Friday, 04 July 2025
AN #205 - Controllino Mini Print
  The Controllino Mini is an industry-standard Arduino application. It is based on the Arduino UNO board.
It is based on the Arduino UNO board. There are all functionalities of the Uno Board available, inputs and outputs works with 12V / 24V levels. The housing can be mounted on a rail.
Manufacturer is the company Conelcom GmbH based in Austria. www.controllino.biz
The Controllino Mini is equipped with the following features:
•    Microcontroller: ATmega328
•    Atmel Clock Speed: 16 MHz
•    RTC
•    1x serial Interface
•    1x SPI Interface
•    1x I2C Interface
•    Input current Max. 8A
•    6x Relays Outputs – 230V / 6A
•    8x Analog/Digital Inputs  12V or 24V
•    8x Digital Outputs – 2A @12V or 24V
•    3x PWM Outputs
Usually the Controllino is programmed via the Arduino IDE.
The following example explains the programming of the Controllino with BASCOM.
The program shows the following functions of the Controllino:
• Set and start the Real Time Clock
• Retrieving and displaying the date and time
• Text output via the serial interface
• The digital inputs A0 - A3 control the digital outputs / Relias D0 - D3
• Analogue measurement at the inputs A4 u. A5
• Interrupts via inputs IN0 u. IN1
• Signal output at the outputs D6 a. D7
• PWM signal to output D5
The BASCOM Terminal Emulator displays all program actions.
The serial communication is set to a baud rate of 19200 baud.
Two "screens" are displayed. To one the functions and to the other the actual actions.
Programming the Controllino can be done via the already loaded boot loader. AVRDUDE should be used for this.
http://savannah.nongnu.org/projects/avrdude
In this case, the following settings should be made in the BASCOM option:
Option Programmer
    Programmer :         External Programmer
    Program:         Path to avrdude.exe
    Parameter:        -C c:\avrdude\avrdude.conf -p m328p -P com5 -c arduino -b 115200 -U flash:w:{FILE}:i
Source code:
'BASCOM Demo Controllino MINI
'Entspricht Arduino Uno
'Prozessor: ATMega328 - 32 TQFP
' (c) by .:nomit - Nordhorner Mikrocontroller Technik   03.2018
'                   --- Ports , Pin Belegung ---
' µc Ports     Controllino                   Funktion                Leiste X1
' Port B:
' 0            D4 / Relay D4                 OUT                     16
' 1            D5 / Relay D5 / PWM OC1A      OUT                     17
' 2            SS RTC                        RTC                     20
' 3            MOSI                          RTC                     21
' 4            MISO                          RTC                     22
' 5            SCK                           RTC                     23
' 6            OSC
' 7            OSC
' Port C
' 0            A0                            IN / ADC0                3
' 1            A1                            IN / ADC1                4
' 2            A2                            IN / ADC2                5
' 3            A3                            IN / ADC3                6
' 4            D6 / SDA                      OUT / I2C BUS           18
' 5            D7 / SCL                      OUT / I2C BUS           19
' 6            RESET                         Reset                   11
' Port D
' 0            RxD                           COM                     26
' 1            TxD                           COM                     25
' 2            IN0                           IN / Interrupt 0         9
' 3            IN1                           IN / Interrupt 1        10
' 4            D0 / Relay D0                 OUT                     12
' 5            D1 / Relay D1 / PWM OC0B      OUT                     13
' 6            D2 / Relay D2 / PWM OC1B      OUT                     14
' 7            D3 / Relay D3                 OUT                     15
' ADC6         A4                            ADC6                     7
' ADC7         A5                            ADC7                     8
'                                            5V+                      1
'                                            GND                      2
'                                            3.3V+                   24
$regfile = "m328pdef.dat" 'als 32 TQFP
$framesize = 32
$swstack = 32
$hwstack = 64
$crystal = 16000000                                         'Resonatorfrequenz
$baud = 19200                                               'Baudrate (Übertragungsgeschwindigkeit)
Baud = 19200
'##### Variablen Uhrzeit ######
Dim Stunden As Byte
Dim Minuten As Byte
Dim Sekunden As Byte
Dim Tag As Byte
Dim Wochentag As Byte
Dim Monat As Byte
Dim Jahr As Byte
Dim Txt_rtc As String * 25                                  'String für Zeit
'##### Variablen #######
Dim Zur_rtc(10) As Byte 'für SPI / RTC
Dim Von_rtc(10) As Byte 'für SPI / RTC
Dim Result As Word 'ADC Ergebnis
Dim _int0 As Byte 'Zähler Interrupt In0
Dim _int1 As Byte 'Zähler Interrupt In1
Dim X As Byte 'Allgemein
Dim Status(2) As String * 3                                 'Statusmeldung für Ein- / Ausgänge
    Status(1) = "AUS"
    Status(2) = "EIN"
'##### Variabel PWM #####
Dim _pwm As Word 'Zähler PWM
Dim _pwm_rauf As Bit 'Flag für PWM rauf / runter
'##### Alias der Controllino Ports #####
D0 Alias Portd.4                                            'Digital Ausgänge D0 - D7
D1 Alias Portd.5
D2 Alias Portd.6
D3 Alias Portd.7
D4 Alias Portb.0
D5 Alias Portb.1
D6 Alias Portc.4
D7 Alias Portc.5
A0 Alias Pinc.0                                             'Digital Input
A1 Alias Pinc.1
A2 Alias Pinc.2
A3 Alias Pinc.3
In0 Alias Pind.2                                            'Eingänge A4 u. A5 als Digital Eingang
In1 Alias Pind.3
Const Adc_a0 = 0                                            'Analog Kanäle A0 - A5
Const Adc_a1 = 1
Const Adc_a2 = 2
Const Adc_a3 = 3
Const Adc_a4 = 6
Const Adc_a5 = 7
'#### Alias des SPI Bus ####
Rtc_ss Alias Portb.2
Mosi Alias Portb.3
Miso Alias Pinb.4
Sck Alias Portb.5
'##### Delcare Subs ######
Declare Sub Rtc_schreiben(byval Tt As Byte , Byval Mm As Byte , Byval Jj As Byte , Byval Wt As Byte , Byval H As Byte , Byval M As Byte , Byval S As Byte )
Declare Sub Rtc_lesen()
Declare Sub Rtc_reset()
'##### RTC Register #####
Const Rtc_control_1 = &H00
Const Rtc_control_2 = &H01
Const Rtc_seconds = &H02
Const Rtc_minutes = &H03
Const Rtc_hours = &H04
Const Rtc_days = &H05
Const Rtc_weekdays = &H06
Const Rtc_months = &H07
Const Rtc_years = &H08
'Programm   : Main
'Funktion   : Hauptroutine
'Aufruf von : Reset
'Ausgabe    : ---
'Eingabe    : ---
'Bemerkung  :
Main:
 'Ports
 Ddrb = &B11111111                                        'PortB als Ausgang
 Portb = &B00000000                                       'Alles aus
 Ddrc = &B01110000                                        'D4 + D5 = Ausgang, A0 - A4 = Eingang
 Portc = &B11000000                                       'Relais aus, A0 - A4 Pullup aus !
 Ddrd = &B11110011                                        'PortD 4 - 7 ,0-1 als Ausgang , IN0 u. IN1 als Eingang
 Portd = &B00000011                                       'D4 - D7 aus, IN0 u. IN1 Pullup aus !
 'SPI RTC
 Config Spi = Hard , Interrupt = Off , Data_order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 1
 Spiinit
 'AD Konverter
 Config Adc = Single , Prescaler = Auto , Reference = Avcc
 'PWM
 Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Up , Prescale = 8       '980Hz
 Set _pwm_rauf                                            'Richtung rauf zählen
   _pwm = 0                                                 'Vorbesetzen
   Pwm1a = _pwm
 'Interrupts
 On Int0 Int0_isr                                         'Interrupt Serviceroutine
 Config Int0 = Falling                                    'Auslösen durch fallende Flanke
 Enable Int0                                              'Interrupt freibegeb
 On Int1 Int1_isr                                         'Interrupt Serviceroutine
 Config Int1 = Rising                                     'Auslösen durch steigende Flanke
 Enable Int1                                              'Interrupt freibegeb
 Enable Interrupts 'alle Interrupts freigeben
 Set D6                                                   'Ausgang vorbesetzen
 Reset D7                                                 'Ausgang vorbesetzen
 'Ende der Initialisierung
 Print
 Print "***********************************"
 Print "*Bascom Demo fuer Controllino Mini*"
 Print "*(c) .:nomit               03.2018*"
 Print "*---------------------------------*"
 Print "*RTC                              *"
 Print "*   Uhrzeit / Datum  (RTC = 1)    *"
 Print "*   A0 = 1 ->  initialisiere RTC  *"
 Print "*Input      Output                *"
 Print "*   A0  ->  D0                    *"
 Print "*   A1  ->  D1                    *"
 Print "*   A2  ->  D2                    *"
 Print "*   A3  ->  D3                    *"
 Print "*Analog                           *"
 Print "*   A4     (0 - VCC)              *"
 Print "*   A5     (0 - VCC)              *"
 Print "*Interrupt                        *"
 Print "*   IN0    --+__   -> _INT0 + D4  *"
 Print "*   IN1    __+--   -> _INT1       *"
 Print "*PWM                              *"
 Print "*   D5  ->  PWM (50 - 1000)       *"
 Print "***********************************";
 Wait 5
 Print
 Call Rtc_reset
 'Initialisieren der RTC nach Reset, wenn Eingang A0 = high Level ist
 If A0 = 1 Then 'A0 = High, schreibe Uhrzeit / Datum neu
 Call Rtc_schreiben(19 , 3 , 18 , 1 , 09 , 58 , 30) 'setzte RTC auf: Mo, 19.03.18 / 09:58:30
 Print "RTC wurde neu initialisiert..."
 Wait 2
 End If
 'Demo RTC
 Call Rtc_lesen()
 Print "Zeit: " ; Txt_rtc
 'Demo Digital Input / Output
      D0 = A0                                               'Ausgänge schalten
      D1 = A1
      D2 = A2
      D3 = A3
 Print
 Print "Ein- / Ausgang"
 Print "--------------"
      X = A0 + 1
 Print "A0 -> D0 = " ; Status(x)
      X = A1 + 1
 Print "A1 -> D1 = " ; Status(x)
      X = A2 + 1
 Print "A2 -> D2 = " ; Status(x)
      X = A3 + 1
 Print "A3 -> D3 = " ; Status(x)
 'Demo ADC
 Print
 Print "Analog"
 Print "------"
      Result = Getadc(adc_a4) 'Analog A4
 Print "A4: " ; Result
      Result = Getadc(adc_a5) 'Analog A5
 Print "A5: " ; Result
 'Demo Interrupt
 Print
 Print "Interrupts"
 Print "----------"
 Print "_Int0 = " ; _int0
 Print "_Int1 = " ; _int1
 'Demo Digital Ausgang ohne Relais
 Toggle D6
 Toggle D7
 Print
 Print "Digital Ausgang / PWM"
 Print "---------------------"
      X = D6 + 1
 Print "DA D6  = " ; Status(x)
      X = D7 + 1
 Print "DA D7  = " ; Status(x)
 'Demo PWM
 If _pwm_rauf = 1 Then 'welche Richtung wird gezählt?
 If _pwm < 1000 Then
            _pwm = _pwm + 50
 Else
            _pwm = _pwm - 50
 Reset _pwm_rauf                                 'Runter zählen
 End If
 Else
 If _pwm > 50 Then
            _pwm = _pwm - 50
 Else
            _pwm = _pwm + 50
 Set _pwm_rauf                                   'Rauf zählen
 End If
 End If
      Pwm1a = _pwm                                          'PMW1A stetzen
 Print "PWM D5 = " ; _pwm
 Wait 1
'Subroutine : RTC_Reset
'Funktion   : Software Reset RTC
'Aufruf von : Main
'Ausgabe    :
'Eingabe    :
'Bermerkung :
Sub Rtc_reset()
   Rtc_ss = 1                                               'Chipselect ein
   Zur_rtc(1) = &H10
   Zur_rtc(2) = &H58
 Spiout Zur_rtc(1) , 2
   Rtc_ss = 0
End Sub
'Subroutine : RTC_Lesen
'Funktion   : Lese Uhrzeit und Datum
'Aufruf von : Main
'Ausgabe    : Tag, Monat, Jahr , Wochentag, Stunden, Minuten, Jahr , txt_RTC
'Eingabe    :
'Bemerkung  : Ausgabe in Dezimalwerte, String
Sub Rtc_lesen()
   Zur_rtc(1) = &H92                                        'Lese von Adresse 02h
   Von_rtc(1) = Spimove(zur_rtc(1) , 8)
   Rtc_ss = 0
   Von_rtc(2) = Von_rtc(2) And &B01111111                   'Reset Wert filtern
   Von_rtc(3) = Von_rtc(3) And &B01111111                   'Reset Wert filtern
   Sekunden = Makedec(von_rtc(2)) 'Sekunden umwandeln in Dezimal
   Minuten = Makedec(von_rtc(3)) 'Minuten umwandeln in Dezimal
   Stunden = Makedec(von_rtc(4)) 'Stunden umwandeln in Dezimalin
   Tag = Makedec(von_rtc(5)) 'Wochentag umwandeln in Dezimalin
   Wochentag = Makedec(von_rtc(6)) 'Tag Umwandeln In Dezimalin
   Monat = Makedec(von_rtc(7)) 'Monat umwandeln in Dezimalin
   Jahr = Makedec(von_rtc(8)) 'Jahr umwandeln in Dezimalin
 Select Case Wochentag                                    'Suche Wochentag
 Case 00
            Txt_rtc = "So, "
 Case 01
            Txt_rtc = "Mo, "
 Case 02
            Txt_rtc = "Di, "
 Case 03
            Txt_rtc = "Mi, "
 Case 04
            Txt_rtc = "Do, "
 Case 05
            Txt_rtc = "Fr, "
 Case 06
            Txt_rtc = "Sa, "
 End Select
    Txt_rtc = Txt_rtc + Bcd(von_rtc(5)) + "." + Bcd(von_rtc(7)) + "." + Bcd(von_rtc(8)) + " / " + Bcd(von_rtc(4)) + ":" + Bcd(von_rtc(3)) + ":" + Bcd(von_rtc(2))
End Sub
'Subroutine : RTC_schreiben
'Funktion   : Schreibt Uhrzeit und Datum
'Aufruf von : Main
'Ausgabe    :
'Eingabe    : Tag(1-31), Monat(1-12), Jahr(0-165), Wochentag (0-7 (0=So,1=Mo,..), Stunde(0-23), Mintuen(0-59), Sekunden(0-59)
'Bemerkung  : Eingabe in Dezimalwerte
   Zur_rtc(1) = &H12                                        'Schreibebefehl ab Adresse 02h
   Zur_rtc(2) = Makebcd(s) 'Sekunden in BCD
   Zur_rtc(2) = Zur_rtc(2) And &H7F                         'Ozilator aktiveren
   Zur_rtc(3) = Makebcd(m) 'Minuten in BCD
   Zur_rtc(4) = Makebcd(h) 'Stunden in BCD
   Zur_rtc(5) = Makebcd(tt) 'Tag in BCD
   Zur_rtc(6) = Makebcd(wt) 'Wochentag in BCD
   Zur_rtc(7) = Makebcd(mm) 'Monat in BCD
   Zur_rtc(8) = Makebcd(jj) 'Jahr in BCD
 Set Rtc_ss                                               'Chip Select
 Spiout Zur_rtc(1) , 8                                    'Schreibe Werte
 Reset Rtc_ss
End Sub
'Subroutine : Int0_Isr
'Funktion   : INT0 Interrupt Serviceroutine
'Aufruf von : IN0, fallende Flanke
'Ausgabe    : Incr _Int0, Toggle D4
'Eingabe    :
'Bemerkung  : Kein Entprellen des Eingangs;
Int0_isr:
 Incr _int0                                               'Zähler für In0
 Toggle D4                                                'Relais setzen / löschen
'Subroutine : Int1_Isr
'Funktion   : INT1 Interrupt Serviceroutine
'Aufruf von : IN1, steigende Flanke
'Ausgabe    : Incr _Int1
'Eingabe    :
Int1_isr:
 Incr _int1                                               'Zähler für In1
