Tuesday, 15 July 2025
Check the Shop
  Random
Random
SE-CMPS
SE-CMPS
EUR 83.49
Mega88P
Mega88P
EUR 4.16
AVR-DOS Print
AVR-DOS is a FAT16 File system for BASCOM-AVR
AVR-DOS is a FAT16 File system for BASCOM-AVR written by Vögel Franz Josef. MCS Electronics is the authorised reseller for this add-on library.
The library is completely written in AVR-assembler.
The AVR-DOS File system is completely integrated into the compiler
The syntax is completely the same as from QB/VB.
A small example:
Print #1 , "Init File System ... ";
Dim Gbtemp1 As Byte ' scratch byte
Gbtemp1
= Initfilesystem(1) ' we must init the filesystem once
If Gbtemp1 > 0 Then
Print #1 , "Error " ; Gbtemp1
Else
Print #1 , " OK"
Print "Disksize : " ; Disksize() ' show disk size in bytes
Print "Disk free: " ; Diskfree() ' show free space too
End If
'dim some test variables
Dim S As String * 60 , Fl As String * 12 , Ff As Byte
Dim Sdatetime As String * 18
Fl
= "test.txt"
S
= "test this"
'Now we are getting to it
'We can specify a file handle with #1 or #2 etc. or we can ask for a free
' file handle with the FreeFile function. It will return a free handle if there is one.
Ff
= Freefile() ' get a file handle
'With this file handle we refer to a file
Open Fl For Output As #ff ' open fikle for output
' we need to open a file before we can use the file commands
' we open it for OUTPUT, INPUT , APPEND or BINARY
' In this case we open it for OUTPUT because we want to write to the file.
' If the file existed, the file would be overwritten.
Print #ff , S ' print some data
Print #ff , S
Print #ff , S
Print #ff , "A constant" ; S
Testsb Ff
Close #ff
It is simple to create data loggers, MP3 players etc.
MCS developed a MIDI player using MMC/SD cards.
The LBX comes for free with BASCOM-AVR. When you want the ASM source, you can order the  USER library for AVR-DOS. The price is 19.95 euro.
When you want to develop a commercial product with the library(either LBX or LIB), you need to purchase a Commercial license for 99 euro.
