Saturday, 12 July 2025
AN #120 - Sony IR receiver using the SIRCS protocol Print
This application note was submitted by Alex Shepherd
This AN shows a good usage of the input capture function of the timer. You can use the AN to decode other formats as well.
Download source code
' AVR Sony SIRCS IR Remote Decoder
' Copyright (c) 2002 Alex Shepherd email: ashepherd@wave.co.nz
' Here is a alternative to AN20 to decode the output of SONY IR Remote that uses
' the SIRCS Protocol and decodes 12, 15 and 20 bit codes
' It uses a 3 pin integrated demodulator/decoder IR Decoder device called
' an IS1U621 see http://www.e-technik.fh-kiel.de/~dispert/robots/is1u621.pdf
' but there are a number of similar devices.
' This program works by connecting the Data output from the IS1U621 to the ICP
' Pin of the AVR and then uses the Capture1 interrupt to measure the time
' between each bit to know if it is a 1 or a 0 and then uses Compare1a interrupt
' to detect that there has not been a bit toggle for several bit times to
' detect the end of the packet.
' I ran the code on a AT90S8535 @ 8MHz and also a ATMega8 @ 10MHz, however
' the timings below are for the AT90S8535 @ 8MHz
' If you need to change the XTAL frequency then look down at line: 126 and
' uncomment the Print line there so that it prints out the clock counts per data
' line toggle so you get an idea of the count distributions.
' Then alter the count thresholds on lines 47 and 48 so that you detect the
' initial start bit which is longer than the rest and then observe the time
' differences between the other bits and pick a number between the average of
' the 1 or 0 count averages.
' I got a startbit of about 450 counts, a 1 bit of about 55 counts and a 0 bit
' of about 37 counts so I chose 200 and 46 for the two thresholds
' Your mileage may vary...
Config Timer1 = Timer , Prescale = 256 , Capture Edge = Rising , Compare A No_output = Disconnect
Config Serialout = Buffered , Size = 150
On Capture1 Capture1_int
On Compare1a Compare1a_int
Dim Ready As Byte
Dim Address As Word
Dim Code As Word
Dim Startbitperiod As Byte
Dim Normalbitperiod As Byte
' If you change the XTAL frequency then you will need to alter these 3 values
Startbitperiod
= 200
Normalbitperiod
= 45
' Set the Compare threshold to detect end of packet after 4 bit times of no activity
Compare1a = Normalbitperiod * 4
Enable Interrupts
Enable Capture1
Enable Compare1a
Cls
Lcd "Sony IR Receiver"
If Ready <> 0 Then
 Ready
= 0
Lowerline
Lcd "Address: " ; Address ; " Code: " ; Code ; " "
End If
Dim Period As Word
Dim Command As Long
Dim Bitcount As Byte
Dim Shiftcount As Byte
Compare1a_int
' Uncomment the line below to see the bit patterns to debug new
' command sizes not allowed for in the code
' Print "B " ; Bitcount ; " C " ; Bin(command)
 Ready
= 1
If Bitcount = 12 Or Bitcount = 15 Or Bitcount = 20 Then
 Shiftcount
= 31 - Bitcount
Shift Command , Right , Shiftcount
Else
 Ready
= 0
End If
 Code
= Command And &H0000007F
Shift Command , Right , 7
 Address
= Command
 Bitcount
= 0
Capture1_int
Timer1 = 0
 Period
= Capture1
If Period >= Startbitperiod Then
 Command
= 0
 Bitcount
= 0
Else
If Period > Normalbitperiod Then
 Command
= Command Or &H80000000
End If
Incr Bitcount
End If
' Uncomment this line to print out the bit times see how to tweak the
' Period thresholds if you change the XTAL frequency
' Print "P " ; Period ; " B " ; Bitcount
