Fedor Sumkin , Russia , 2007
Here is little project, which in the next once proves
the superiority a controller AVR on rest processor.
When enabling device, is initialized screen, is
flooded by black colour and is removed video real-time with cameras.
The Iron:
The Camera ADCM1700 rs from telephone Siemens S65
(their there several types it is necessary to take with inscription HERA 0408)
Controller ATMEGA162 - 16PU. Possible drive before 24 megahertz (the body of
the quartz fastened on mass, so more works).
The Display from Siemens S65 with controller LPH8836
(other display with the other controller to put no sense in view of their
different commands to initialization) MEGA clock the camera by conclusion OC1A
frequency 8 megahertz. Also with cameras come the signals to synchronizing
hsync and vsync, which are hooked on interruptions of the controller.
The Display hungs on bus SPI, which is dispersed
before limit, and basically influences upon the whole capacity device.
Feeding of device 3 volt.
Feeding of highlight display 12 volt. Schematic:
Detail:
Program:
' Connection a display Siemens S65 with marking Lph88 for Atmega162
' illumination display 12 volt ( be carefull ).
' LCD AVR
' 1 /RS B4
' 2 /Reset B3
' 3 /CS B2
' 4 /CLK B7
' 5 /DAT B5
' 6 /Vcc 3 V (max.3.3 V, min.2.4 V)
' 7 /GND GND
' 8 /Vdigital 3 Volt
' 9 /LED+ 12.0 V
' 10/LED- GND
' Program of functioning with display Siemens c65
' Bascom-AVR 1.11.8./...
$regfile = "m162def.dat" 'MEGA 162
$crystal = 16000000 'quartz 24 megahertzs will correct position of deals
$baud = 115200 'velocity COM port 115200 (for overclocking REM)
$hwstack = 16
$swstack = 16
$framesize = 32
'$xramstart = &H260
'$xramsize = 65535
On Int0 Data_reqest Nosave
On Int1 Hsyncro Nosave 'duration of line forms 319 microseconds
'break between lines forms 114 microseconds (productive time)
On Int2 Kadr Nosave 'duration of frame forms 207 milliseconds
'For normal work with memory put latch cameras in unit.
Wait 2
Ddrb = &B11111111 'port b on output
Config Timer1 = Counter , Prescale = 1 , Compare A = Toggle 'give a clockrate on camera
Set Tccr1b.wgm12
Set Tccr1b.wgm13
Reset_memory Alias Portd.7 : Set Ddrd.7
Select_memory Alias Portd.6 : Set Ddrd.6
Camera_latch Alias Porte.2 : Set Ddre.2
Camera_ale Alias Portb.0 : Set Ddrb.0
Rs Alias Portb.4 '
Rst Alias Portb.3 '
Cs Alias Portb.2
Clk Alias Portb.7
Dat Alias Portb.5
Vsync Alias Pine.0 : Reset Ddre.0 '
Hsync Alias Pind.3 : Reset Ddrd.3 '
Data_clk Alias Pind.2 : Reset Ddrd.2
'Adjust ports on input/output
Set Ddrd.1
Config Portc = Input
Const Buff1_write = &H84
Const Buff2_write = &H87
Const Buff1_mem_write = &H83
Const Buff2_mem_write = &H86
Const Current_page_read = &HD2
'Colour Constants for display (I their until use)
Const White = &HFFFF 'white
Const Black = &H0000 'black
Const Red = &HF800 'red
Const Green = &H7C0 'green
Const Blue = &H1F 'blue
Const Whiblu = &H7FF 'whiblu
'Dim Adr As Word
Dim Xt As Byte
' For itself several variable
Dim Temp As Byte , X As Byte , Y As Byte , C As Bit
Dim Buf(264) As Byte At &H120 ' buffer for one line a display, also buffer an flash
Dim Page_mem As Word , Ar As Bit
Dim A As Word , N As Byte , Temp1 As Word
Dim Cadr_counter As Word
'It is Necessary to describe several subroutines
Declare Sub Bytein()
Declare Sub Clear_screen(byval Clear_color As Word)
Declare Sub Wordout()
Declare Sub Byteout()
Declare Sub S65_init()
Declare Sub Window_locate(byval X_start As Byte , Byval Y_start As Byte , Byval X_end As Byte , Byval Y_end As Byte)
Declare Sub Cspulse()
Declare Sub Command_send(byval Nn As Byte)
Declare Sub Data_send(byval Aa As Word)
Declare Sub Page_read(byval Page_mem As Word)
Declare Sub Buffer1_to_flash(byval Page_mem As Word)
Declare Sub Buffer1_write
C = 1 : A = 1
Config Int1 = Rising
Config Int2 = Rising
'Config Int0 = Falling
Const Cam_addr = &HA2
Const Reg = &H000A
Config Spi = Hard , Interrupt = On , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
Spiinit
Reset Spcr.spr1 : Reset Spcr.spr0 : Set Spsr.spi2x
'initialized SPI
Call S65_init
Call Clear_screen(black)
Set Cs
'$asm
'Sbi portb,0 'free bus given (have switched off camera)
'Sbi Mcucr,7
'$end Asm
Call Window_locate(1 , 1 , 127 , 176) 'added such useful subroutine (possible expose size of window)
$asm
ldi yh,$03
ldi yl,$00
clr r0
ldi r18,0
$end Asm
Enable Int2 'interruption on beginning of line
Gr:
'-------------Here is this piece of code is adjusted on transmission of line so that skip the whole one line------------------
If C = 0 Then
$asm
.def Temp = R22
.def Out1 = R21
.def Out2 = R20
cli
ldi r17,$7f
Dr:
ld r23,y+
mov temp,r23
!swap temp
andi temp,$f
' mov temp,r23
' !Swap Temp
' lsr temp
' andi temp,$7
' mov out1,r23
' andi out1,$f9
' add out1,temp
!out spdr,temp
Waih:
sbis spsr, spif
rjmp waih
'; mov temp,r23
' mov out2,r23
' lsr out2
' lsr out2
' lsr out2
' lsr r23
' !swap r23
' andi r23,$e0
' andi out2,$1f
' add out2,temp
!out spdr,temp
Wapih:
sbis spsr, spif
rjmp wapih
ld r23,y+
dec r17
brne DR
'removed one line
$end Asm
C = 1
sei
Goto Gr
Sub Bytein()
ldi r23,0
!Out Spdr , R23
Wairh:
sbis spsr, spif
rjmp wairh
in r23,spdr
sts {n},r23
End Sub
'--------------------subroutines---------------------
Sub Cspulse 'short pulse CS
Set Cs
nop
Reset Cs
End Sub
'------------Issue of just command an display---------------------------
Sub Command_send(byval Nn As Byte) 'issue of command
N = &H74
Call Byteout()
N = 0
Call Byteout()
N = Nn
Call Byteout()
Call Cspulse
End Sub
'----------Issue of just data an display------------------------------
Sub Data_send(byval Aa As Word) 'issue of Data
N = &H76
Call Byteout()
A = Aa
Call Wordout()
Call Cspulse
End Sub
'--------Subroutine for issue of parameter or spot in display----------------
Sub Wordout
lds r23, {a+1}
!out spdr, r23
lds r23, {a}
Wait_trh:
sbis spsr, spif
rjmp wait_trh
!out spdr, r23
Wait_trl:
sbis spsr, spif
rjmp wait_trl
End Sub
'-------------Subroutine for parcel a command an display--------------------------
Sub Byteout
lds r23, {n}
!out spdr, r23
Waitresult:
sbis spsr, spif
rjmp waitresult
End Sub
Sub S65_init
Reset Rst
Set Cs
Set Rs
Waitms 1
Set Rst
Waitms 10
Reset Cs
Restore Ini_code
For Temp = 0 To 33
Read N
Call Command_send(n)
Read A
Call Data_send(a)
Next Temp
Waitms 300
Set Cs
End Sub
Sub Clear_screen(clear_color As Word)
Dim Temp2 As Word
Reset Cs
Call Command_send(&H16)
Call Data_send(&H8400) 'Interesting parameters to reference (131) end on ő
Call Command_send(&H17)
Call Data_send(&Haf00)
Call Command_send(&H21) 'here expose window, in which remove to info.
Call Data_send(&H0)
Call Command_send(&H22)
N = &H76
Call Byteout()
A = Clear_color
For Temp2 = 1 To 46464
Call Wordout()
Next Temp2
End Sub
Sub Window_locate(x As Byte , Y As Byte , X_pixel As Byte , Y_pixel As Byte)
'subroutine Window locate
'first parameter - horizontal initial coordinate
'second parameter - vertical initial coordinate
'third parameter - horizontal end coordinate
'fourth parameter - vertical end coordinate
'Space is calculated so:
' (horizontal end coordinate - horizontal initial coordinate)
' multiply by
' (vertical end coordinate - vertical initial coordinate)
Reset Cs
N = &H76
Call Byteout()
N = X_end
Call Byteout()
N = X_start
Call Byteout()
Call Cspulse
N = &H76
Call Byteout()
N = Y_end
Call Byteout()
N = Y_start
Call Byteout()
Call Cspulse
N = &H76
Call Byteout()
N = X_start 'On my here changed (X and Y) but in such type works too
Call Byteout() 'In ideal needed to change
N = Y_start
Call Byteout()
Call Cspulse
N = &H76
Call Byteout()
End Sub
'-------------Flash read subroutine---------------------------------------------
'Subroutine of reading given pages of memory
'Input-------page_Mem (0-2047)
'Output------buf(264) ěŕńńčâ 264 áŕéňŕ
Reset Select_memory 'select flash ram
N = Current_page_read 'command Current_page_read
Call Byteout() 'out 3 bytes of adress
Shift Page_mem , Left , 1
A = Page_mem
Call Wordout()
N = 0
Call Byteout()
Call Byteout()
Call Byteout()
Call Byteout()
Call Byteout()
'ďĺđĺäŕëč 32 dont care bits
For Temp1 = 1 To 264
Call Bytein()
Buf(temp1) = N
Next Temp1
Set Select_memory
End Sub
'-------------Flash write subroutine---------------------------------------------
'Subroutine of writing a buffer 1 in page of memory
Reset Select_memory
N = Buff1_mem_write ' command write buffer to flash
Call Byteout()
A = Page_mem
Call Wordout()
N = 0
Call Byteout()
Set Select_memory 'deselect memory
Waitms 30
End Sub
Sub Buffer1_write
Reset Select_memory
N = Buff1_write ' command write in buffer
Call Byteout()
N = &H00 '
Call Byteout()
N = &H00 '
Call Byteout()
N = &H00 '
Call Byteout()
'Set Select_memory
End Sub
Data_reqest:
$asm
in r23,Pinc
st y+,r23
dec r19
breq all
reti
All:
ldi r19,$c0
ldi yh,$03
ldi yl,$00
$end Asm
Disable Int0
C = 0
Hsyncro:
$asm
ldi yh,$03
ldi yl,$00
ldi r19,$c0
$end Asm
Enable Int0 'take line in buffer
Kadr:
Y = 1
Incr Cadr_counter
Enable Int1
Ini_code:
Data &H07 , &H0000% , &H02 , &H0400% , &H04 , &H0000% , &H0C , &H0001% , &H0D , &H0616% , &H0E , &H1010%
Data &H03 , &H000C% , &H0E , &H2D1F% , &H0D , &H0616% , &H01 , &H0215% , &H0F , &H0000% , &H0B , &H0000%
Data &H11 , &H0000% , &H06 , &H0000% , &H05 , &H0030% , &H14 , &HAF00% , &H15 , &H0000% , &H16 , &H8300%
Data &H17 , &HAF00% , &H20 , &H0000% , &H30 , &H0000% , &H31 , &H0400%
Data &H32 , &H0207% , &H33 , &H0700% , &H34 , &H0005% , &H35 , &H0703% , &H36 , &H0707% , &H37 , &H0007%
Data &H3A , &H1200% , &H3B , &H0009% , &H07 , &H0005% , &H07 , &H0025% , &H07 , &H0027% , &H07 , &H0037%
