' Jim Gillespie
' Revised 8-16-2001
' Bit twiddle outputs on 74HC595 daisy chained shift
registers.
' Automatically determines shift register length.
' Written to control a large number of relays.
' Uses 5 port B pins on an ATMEL 90S8515.
' NOTE: the clear_out line does not have to be used.
' The 74HC595 parts will be replaced by ALLEGRO UCN5841A
parts which
' do not have a Clear_Out input pin. Software modified
1-2-00
' to use either the ALLEGRO or 74HC595 chips.
' Added M (map) function to show output status of latched
bits. 2-04-00
' NOTE****: Revised 8-16-2001. DOWNTO instruction no
longer supported.
' Replaced with FOR, TO, STEP -1.
' NOTE****: Compiler no longer supports this syntax:
' For I = 1 to Max_bytes + 1 where Max_bytes is a defined
' constant. Had to add a variable Limit_bytes and set it
to
' Max_bytes and then add 1 to it.
' NOTE****: The 595 chips WILL NOT directly drive relays.
They
' require inverting drivers. FETs, transistors or relay
driver chips
' must be added. The ALLEGRO UCN5841A chips WILL directly
drive relays.
' The ALLEGRO chips are recommended for this application.
' NOTE****: This software has been modified to use EITHER
the 595 or
' the 5841 chips. The CLEAR input to 595 chips is no
longer required.
' NOTE****: ATMEL AVR parts power up with I/O pins
tri-stated.
' All pins that will be used as outputs should have 2.2k
pulldown
' resistors to ground to prevent power-up glitchs.
'Additional info from Vikki Welch :
' Chip Connections (DIP is J or W package, Flat pack is D
or N package):
' Portb.0 to SRCLK (Dip pin 11, flat pack pin 14).
' Portb.1 to SER (Dip pin 14, flat pack pin 18).
' Portb.2 to LAST Qh' (DIP pin 9, Flat pack pin 12).
' Portb.3 to RCLK (Dip pin 12, Flat pack pin 15).
' Portb.4 to SRCLR (595 Only - DIP pin 10, Flat pack pin
13).
' !OE must be low/gnd (DIP pin 13, Flat pack pin 17).
' Command set:
' Snn Set and latch bit nn. Echos command.
' Cnn Clear and latch bit nn. Echos command.
' R Reset and latch all 0's. Echos command
' T Test shift registers and sets length in bits. Returns
bit length
' Does not affect 595 outputs.
' V Version. Return a string giving software version.
' I Initialize. Starts program from scratch. echos
command.
' M Map. Show status of latched output bits LSB to MSB
$regfile = "8515def.dat" ' 8515 used here. Other ATMEL AVR
chips possible.
$baud = 9600 ' development board uses 4
MHZ XTAL
$crystal = 4000000
'$crystal = 7372800 ' use these 2 for production version
'$baud = 9600 ' uses a 7.3728 MHZ XTAL
Const Max_in_len = 3 ' define maximum input chars
Const Max_bytes = 10 ' define max shift reg bytes possible
Const Shift_delay = 20 ' shift delay in microseconds
Const Test_pattern = &HAA ' shift reg test pattern
Dim Bytes(max_bytes) As Byte ' byte shift reg output buffer
Dim String_input As String * Max_in_len ' dim to maximum input characters
Dim Raw_echo As String * Max_in_len
Dim Read_string As String * 40 ' Gets strings read from DATA statement
Dim Value As Byte ' becomes numeric value of command
Dim Opcode As String * 1 ' one character opcode goes here
Dim Temp As String * 2 ' temp string work variable
Dim Tempbyte1 As Byte ' more temp vars
Dim Tempbyte2 As Byte
Dim I As Byte
Dim J As Byte
Dim K As Byte
Dim Max_shift_len As Byte ' Test sets this to max bits found
Dim Arry_end As Byte ' Test sets this to last array
element
Dim Set_clear_flag As Bit ' flag used to set or clear a bit
Dim Limit_bytes As Byte ' For compatibility with version
1.11.6.2
' *** readability definitions ***
' NOTE: 595 pin 13 must be low/GND.
' Note: connect the Qh' of the previous 595 to the SER of
the next 595.
Clock_out Alias Portb.0 ' SRCLK - 74HC595
Data_out Alias Portb.1 ' SER - of the first 74HC595
Data_in Alias Portb.2 ' Qh - of the
last 74HC595
Data_in_read Alias Pinb.2 ' Qh - of the last 74HC595
Latch_out Alias Portb.3 ' RCLK
Clear_out Alias Portb.4 ' SRCLR, available on 74HC595. LOW
true.
Clock_out_dir Alias Ddrb.0 ' *** define direction regs ***
Data_out_dir Alias Ddrb.1
Data_in_dir Alias Ddrb.2
Latch_out_dir Alias Ddrb.3
Clear_out_dir Alias Ddrb.4
' *** sub definitions ***
Declare Sub Clearbytes(byval Bytecnt As Byte) ' clear byte array
Declare Sub Latchbytes() ' xfer shift reg
to latch outputs
Declare Sub Clearshift() ' clear shift reg
Declare Sub Test_shift_reg() ' test and
determine shift reg length
Declare Sub Set_clear_bit() ' set or clear
bit based on flag
Declare Sub Send_bytes() ' send byte array
to shift registers
Declare Sub Map_byte() ' print binary
pattern for Bytes(I)
Init: ' *** set initial
conditions for I/O ***
' MAIN starts here
Set Clock_out
Reset Data_out
Reset Latch_out
Set Clear_out
' set the data direction for I/O
Set Clock_out_dir
Set Data_out_dir
Reset Data_in_dir
Set Latch_out_dir
Set Clear_out_dir
Limit_bytes = Max_bytes ' NOTE**:For compatibility with version 1.11.6.2
Incr Limit_bytes ' NOTE**:For compatibility with version 1.11.6.2
Call Clearshift() ' clear shift reg
Call Latchbytes() ' xfer zeros to
outputs
Call Clearbytes(max_bytes) ' clear output byte array
Call Test_shift_reg() ' test and set
shift reg length
If Max_shift_len = 0 Then
Print "Control Board Failure !!"
Else
Print "Control Board OK !!"
Do ' ****** MAIN
LOOP ******
String_input = Space(max_in_len) ' clear input string to spaces
Input String_input ' read input string
Raw_echo = String_input ' form echo string
String_input = Trim(string_input) ' trim lead and trail spaces
Opcode = Left(string_input , 1) ' extract opcode
Opcode = Ucase(opcode) ' convert to upper case
Temp = Mid(string_input , 2 , Max_in_len) ' get numeric string
Temp = Trim(temp)
Value = Val(temp) ' convert string to numeric
If Value > Max_shift_len Then ' setting or clearing beyond bit
range?
Opcode = " " ' yes. set a bogus command code
Select Case Opcode
Case "S" ' Set a bit
If Value = 0 Then ' improper bit
value or format
Print "ERR 7"
Else
Set Set_clear_flag ' flag to set a bit
Call Set_clear_bit() ' go set the bit in array
Call Send_bytes() ' send to shift regs
Call Latchbytes() ' latch the bit pattern to outputs
Print Raw_echo ' echo command
Case "C" ' Clear a bit
value or format
Print "ERR 8"
Else
Reset Set_clear_flag ' flag to clear a bit
Call Set_clear_bit() ' clear the bit in the array
Case "M" ' Print map of
output bits set/reset
If Arry_end = 0 Then ' shows LSB to
MSB
Print "ERR 7"
Else
For I = 1 To Arry_end
Call Map_byte()
Print " ";
Next I
Print
Case "V" ' print Version
etc from DATA
Restore Version_string ' Initialize DATA string
pointer
Read Read_string
I = Instr(read_string , "^") ' ^ character exits loop
If I <> 0 Then
Exit Do
Print Read_string;
Print
Case "T" ' Test interface
Call Clearshift() ' set shift reg to all zeros
Call Clearshift() ' clear shift reg again
If Max_shift_len = 0 Then ' if failure,
give error message
Print "ERR 1"
Else
Print Max_shift_len ' otherwise, echo shift reg
length found
Case "R" ' Reset all
outputs low
Call Latchbytes() ' latch shift reg
Call Clearbytes(max_bytes) ' clear byte array
Print Raw_echo ' echo command input
Case "I" ' Initialize
Exit Do ' re-start this program
Case Else ' unknown or
improper command format
Print "ERR 4"
End Select
Loop ' ***** MAIN LOOP END *****
Print "Control Board Reset and Initialized"
Goto Init ' I command. restart program
' *** subroutines ***
Sub Clearbytes(byval Bytecnt As Byte) ' clear output byte array
For I = Bytecnt To 1 Step -1 'NOTE**: Old DOWNTO no longer works
Bytes(i) = 0
Next I
End Sub
Sub Latchbytes()
Set Latch_out ' latch the shift reg to outputs
Waitms 1
Reset Latch_out
End Sub
to all 0's
Tempbyte1 = 0 ' Modified 1-2-99 for ALLEGRO chips
For I = 1 To Limit_bytes ' send lots of zeros to shift regs to clear
Shiftout Data_out , Clock_out , Tempbyte1 , 0 , 8 , Shift_delay
Next I
Reset Clear_out ' toggle the clear out line (for
74HC595 parts)
Waitms 1
Set Clear_out
End Sub
Sub Test_shift_reg() ' send byte
pattern &HAA to
Tempbyte1 = Test_pattern ' shift reg and
count how many 8 bit shifts til
' the pattern appears in cpu input shift reg
For I = 1 To Limit_bytes ' NOTE**: For compatibility with 1.11.6.2
Shiftin Data_in_read , Clock_out , Tempbyte2 , 0 , 8 , Shift_delay
If Tempbyte2 = Test_pattern Then
Exit For ' we got a match to pattern
Next I
If Tempbyte2 <>
Test_pattern Then
Max_shift_len = 0 ' no match. hardware problem!!
Arry_end = 0
Else
Max_shift_len = I * 8 ' match! calc. and save number of bits found
Arry_end = I ' last array element
End Sub
Sub Set_clear_bit() ' set or clear a
bit in byte array
K = 1
I = Value - 1 : I = I 8 : I = I + 1 ' calc array index
J = Value - 1 : J = J Mod 8 ' calc bit
position
Tempbyte1 = Bytes(i)
Rotate K , Left , J ' put a 1 in proper bit position
If Set_clear_flag = 1 Then
Tempbyte1 = Tempbyte1 Or K ' sets the bit position
Else
K = Not K
Tempbyte1 = Tempbyte1 And K ' clear bit position
Bytes(i) = Tempbyte1 ' update array byte
'Print
Hex(tempbyte1) ' ********* debug ***********
End Sub
Sub Send_bytes()
For I = Arry_end To 1 Step -1 ' send byte array to shift regs
Next I
End Sub
Sub Map_byte() ' show map of
output latch states
Tempbyte1 = Bytes(i) ' LSB to MSB
For J = 1 To 8 ' 8 bits
per byte to process
K = Tempbyte1 And 1 ' test LSB
If K <> 0 Then
Print "1";
Else
Print "0";
Shift Tempbyte1 , Right , 1
Next J
End Sub
$data ' Put some strings in DATA for V command
Version_string: ' just for fun
Data "Jim Gillespie" , " 08-16-2001" , " Version 5.01"
Data " Serial #" , "000401" , "^"
