Wednesday, 09 July 2025
Check the Shop
  Random
Random
PIC002
PIC002
EUR 2.36
BASCOM-AVR CrossUpgrade (CD version)
EUR 83.49
GSM Modem - GSM Terminal from Contrive is ideal for embedded applications Print
The GSM Terminal from Contrive is ideal for embedded applications
GSM Terminal
  • Industrial GSM dual band modem.
  • Power supply 8÷38Vdc 6÷29Vac.
  • Data rate up to 14400bps. Fax/SMS.
  • Extended AT commands.
  • Mini-SIM card receptacle.
  • R&TTE approval.
  • RF power 2W @ EGSM900 (Class 4)
  • RF power 1W @ GSM1800 (Class 1)
  • Embedded antenna (type A)
  • External antenna (type X)
The GSM Terminal from Contrive is ideal for embedded applications. The modem can be controlled by RS-232. The module is approved so you can use it in your own designs. The internal antenna (model A) makes it simple to use the mode:
  • insert Sim Card
  • connect the power supply
  • control by simple AT commands
Here is a simple BASCOM-AVR program that sends an SMS and will receive SMS:
' SMS.BAS
' (c) 2002 MCS Electronics
' This sample shows how to use AT command on a GSM mode
' The GSM modems are available from www.mcselec.com
'tested on a 2314
$regfile = "2313def.dat"
'XTAL = 10 MHZ
$crystal = 10000000
'By default the modem works at 9600 baud
$baud = 9600
'HW stack 20, SW stack 8 , frame 10
'some subroutines
Declare Sub Getline(s As String)
Declare Sub Flushbuf()
Declare Sub Showsms(s As String )
'used variables
Dim I As Byte , B As Byte
Dim Sret As String * 66 , Stemp As String * 6
'we use a serial input buffer
Config Serialin = Buffered , Size = 12 ' buffer is small a bigger chip would allow a bigger buffer
'enable the interrupts because the serial input buffer works interrupts driven
Enable Interrupts
'define a constant to enable LCD feedback
Const Uselcd = 1
Const Senddemo = 1 ' 1= send an sms
Const Pincode = "AT+CPIN=1234" ' pincode change it into yours!
Const Phonenumber = "AT+CMGS=+31653123456" ' phonenumber to send sms to
#if Uselcd = 1
Cls
Lcd "SMS Demo"
#endif
'wait until the mode is ready after power up
Waitms 3000
#if Uselcd = 1
Lcd "Init modem"
#endif
Print "AT" ' send AT command twice to activate the modem
Print "AT"
Flushbuf
' flush the buffer
Print "ATE0"
#if Uselcd = 1
Home Lower
#endif
Print "AT" : ' Waitms 100
 Getline Sret
' get data from modem
#if Uselcd = 1
Lcd Sret ' feedback on display
#endif
Loop Until Sret = "OK" ' modem must send OK
Flushbuf
' flush the input buffer
#if Uselcd = 1
Home Upper : Lcd "Get pin mode"
#endif
Print "AT+cpin?" ' get pin status
Getline Sret
#if Uselcd = 1
Home Lower : Lcd Sret
#endif
If Sret = "+CPIN: SIM PIN" Then
Print Pincode ' send pincode
End If
Flushbuf
#if Uselcd = 1
Home Upper : Lcd "set text mode"
#endif
Print "AT+CMGF=1" ' set SMS text mode
Getline Sret
' get OK status
#if Uselcd = 1
#endif
'sms settings
Print "AT+CSMP=17,167,0,0"
Getline Sret
Print "AT+CNMI=0,1,2,0,0"
Getline Sret
#if Senddemo = 1
#if Uselcd = 1
Home Upper : Lcd "send sms"
#endif
Print Phonenumber
Waitms 100
Print "BASCOM AVR SMS" ; Chr(26)
 Getline Sret
#if Uselcd = 1
Home Lower : Lcd Sret 'feedback
#endif
#endif
'main loop
 Getline Sret
' wait for a modem response
#if Uselcd = 1
Cls
Lcd "Msg from modem"
#endif
 I
= Instr(sret , ":") ' look for :
If I > 0 Then 'found it
 Stemp
= Left(sret , I)
Select Case Stemp
Case "+CMTI:" : Showsms Sret ' we received an SMS
' hanle other cases here
End Select
End If
Loop ' for ever
'subroutine that is called when a sms is received
's hold the received string
'+CMTI: "SM",5
#if Uselcd = 1
Cls
#endif
 I
= Instr(s , ",") ' find comma
 I
= I + 1
 Stemp
= Mid(s , I) ' s now holds the index number
#if Uselcd = 1
Lcd "get " ; Stemp
Waitms 1000 'time to read the lcd
#endif
Print "AT+CMGR=" ; Stemp ' get the message
 Getline S
' header +CMGR: "REC READ","+316xxxxxxxx",,"02/04/05,01:42:49+00"
#if Uselcd = 1
Lowerline
Lcd S
#endif
 Getline S
' get data from buffer
Select Case S
Case "PORT" : 'when you send PORT as sms text, this will be executed
#if Uselcd = 1
Cls : Lcd "do something!"
#endif
Case "OK" : Exit Do ' end of message
Case Else
End Select
#if Uselcd = 1
Home Lower : Lcd "remove sms"
#endif
Print "AT+CMGD=" ; Stemp  ' delete the message
 Getline S
' get OK
#if Uselcd = 1
Lcd S
#endif
End Sub
'get line of data from buffer
 S
 B
= Inkey()
Select Case B
Case 0 'nothing
Case 13 ' we do not need this one
Case 10 : If S <> "" Then Exit Do ' if we have received something
Case Else
 S
= S + Chr(b) ' build string
End Select
End Sub
'flush input buffer
Sub Flushbuf()
Waitms 100 'give some time to get data if it is there
 B
= Inkey() ' flush buffer
Loop Until B = 0
End Sub
