Wednesday, 09 July 2025
AN #116 - Reading the SHT11 Humidity sensor Print
This application note was submitted by Stuart Leslie. I am very pleased with it since I tried to get the SHT11 working too but failed. After a few days I gave up on it and was ready to test it with a 8051 chip. The SHT11 does not follow the I2C specifications. Good for us that Stuart was so clever to use the SHIFT routines.
The SHT11 is a very good dual sensor, it is a temperature and humidity sensor. It is cheap when you consider the performance and there are free samples available from Sensirion.
You can download the sample BASCOM-AVR file.
It is also shown below.
'Routine to read the SHT11 Humidity sensor chip
'By Stuart Leslie
'Contact stu@4sightinc.com with any questions
'Uses BascomAVR
'a .01 uf capacitor across VCC and Ground on the SHT11 really cleans up the data
'a pullup is required on "data" pin as shown in the data sheet
Dim Ctr As Byte
Dim Dataword As Word
Dim Command As Byte
Dim Dis As String * 20
Dim Calc As Single
Dim Calc2 As Single
Dim Rhlinear As Single
Dim Rhlintemp As Single
Dim Tempc As Single
Dim Tempf As Single
Const C1 = -4
Const C2 = 0.0405
Const C3 = -0.0000028
Const T1c = .01
Const T2 = .00008
Const T1f = .018
Sck
Alias Portb.0
Dataout
Alias Portb.1
Datain
Alias Pinb.1
Redled
Alias Portb.2
Declare Sub Getit()
Ddrb = &B11111111  'all port b are output
Config Pinb.0 = Output 'sck
Config Pinb.1 = Output 'datain
'reset the serial communications first, it is easily confused!
Set Dataout
For Ctr = 1 To 12
Set Sck
Waitus 2
Reset Sck
Waitus 2
Next Ctr
Do 'continually read the tempfature and humidity
 Command
= &B00000011
Call Getit 'Get the temperature, puts result in "dataword" for us
 Tempf
= T1f * Dataword
 Tempf
= Tempf - 40
 Tempc
= T1c * Dataword 'get celcius for later calculations and for "the rest of the world"
 Tempc
= Tempc - 40
 Dis
= Fusing(tempf , "###.##")
Print "Temperature = " ; Dis ; " (F)"
 Command
= &B00000101
Call Getit 'get the humidity
 Calc
= C2 * Dataword
 Calc2
= Dataword * Dataword 'that "2" in the datasheet sure looked like a footnote for a couple days, nope it means "squared"!
 Calc2
= C3 * Calc2
 Calc
= Calc + C1
 Rhlinear
= Calc + Calc2
'Dis = Fusing(rhlinear , "##.##")
'Print "Humidity adjusted for linear = " ; Dis
 Calc
= T2 * Dataword
 Calc
= Calc + T1c
 Calc2
= Tempc - 25
 Calc
= Calc2 * Calc
 Rhlintemp
= Calc + Rhlinear
 Dis
= Fusing(rhlintemp , "##.##")
Print "Humidity adjusted for temperature = " ; Dis
Print
Wait 1
Sub Getit()
Local Datavalue As Word
Local Databyte As Byte
'start with "transmission start"
Set Sck
Reset Dataout
Reset Sck
Set Sck
Set Dataout
Reset Sck
'now send the command
Shiftout Dataout , Sck , Command , 1
Ddrb = &B11111101 'datain is now input
Config Pinb.1 = Input 'datain
Set Sck 'click one more off
Reset Sck
Waitus 10 'no idea why, but it doesn't work without it!
Bitwait Pinb.1 , Reset 'wait for the chip to have data ready
Shiftin Datain , Sck , Databyte , 1 'get the MSB
 Datavalue
= Databyte
Ddrb = &B11111111
Reset Dataout 'this is the tricky part- Lot's of hair pulling- have to tick the ack!
Set Sck
Reset Sck
Shiftin Datain , Sck , Databyte , 1 'get the LSB
Shift Datavalue , Left , 8
 Datavalue
= Datavalue Or Databyte
'don't tick the clock or ack since we don't need the CRC value, leave it hanging!
 Dataword
= Datavalue
Ddrb = &B11111111
Reset Dataout
Set Sck
Reset Sck
Shiftin Datain , Sck , Databyte , 1 'not using the CRC value for now- can't figure it out! Anybody know how to impliment?
'Print "CRC value was - " ; Databyte
Ddrb = &B11111111
Set Dataout
Set Sck
Reset Sck
End Sub
