case Smsc 'smsc is serialin from buffer
Case "?" : Call Ee_menue
Case "S" : Call Ee_status
Case "#" : Call Ee_erase
Case "P" : Call Pass_set
Case "A" : Call Gsma_set
Case "1" : Call Gsm_user_set
Case "2" : Call Gsm_port_out_set
Case "4" : Call Port_sms_text_set
Case "3" : Call Gsm_port_in_set
Case "5" : Call Smstxt_comm
Case "6" : Call Call_ee
Case "7" : Call Gps_tcp_setup
Case "8" : Call Heat_unit_stoker
Case "9" : Call 112_call
Case "!" : Call Reset_ee
Case "0" : Print
Goto Stuu
Case Else :
Print "COMMAND ERROR ! "
Print : Print "Enter command > : "
Print
Ss = ""
Waitms 200
Ss = ""
Print ""
'YOU SEND (@) THEN IT RETURN TO NORMAL EXIT EEPROM UPDATE
'IF
Loop '
Print "END SETUP >"
Print
Waitms 2000
Goto Main_sms_con
'SEND TO VB TO SEE IT EXIT OK
'** Return to MAIN Program Loop
Sub Ee_menue
Menuu:
Print
Print " FT-SMS 27 Eeprom setup "
Print " ---------------------------------------------------"
Print ""
Print " ? - Help"
Print " P = Enter Password for SMS access"
Print " A = Enter gsm Admin number"
Print " 1 = Enter User 1 - 5 number"
Print " 2 = Setup output ports"
Print " 3 = Setup port in aktiv on/off"
Print " 4 = Enter port text for sms "
Print " 5 = Test SMS in Emulator "
Print " 6 = Setup for Calls and SMS "
Print " 7 = GPS "
Print " 8 = Stoker"
Print " 9 = Setup for 112"
Print " 0 = Set SMS Alert"
Print " ! = RESET ATMEL "
Print " # = Erase Eeprom "
Print " S = See Eeprom setup status"
Print " 0 = EXIT SETUP"
Print "-------------------------------------------------------"
Print
'Input "Enter command + <Enter> : " , Ss
Sub Getcr(s As String)
S = ""
B = Inkey()
Select Case B
Case 0
Case 13
Case 10 : If S <> "" Then Exit Do
Case Else
S = S + Chr(b)
Loop Until B = 0
Smsc = S
Waitms 50
Sub Clearbuf()
Kk = ""
Waitms 250
B = Inkey()
Kk = Kk + Chr(b)
Loop Until B = 0
Waitms 150
kimmi
Posted: Fri Aug 04, 2006 11:25 am Post subject: |
Can i solve this problem if i creates software UART’s for terminal use
have never try´d this software UART’s and help for this is small in bascom ther thay use portc in exsample _________________ / Kim |
DToolan
Posted: Sat Aug 05, 2006 2:19 pm Post subject: |
kimmi... in your example posting, you left something out that's kind of important or you'll get no terminal send chars...
Enable Interrupts '<- buffered serial requires this line
'... etc
Loop |
If you have that in your real code but left it out of your post, then I'll keep looking. |
kimmi
Posted: Sat Aug 05, 2006 7:43 pm Post subject: |
Hi DToolan ...
tnx ..
Have fix the problem
the do loop in new sms i did not exit thats way it did not work
