Wednesday, 09 July 2025
AN #159 - Rheobas four-channel Print
Anatoly A. Tokarev, Russia, 2007
That was got as a result:
4 channels of the regulation;
the regulation of the output voltage from 0 before practically 12 In stair, 128 stairs of the regulation;
the regulator is executed on scheme SEW so in it nothing do not get-warm (at least once so that there was it is necessary to put the radiators);
the frequency SEW 31250 Hz - an ultrasonic range - so works noiseless, no snub ;
after enabling rheobas (the computer) for 10 seconds occurs spinup ventilator on maximum voltage (12 volts), simultaneously occurs observation maximum velocity of the rotation impeller ventilator;
after spinup voltage in channel is fixed such, what it was under the last regulation and rheobas moves over to operating duty;
the speed measurements of the rotation impeller ventilator occurs round-robin, in 2 seconds is chosen next channel, is measured velocity, results of the measurement are removed on screen in the manner of absolute importance (in rotation per minute) and in the manner of percent from maximum velocity;
if the impeller cost(stand)s (no tahoe a signal), is removed report on damages on indicator and is given bleep (the amount "cheep" corresponds to the number of the channel, in which has occurred the damage);
the channel possible to switch off, bring level of the output voltage before 0, herewith it will not be interviewed, but on screen is removed message "out-of-work".
As it is seen, scheme became greatly in contrast with previous variant more simply. Do Not think that one more alteration will allow to do rheobas in 2 resistors :).
Some explanations to scheme:
the microcontroller DD1 forms 4 SEW the signal for governing P-canal MOSFET key DA1, DA2;
for clock microcontroller is used internal generator 8 MHZ, this has allowed to free the vapour a conclusion (for possible hereinafter connections sensor temperature) and reduce the price of the scheme;
information about the work channel regulations is removed on two-row ZHK indicator HL1, information in indicator is sent on quad bit to bus;
the buttons S1-S3 control work of rheobas, capacitors S2-S4, included parallel button, are intended for suppression bounce, are used internal tightening resistors on conclusion of the microcontroller, to which is connected buttons;
the chain R9,C5 and internal tightening resistor of the microcontroller execute the function of the voltage level co-ordination and, simultaneously, function of the filter of the low frequency, suppressing to a certain degree short pulsed hindrances in tahoe a signal ventilator;
for relief of searching for radio elements, the co-ordination level voltages of the microcontroller and MOSFET of keys are executed otherwise, than in previous scheme: instead of microcircuit of the co-ordination level 74F07, is used other scheme of the feeding (the stabilizer of the negative voltage DA3) with the result that findings Vcc microcontroller and Vdd indicator are connected to voltage +12 В, but findings GND microcontroller and Vss indicator are connected to voltage +7 In (leaving the stabilizer DA3). The Voltages are brought to the general wire (the body) of the computer feeding.
Such decision aside from plus (the stabilizer 79L05 to find greatly more simply, than 74F07), has and negative side: printed charge and particularly indicator it is necessary to fix so that was not a contact no their current-carrying parts (the conductor, platform, frames of the indicator etc.) with body of the computer!
Management:
S1 - "less", reduces the voltage on ventilator;
S2 - "fix", fixes the current channel, triangle appears left of inscription "Channel", the repeated striking removes fixing the channel, they will newly be switched in 2 seconds;
S3 - "more", enlarges the voltage on ventilator.
simultaneous striking S1+S3 - an unset rheobas, is newly produced spinup of impeller and measurement to maximum velocity of the rotation.
Long striking on button (long 1 seconds) includes auto cycling.
Now about designs:  this variant, either as previous rheobas, am going to to place in compartment 3,5" so as constructive I have taken the old spindle 3,5", has thrown whole stuffing, has sawed; sawn off the spare glandules and from face plastic panel has left only frame:
We Assemble the elements (DA1, DA2 - on the part of conductor!), throttles L1-L4 crepe on charge hot melt, solder the indicator.
On charge, beside connector of the connection of the feeding, is installed fusible fuze in chain of the general wire ventilator,it, certainly, possible change the jumper, however better his(its) put(deliver) to under casual closing conclusion 1,2 in connector XP1-XP4 not to burn the keys DA1, DA2. I was lazy immediately its put(deliver), as a result happened to to change the burned; burned microcircuit DA2.
For fastening the charge 4 screws M3 we use to constructive, it is necessary to take not too long - that they did not protrude from below - and, in ditto time that their lengths have been enough for installing plastic little buildings, raising slightly charge from constructive. This will allow align position of the buttons by the vertical.
The Indicator while (for time first experiment) shall bolt hot glue.
Programming the microcontroller:
Categorically it is impossible programmer the microcontroller, stated in board  of rheobas and eating from this computer - possible all пожечь!
Without fall programmer the microcontroller or in industrial programmator, or if it homemade and is intended for in-circuit of the programming, connect to it panel  for installing the microcircuit.
The Regulation:
Single that can require the regulations, this adjustment contrast scenes on indicator. For regulation change the chain a resistor R3, R4 on variable (preset) resistor 10 lumps, extreme findings of the variable resistor connect to chain +12 В and +7 В, but average output (the crawler) to output 3 indicators. Approaching scenes, on indicator. Unsolder resistor from board. To make size, resistances shoulder variable resistor (from average output before extreme outled) and install the constant resistors such or close nominal value.
No more regulations rheobas require.
We Proceed with experiment.
We Connect the ventilators and feeding, in channel 4 ventilators do not include:
After enabling (or after simultaneous striking the buttons S1, S2), during of the spinup.
 Indication of velocities in channel in rotation per minute and percent from maximum velocity.
 In channel 4 ventilators was not connected so signal is removed about damages.
 The Channel possible to switch off, for this it is necessary to reduce the voltage before 0.
 As a matter of convenience regulations, channel, in which goes the regulation possible to fix striking the button S2 If install too small voltage on ventilator, tahoe a sensor can give the wrong signal, as a result of evidences speed will be distant from reality.
The Practical advice: undesirable to install the velocity of the rotation below 30% from maximum, many ventilators in this case give the sloppy tahoe a signal.
Remained invent form and highly of the buttons, neatly do the front panel from stub. But this I will concern this at May.
For interesting persons to repeat rheobas, are enclosed:
the drawing of the printed board (ready to use on lazer-ironing to technologies);
the picture with location element on printed board;
the lace trim of the microcontroller;
the primaries.
Schematic:
Constrution examples:
Source code:
' 4 channel PWM rheobus for computer's fans on ATMega48.
' Rheo200Le.bas
' (c) Anatoly A. Tokarev 2007, atlab@zmail.ru
' NOT FOR COMMERCIAL USE!
' This is my first project on Atmel's microcontroller.
' It was started on 26 march 2007 and was fully (with hardware
' making and debugging) completed on 19 april 2007
' THANKS TO THE BASCOM-AVR.
' Design features:
' - internal ATMega RC generator 8 MHz
' - 4 PWM channels (regulation and measurement)
' - PWM is in ultrasound range (no sounds or clicks)
' - 0V <= Vout <= 12 V
' - 3 button user control
' - 2*16 LCD (# channel, fan speed: rpm and percentage of max speed)
' - 10 sec. full speed spinup after power on
'-- Control --------------------------------------------------------------------
' - button "Right" - increase fan speed
' - button "Left" -  decrease fan speed
' - button "Center" -  select # fan
' - buttons "Left+Right" - soft reset
'-- LCD ------------------------------------------------------------------------
' Db4 - PortC.0
' Db5 - PortC.1
' Db6 - PortC.2
' Db7 - PortC.3
' E   - PortC.4
' Rs  - PortC.5
'-- PWM outputs ----------------------------------------------------------------
' 5  - OC2B/PD3  - Pwm4
' 11 - OC0B/PD5  - Pwm2
' 12 - OC0A/PD6  - Pwm1
' 17 - OC2A/PB3  - Pwm3
'-- FAN tach -------------------------------------------------------------------
' 15 - PortB.1 - Tach1
' 16 - PortB.2 - Tach2
' 18 - PortB.4 - Tach3
' 19 - PortB.5 - Tach4
'-- Buttons --------------------------------------------------------------------
' Left   (Key1) - PinD.0
' Center (Key2) - PinD.1
' Right  (Key3) - PinD.2
 $regfile = "m48def.dat"
 $crystal = 8000000
'-- Timers init ----------------------------------------------------------------
'TMR0 and TMR2 use FAST PWM mode
 Tccr0a = &HF3
 Tccr0b = &H01
 Tccr2a = &HF3
 Tccr2b = &H01
' TMR1 used for fan failure check
Config Timer1 = Timer , Prescale = 64
'-- Ports init -----------------------------------------------------------------
Config Portb = &B11001001                                   'PB1,2,4,5 outputs, other - inputs
Portb = &B00110110                                          'use pullup on inputs
Config Portc = &B10111111                                   'PŃ6 - input
Portc = &B01000000                                          'use pullup on inputs
Config Portd = &B11101000                                   'PD0,1,2,4 - inputs
Portd = &B00010111                                          'use pullup on inputs
'-- LCD config ------------------------------------------------------------------
Config Lcdpin = Pin , Db4 = Portc., Db5 = Portc., Db6 = Portc., Db7 = Portc., E = Portc., Rs = Portc.4
Config Lcd = 16 * 2
'-- Buttons config -------------------------------------------------------------
Key1 Alias Pind.0                                           ' âëĺâî
Key2 Alias Pind.1                                           ' öĺíňđ
Key3 Alias Pind.2                                           ' âďđŕâî
'-- Alarm zummer ---------------------------------------------------------------
Speaker Alias Portd.4                                       '
'-- Variables ------------------------------------------------------------------
Dim T1over As Bit ' flag, if Timer1 is overflowed, whis is fan failure
Dim Needshow As Bit ' flag, need to show rpm
Dim Needtosave As Bit ' flag, need to save data in EEPROM
Dim Fixnchan As Bit ' flag, # channel is fixed
Dim Key1pressed As Byte '
Dim Key2pressed As Bit '
Dim Key3pressed As Byte '
Dim Cntr As Byte ' counter
Dim Ptr As Byte ' pinter
Dim Q(4) As Byte ' relative pulse duration
Dim Nchan As Byte ' # selected channel
Dim Nc As Byte
Dim Pcintcntr As Byte ' counter for 1/2 revolution
Dim Perc As Word '
Dim I As Byte '
Dim J As Byte '
Dim K As Byte '
Dim Pixelprogress As Word
Dim T1 As Word ' TMR1 save buffer
Dim Nmax(4) As Word '
Dim N(4) As Word '
Dim Nl As Long ' speed, rpm
Dim Buf As Word
Dim W As Word
Dim Nchstr As String * 1
$eeprom ' preprogrammed speed
Data 32 , 64 , 128 , 196
$data
'-- Interrupts -----------------------------------------------------------------
 On Pcint0 Isr_pcint0                                       ' PortB pin change interrupt (from fans)
 On Ovf1 Isr_tmr1                                           '
'-- Begin ----------------------------------------------------------------------
Progstart: ' soft reset label
 Pcmsk0 = 0                                                 '
 Timsk = 1                                                  '
 Disable Pcint0
 Stop Timer1
 Disable Timer1
 Pwm0a = 255
 Pwm0b = 255
 Pwm2a = 255
 Pwm2b = 255
'-- User defined symbols in LCD ------------------------------------------------
'-- Progressbar ----------------------------------------------------------------
 Deflcdchar 0 , 32 , 32 , 32 , 32 , 32 , 32 , 32 , 32       '
 Deflcdchar 1 , 16 , 16 , 16 , 16 , 16 , 16 , 16 , 16       '
 Deflcdchar 2 , 24 , 24 , 24 , 24 , 24 , 24 , 24 , 24       '
 Deflcdchar 3 , 28 , 28 , 28 , 28 , 28 , 28 , 28 , 28       '
 Deflcdchar 4 , 30 , 30 , 30 , 30 , 30 , 30 , 30 , 30       '
 Deflcdchar 5 , 31 , 31 , 31 , 31 , 31 , 31 , 31 , 31       '
'-- Right triange --------------------------------------------------------------
 Deflcdchar 6 , 16 , 24 , 28 , 30 , 30 , 28 , 24 , 16       '>
 Cls
 Cursor Off Noblink
 Upperline
 Lcd "Rheobus v2.00Le "
 Lowerline
 Lcd "(c) 2007 ATLab  "
 Waitms 10000                                               ' 10 sec. spinup
 Needshow = 0
 Enable Interrupts
 For Nchan = 1 To 4 Step 1                                  ' read PWM presets
   Ptr = Nchan + 8
 Readeeprom Q(nchan) , Ptr
 Gosub Speedmeter                                         ' Max speed measurment
 Waitms 500
 If Needshow = 1 Then
 Gosub Calcspeed
     Nmax(nchan) = Nl                                       '7500000  T1
     Needshow = 0
 Else
     Nmax(nchan) = 0
 End If
 Next Nchan
 Pwm0b = Q(1) ' set PWM
 Pwm0a = Q(2)
 Pwm2a = Q(3)
 Pwm2b = Q(4)
 Waitms 2000                                                ' 2 sec. for spin stabilization
 Nchan = 4
 Cntr = 3
 T1over = 0
 Needshow = 0
 Needtosave = 0
 Fixnchan = 0
 Key1pressed = 0
 Key2pressed = 0
 Key3pressed = 0
'-- Endless loop ---------------------------------------------------------------
' buttons 1,3 check pressed
 If Key1 = 0 Or Key3 = 0 Then
' 1,3 pressed simultaneously
 If Key1 = 0 And Key3 = 0 Then
 Goto Progstart                                       ' soft reset
 End If
' if pressed 3 (Right), increase rpm
 If Key3 = 0 Then '
 If Key3pressed < 5 Then '
         Key3pressed = Key3pressed + 1                      ' autorepeat after 1 sec
 End If
 If Key3pressed = 1 Or Key3pressed => 5 Then ' first press and autorepeat
 If Q(nchan) => 254 Then
           Q(nchan) = 255
 Else
           Q(nchan) = Q(nchan) + 2
 End If
 End If
 Else
       Key3pressed = 0                                      ' flag clear if button isn't pressed
 End If
' if pressed 1 (Left), decrease rpm
 If Key1 = 0 Then '
 If Key1pressed < 5 Then '
         Key1pressed = Key1pressed + 1                      ' autorepeat after 1 sec
 End If
 If Key1pressed = 1 Or Key1pressed => 5 Then ' first press and autorepeat
 If Q(nchan) <= 2 Then
           Q(nchan) = 0
 Else
           Q(nchan) = Q(nchan) - 2
 End If
 End If
 Else
       Key1pressed = 0
 End If
' setup PWM
 Pwm0b = Q(1)
 Pwm0a = Q(2)
 Pwm2a = Q(3)
 Pwm2b = Q(4)
     Cntr = 0
     Needtosave = 1
' RPM measurement after speed change
 If Q(nchan) = 0 Then
 Gosub Showfan
 Else
 Gosub Speedmeter                                     '
 End If
 Else
     Key1pressed = 0
     Key3pressed = 0
 End If
' check button 2 (center) pressed
 If Key2 = 0 Then ' select (fix) cahnnel
 If Key2pressed = 0 Then
       Key2pressed = 1
 Locate 1 , 1
 If Fixnchan = 0 Then
         Fixnchan = 1
 Lcd Chr(6) ' >
 Else
         Fixnchan = 0
 Lcd " "
 End If
 End If
 Else
     Key2pressed = 0
 End If
' pause 0.25 sec for the process sync.
 Waitms 250
   Cntr = Cntr + 1
' 0.5 sec later button release: save PWM data in EEPROM
 If Needtosave = 1 Then
 If Cntr => 2 Then
 Writeeeprom Q(1) , 9
 Writeeeprom Q(2) , 10
 Writeeeprom Q(3) , 11
 Writeeeprom Q(4) , 12
       Needtosave = 0                                       '
 End If
 End If
' next channel measerement after 2 sec.
 If Cntr => 8 Then '
     Cntr = 0
       Nchan = Nchan + 1                                    ' select next channel:
 If Nchan > 4 Then '  1->2->3->4->1..
         Nchan = 1                                          '
 End If
 End If
 Gosub Showfan
 Else
 Gosub Speedmeter                                     ' measurement
 End If
 End If
 If Needshow = 1 Then ' Measurement executed
 Gosub Calcspeed                                        ' Calculate the rpm
     N(nchan) = Nl                                          '
 If N(nchan) > Nmax(nchan) Then
        Nmax(nchan) = N(nchan)
 End If
 Gosub Showfan                                          ' and show on LCD
     Needshow = 0
 End If
' time is over, this is fan failure
 If T1over = 1 Then
 Gosub Showfan                                          ' show on LCD
     T1over = 0
 End If
' Show results on LCD
Showfan:
 Nc = Nchan + 48                                            ' for ROM economy
 Nchstr = Chr(nc) '
 Cls
 Locate 1 , 1
 If Fixnchan = 1 Then
 Lcd Chr(6) '"{201}" (like ">" sign)
 Else
 Lcd " "
 End If
 Locate 1 , 2
 Lcd "Channel" ' channel
 Lcd Nchstr                                                 ' number
 Lcd " is OFF " '
 Else
 If T1over = 1 Then
 Lcd " ALARM! " '
 For I = 1 To Nchan                                     ' make sound
 For W = 600 To 300 Step -4
 Sound Speaker , 5 , W                              '
 Next J
 Waitms 200
 Next I
 Else
 Lcd " "
 Lcd Str(n(nchan)) ' RPM
 Lcd " rpm" '
     Perc = N(nchan) * 10                                   ' calc percentage of Max Speed
     Pixelprogress = Perc
     Buf = Nmax(nchan)  10
     Perc = Perc  Buf
 Locate 2 , 2                                           ' show %
 Lcd Str(perc)
 Lcd "% "
     Buf = Nmax(nchan)  5
     Pixelprogress = Pixelprogress  Buf                    ' Nmax(nchan)
 Locate 2 , 6                                           ' show progress bar
 For I = 0 To 9 Step 1
       J = I * 5
       K = J + 5
 If K > Pixelprogress Then
 If J > Pixelprogress Then
           Ptr = 0
 Else
           Ptr = Pixelprogress Mod 5
 End If
 Else
           Ptr = 5
 End If
 Lcd Chr(ptr)
 Next I
 End If
 End If
' Speed calculation
Calcspeed:
 Nl = 7500000  T1
' Speed measurement start
Speedmeter:
 If Q(nchan) = 0 Then ' if channel is Off, no measure
 End If
 Pcintcntr = 0
 Timer1 = 0
 T1 = 0
 Start Timer1
 Select Case Nchan                                          '
 Case 4
 Pcmsk0 = &B00100000                                      ' interrupt mask for Tach4
 Case 3
 Pcmsk0 = &B00010000                                      ' interrupt mask for Tach3
 Case 2
 Pcmsk0 = &B00000100                                      ' interrupt mask for Tach2
 Case 1
 Pcmsk0 = &B00000010                                      ' interrupt mask for Tach1
 End Select
 Waitus 5                                                   '
 Pcifr = 0                                                  ' clr flag
 Enable Pcint0 ' enable interrupts
 Enable Ovf1                                                '
Isr_pcint0:
 If Pcintcntr = 0 Then
 Timer1 = 0                                               ' start revolution time measurement
 End If
 Pcintcntr = Pcintcntr + 1
 If Pcintcntr = 5 Then
 Stop Timer1 ' stop measurement
   T1 = Timer1
 Pcmsk0 = 0                                               ' clr all tach masks
 Disable Pcint0 '
 Disable Timer1 '
   Needshow = 1
 End If
Isr_tmr1:
 Stop Timer1
 Disable Timer1
 T1over = 1                                                 ' set overflow flag
