PID Controller
This application note is written by Mike Eitel.
Download file in .ZIP
' -----[ Program Description
' This program implements an PID algorithm in BASCOM
' This File is partialy based on a program from ?????? and
' I do not intent to touch any of his rights !!!
' So for correct use of his copyrights please inform as
marked below!
' -----[ Disclaimer
' This example is offered on an "AS IS" basis,
no warranty expressed or implied.
' The programers disclaim liability of any damages
associated with the use of
' the hardware or software described herein. You use it on
your own risk.
' I'm not able to provide any free support.
' Copyright (c) 2001 Mike Eitel all rights reserved
' -----[ Revision History
' 060529 - Version AVRPID Ver .95 Basic PID functionality Mike Eitel
' -----[ Aliases ]--------------------------------------------------------------
$sim ' Helps testing in a simulation
' -----[ Constant
' -----[ Variables
Dim Auto_mode As Bit ' Regulator on ?
Dim Manual_value As Single ' Output if not regulating
Dim Sp As Single ' Setpoint
Dim Pv As Single ' Process Value
Dim Cv As Single ' PID output
Dim First_execution As Byte ' First start recognition
Dim Initial_error As Single ' Startup difference
Dim A As Byte ' Tmp for random
Dim B As Single ' Tmp for random
' -----[ Start of program
' -----[ Start of program ]-----------------------------------------------------
Auto_mode = 1 ' Permanent running choosen
First_execution = 0 ' Set permanent running algorithm
Manual_value = 40 ' Output if not regulating = on
Sp = 37 ' Value to aim to
Cyclic:
' -----[ Start of endless running program
Waitms 50 ' PID must run deterministic
' time slices
Gosub Regulator ' Call the PID allgorithm
Gosub Object ' Call the simulated outer loop
Goto Cyclic
' -----[ End of
endless running program ]------------------------------------
' -----[ End of
' -----[ End of
-----------------------------[ Subroutines ]-------------------------------
Object:
' -----[ Start of
simulated regulation loop ]--------------------------------
Pv = Pv + Cv ' linear function used
If Pv = Sp Then ' When PV=SP then make a
A = Rnd(100) ' random SP jump
Sp = 1 * A
Regulator:
' -----[ Start of
PID Regulator]---------------------------------------------
' -----[ Constant
Const Kp = .85 ' Proportional factor
Const Ki = .67 ' Integration factor
Const Kd = .15 ' Derivation factor
Variables ]---------------------------------------------------------
'Dim Sp As
Single '
Setpoint
'Dim Pv As
Single '
Process Value
'Dim Cv As
Single '
PID output
'Dim
'Dim
Dim Last_pv As Single ' Last PV
Dim Last_sp As Single ' Last SP
Dim Sum_error As Single ' Summed error value
Dim D_pv As Single ' Derrivated delta PV
Dim Error As Single ' Difference between SP and PV
Dim Pterm As Single ' Proportional calculated part
Dim Iterm As Single ' Integrated calculated part
Dim Dterm As Single ' Derivated calculated part
' -----[ Code
If Auto_mode = 1 Then
Regulating modus
Error = Sp - Pv
Sum_error = Sum_error + Error
Iterm = Ki * Sum_error ' Integrated CV part
' -------- First
time startup
If First_execution < 2 Then
If First_execution = 0 Then
Sum_error = Manual_value / Ki
First_execution = 1
Initial_error = Error
Pterm = 0
Dterm = 0
If Initial_error > 0 And Error < 0 Then
First_execution = 2
Last_pv = Pv
If Initial_error < 0 And Error > 0 Then
First_execution = 2
Last_pv = Pv
Last_sp = Sp
' -------- Normal
calculation loop
Else
D_pv = Last_pv - Pv
Last_pv = Pv
Dterm = Kd * D_pv ' Derivated CV part
If Sp = Last_sp Then
' -------- Normal loop when setpoint not changed
Pterm = Kp * Error ' Proportional CV part
' -------- Loop when setpoint changed
Else
Pterm = 0
Dterm = 0
If Sp > Last_sp And Pv > Sp Then
Last_sp = Sp
Last_pv = Pv
If Sp < Last_sp And Pv < Sp Then
Last_sp = Sp
Last_pv = Pv
End If ' Enf of SP change seperation '
End If ' Enf of first time running seperation '
Cv = Pterm + Iterm ' Summing of the tree
Cv = Cv + Dterm ' calculated terms
' -------- Forced
modus
Else ' When running in non regulationg modus
Cv = Manual_value ' Set output to predefined value
First_execution = 0 ' restart bumpless
