Tuesday, 08 July 2025
AN #114 - Getting started in Data Transmission and Error detection with Correction Print
This application note was submitted by Srikanth Kamath. Email panther@vasnet.co.in
All is explained in the program you can download. It is also shown below.
'AN ******************Error detection and correction***************************
' Application Note  *
' Getting started in Data Transmission and Error detection with Correction *
' using BASCOM AVR *
' Encodes 21 -bit Data Word Into 32 -bit Extended Bch 32.21 Word *
' This code is used in the POCSAG protocol specification for pagers. *
' In this specific case, there is no need to use the Berlekamp-Massey *
' algorithm, since the error locator polynomial is of at most degree 2. *
' Instead, we simply solve by hand two simultaneous equations to give *
' the coefficients of the error locator polynomial in the case of two *
' errors. In the case of one error, the location is given by the first  *
' syndrome. *
' This program derivates from the original bch2.c, which was written *
' to simulate the encoding/decoding of primitive binary BCH codes. *
' Part of this program is adapted from a Reed-Solomon encoder/decoder *
' program, 'rs.c', to the binary case. *
' Extended Code Bch 32.21 Correction Using Zeh Functions *
' The Idea And The Original Algorithm Were Proposed By K. Borisov *
' C Source Code(c)vlv *
' Ported to BASCOM AVR by M/S PACTINDIA on 27.04.2002 *
' Written by Srikanth Kamath; e-mail: panther@vasnet.co.in *
' (c) Copyright 2002 Panther Electronics ; www.pactindia.com/bascom.htm *
' COPYRIGHT NOTICE: This program is free for non-commercial purposes. *
' You may implement this program for any non-commercial application. You may *
' also implement this program for commercial purposes, provided that you *
' obtain my written permission. Any modification of this program is covered *
' by this copyright.  *
' The Bch 32.21 Codeword Is Treated As Long Int Data Size is 21 bits *
' The Function Corrects Up To 2 Errors And Detects At Least 3 Errors. *
' The Error Value Is Amount Of Errors(0 , 1 , 2).  *
' If The Error Is Not Correctable , Error Value Is 0xff And The Codeword *
' Is Not Changed. *
' The Encoding part is of size 700byte this should gointo the transmitting uC *
' The Decoding part is of size 1900byte this should gointo the Reciever uC *
' The Test part is the routine that you must change to in the TX uC to encode *
' and similarly the Test part must change in the TR uC to decode *
' BUGS: *
' Fixed on 5.5.2002,  *
' The error are now correctly reported 0,1,2 or 255 * *
' 27.4.2002 The corrected_data is either +1 or -1 at times from actual *
' encodded_data But this does not effect the decode or error correction *
' Also the error no reported is not related to no of error but detected *
' Warranty & Disclaimer: *
' We do not guarantee that this module is free from defects or bug's in normal *
' use/service, and that these module will perform to the current specification *
' in accordance with, and subject to, the company’s standard warranty which *
' is detailed in Panther Electronics Purchase order Acknowledgement. *
' We assumes no responsibility for the use of any circuits / code described in *
' this book / e-book/ manual, nor does the company assumes responsibility for *
' the functioning of undescribed features or parameters. *
' In absence of a written agreement to the contrary, Panther Electronics *
' assumes no liability with respect to the use of semiconductors devices/codes *
' described and used in this module for product design or infringements of *
' patents or copyrights of third parties. *
' These are control modules /codes only and not tested with for full *
' functionality with the controlled units and products. These modules are not *
' authorised for use as critical components or systems and the use as such *
' implies that the user bears all risk of such use. *
' Many Many Thanks to  *
' Mark Albert's, Eric Baron, Udo, Jack Tidwel and all other who have helped *
' Change this to Suit you AVR
$regfile = "8515def.dat"
'$dbg
' Note this code requires HW10, SS32 and FRAME 43
Declare Function Encodebch(datas As Long) As Long
Declare Function Correctbch(encodedbchword As Long) As Long
'***************The test program ***********************************************
' This test is to Show how tHe BCH encoding of 21bit data packet helps in
' error detection and correction of error in asyncrony data transmission
' this BCH encoding and Decoding provides error correction upto 2 error per
' packet of 21bit. Hence the chances of usefull and purpose full transmission
' is garrented
Dim Inputdata As Long
' This is the data to be transmitted
Dim Temp As Byte , Cnt As Byte ' temp variables used
Dim Just_tmp As Long  ' temp variables used
Dim Corrupted_data As Long
' This is the received data
Dim Decoded_data As Long
' this is the decoded data = inputdata
Dim Encoded_data As Long
' this is the corrected data
Dim Result As Byte
' This is the error no
' NOTE: If Result = &HFF the error could not be corrected hence discard the
' Received data
Main
 Inputdata
= 0
' get some random data in
For Cnt = 1 To 2
Shift Inputdata , Left , 8
 Temp
= Rnd(255)
 Inputdata
= Inputdata Xor Temp
'** / / Truncate To 21 Bit
 Inputdata
= Inputdata And &H1FFFFFF
'** / / Encode To Bch 32.21
 Encoded_data
= Encodebch(inputdata)
'/ / Corrupt Data(2 Random Errors)
 Corrupted_data
= Encoded_data
'Corrupted_data is the received transmission data
 Temp
= Rnd(255)
 Temp
= Temp And &H1F
Set Corrupted_data.temp
 Just_tmp
= Corrupted_data
 Temp
= Rnd(255)
 Temp
= Temp And &H1F
Print " Encoded Data with first error " ; Just_tmp ; " with second Second error " ; Corrupted_data
'// Correct Data
'Call Correctbch(corrupted_data)
 Just_tmp
= Correctbch(corrupted_data)
'// Decode Data
Print "Corrupted_data " ; Corrupted_data ; " EncodedWord " ; Encoded_data ; " Corrected_data " ; Just_tmp
 Decoded_data
= Just_tmp
' This is the the required to get back the corrected data
Shift Decoded_data , Right , 11
' Can be shift this to Correctbch itself, but kept it here to check and test
If Result <> &HFF Then
If Inputdata <> Decoded_data Then
Print " Error check this"
Print "---------Srikanth Kamath T___________**********"
Else
Print "Inputdata " ; Inputdata ; " Decode Data " ; Decoded_data ; " No of Error Corrected " ; Result
Print "---------Decode Sucessful___________**********"
End If
Else
Print "---------Decode not possible___________**********" ; " No of Error more than 2: " ; Result
End If
'Goto Main
'***************Function Encoded the 21 bit InputData to 32 bit BCH_word********
' This Function Encoded the 21 bit InputData to 32 bit BCH_word
Local Tmp_enc As Long , Ci As Byte , Ltmp_enc As Long
 Ltmp_enc
= Datas
'/ / Divide By Polynom
For Ci = 0 To 20
Shift Ltmp_enc , Left , 1
 Tmp_enc
= Ltmp_enc And &H200000
If Tmp_enc <> 0 Then
 Ltmp_enc
= Ltmp_enc Xor &H1B4800
End If
'/ / Allign The Remainder
Shift Ltmp_enc , Right , 10
 Ltmp_enc
= Ltmp_enc And &H7FE
' / / Add Data
 Tmp_enc
= Datas
Shift Tmp_enc , Left , 11
 Ltmp_enc
= Ltmp_enc Or Tmp_enc
 Encodebch
= Ltmp_enc
' / / Calculate Parity
 Ci
= 0
While Ltmp_enc <> 0
 Tmp_enc
= Ltmp_enc And 1
'debug
 Ci
= Ci Xor Low(tmp_enc)
' Tmp_enc2 = Tmp_enc2 Xor Tmp_enc
' Ci = Low(tmp_enc2)
Wend
' / / Add Parity
 Encodebch
= Encodebch Or Ci
End Function
'END OF*********Function Encoded the 21 bit InputData to 32 bit BCH_word********
'***************The decoding and error correction start*************************
'*************************Correction Itself*************************************
' Using the zeh function
Declare Function Makesyndrome(x As Long , Byval Polynom As Byte) As Byte
Declare Function Inverbit(bch_word As Long , Byval Bitno As Byte) As Long
Local Sa As Byte , Sb As Byte , Parity As Byte , Dist As Byte , Tmplong As Long , Tmp As Byte , Ltmp As Long
 Ltmp
= Encodedbchword
' / / Calculate Syndromes A And B
 Sa
= Makesyndrome(ltmp , &H05)
 Sb
= Makesyndrome(ltmp , &H1D)
  Parity
= 0
While Ltmp <> 0
 Tmplong
= Ltmp And 1
 Tmp
= Low(tmplong)
 Parity
= Parity Xor Tmp
Shift Ltmp , Right , 1
Wend
' / / Check Syndromes
If Sa = 0 And Sb <> 0 Then
 Result
= &HFF
 Correctbch
= Encodedbchword
Exit Function
End If
If Sb = 0 And Sa <> 0 Then
 Result
= &HFF
 Correctbch
= Encodedbchword
Exit Function
End If
'// If Both Syndromes Are 0(no Code Errors)
If Sa = 0 And Sb = 0 Then
If Parity = 0 Then
'// No Errors
 Result
= 0
 Correctbch
= Encodedbchword
Exit Function
End If
'debug
 Correctbch
= Encodedbchword Xor 1
 Result
= 1
Exit Function
End If
 Sa
= Lookup(sa , Table_sa)
 Sb
= Lookup(sb , Table_sb)
'// If Both Syndromes Are Indicating One Error
If Sa = Sb Then
 Correctbch
= Inverbit(encodedbchword , Sa)
' debug 1
' If(parity! = 0) Return 1 ; / / One Error
'Tmp = 0
'If Parity = 0 Then
' Set Tmp.0
'Else
' Reset Tmp.0
'End If
'--- debug 1
If Parity <> 0 Then
 Result
= 1
Exit Function
End If
' debug 1
 Correctbch
= Correctbch Xor 1
 Result
= 2
Exit Function
End If
'// More Then Two Errors - Not Correctable
If Parity <> 0 Then
 Result
= &HFF
 Correctbch
= Encodedbchword
Exit Function
End If
 Dist
= Sa - Sb
'// Modulo 1f
 Tmp
= Dist And &H80
If Tmp <> 0 Then
 Dist
= Dist + &H1F
End If
'// Find Distance Between Errors
 Dist
= Lookup(dist , Table_dist)
'// Not Correctable
If Dist = &HFF Then
 Result
= &HFF
 Correctbch
= Encodedbchword
Exit Function
End If
'// Correct 1 -st Error Location
 Tmp
= Lookup(dist , Dist_correction_table)
 Sa
= Sa - Tmp
'// Modulo 31
 Tmp
= Sa And &H80
If Tmp <> 0 Then
 Sa
= Sa + &H1F
End If
'/ / Correct 1 -st Error
 Tmp
= Sa + 1
 Correctbch
= Inverbit(encodedbchword , Tmp)
'// Find 2 -nd Error Location
 Sa
= Sa + Dist
'// Modulo 31
If Sa >= 31 Then
 Sa
= Sa - 31
End If
'//Correct 2 -nd Error
 Tmp
= Sa + 1
 Correctbch
= Inverbit(correctbch , Tmp)
 Result
= 2
End Function
'END OF*******************Correction Itself*************************************
'************************Divide By Polynom**************************************
'Sub Makesyndrome(x As Long , Byval Polynom As Byte)
Local Tmp_syn As Long , Cntr As Byte , L_polynom As Long , Tmp_syn2 As Long
 Tmp_syn
= X And &HFFFFFFFE
 L_polynom
= Polynom
Shift L_polynom , Left , 27
' / / Calculate The Syndrome
For Cntr = 0 To 30
 Tmp_syn2
= Tmp_syn And &H80000000
If Tmp_syn2 <> 0 Then
Shift Tmp_syn , Left , 1
 Tmp_syn
= Tmp_syn Xor L_polynom
Else
End If
Shift Tmp_syn , Right , 27
 Makesyndrome
= Tmp_syn
End Function
'END OF******************Divide By Polynom**************************************
'***************Invert Bit At The Position Bitno********************************
'Sub Inverbit(bch_word As Long , Byval Bitno)
Local Tmp_inver As Long
 Tmp_inver
= 0
Set Tmp_inver.bitno
 Inverbit
= Bch_word Xor Tmp_inver
End Function
'END OF*********Invert Bit At The Position Bitno********************************
'****************Syndrome A Error Position Table********************************
Table_sa
Data &H00 , &H1B , &H1C , &H0E , &H1D , &H01 , &H0F , &H07,
Data &H1E , &H19 , &H02 , &H17 , &H10 , &H04 , &H08 , &H13,
Data &H1F , &H06 , &H1A , &H0D , &H03 , &H12 , &H18 , &H16,
Data &H11 , &H15 , &H05 , &H0C , &H09 , &H0A , &H14 , &H0B
Table_sb
Data &H00 , &H1B , &H1C , &H10 , &H1D , &H05 , &H11 , &H02,
Data &H1E , &H16 , &H06 , &H0C , &H12 , &H14 , &H03 , &H19,
Data &H1F , &H0E , &H17 , &H0A , &H07 , &H08 , &H0D , &H09,
Data &H13 , &H18 , &H15 , &H0B , &H04 , &H01 , &H1A , &H0F
Table_dist
Data &HFF , &HFF , &HFF , &H03 , &HFF , &HFF , &H06 , &H0B,
Data &HFF , &HFF , &HFF , &HFF , &H0C , &HFF , &H09 , &H08,
Data &HFF , &H0E , &HFF , &H0A , &HFF , &HFF , &HFF , &H04,
Data &H07 , &H05 , &HFF , &H02 , &H0D , &H01 , &H0F , &HFF
Data &HFF , &H13 , &H06 , &H1E , &H0B , &H03 , &H1C , &H17,
Data &H15 , &H11 , &H05 , &H14 , &H18 , &H0F , &H0E , &H19
