Saturday, 13 September 2025
AN #186 - KokkeKat FAT-free SD card library Print
This application note presents a new SD card library. It is written entirely in BASCOM AVR basic
with the intention to minimize RAM usage.
by Niclas Arndt
1 What makes it special?
• Written in commented basic so you can easily understand it and make any addition or modification you see fit.
• Low dedicated RAM requirement – read, write, and append with fsinfo updating takes only 651 bytes of RAM plus 10 bytes of $hwstack . Read-only requires only 588 bytes of RAM plus 10 bytes of $hwstack.
• An integrated directory scrolling routine useful for forward and backward navigation applications, e.g. mp3 players.
• Support for long filenames when scrolling and reading files.
2 Main features
• Modular – you can easily define which parts of the library you want to use.
• SDSC, SDHC, and SDXC support. (For SDXC you need to format it with FAT32 in Mac OS or Linux.)
• FAT16 and FAT32 support in root directory and subdirectory (no support for ExFAT).
• This means that the maximum file size is 4 GB and the maximum partition size is 2 TB. It has been development tested on 32 MB SDSC, 1 GB SDSC, 4 GB SDHC, and 64 GB SDXC.
• Find file, subdirectory, parent directory, and volume ID.
• Read file with 8.3 or long filename.
• Create and write to new file with 8.3 filename.
• Create new subdirectory with 8.3 directory name.
• Append to a pre-existing file with 8.3 filename.
• Scroll forward or backward through a directory.
• Update FAT32 fsinfo sector when writing.
• Wipe out the contents while maintaining the original formatting.
3 Requirements
• You must use commercial v2.0.5.0 (or higher) of BASCOM AVR. This is because this library requires the new data type DWORD: unsigned 32-bit integer.
4 Table of Contents
2 Main features
3 Requirements
5 What you need to know before you start using the library
5.1 SD card versions and modes
5.2 SD card initialization and identification
5.3 SD card signaling speed.
5.4 Block (sector) size
5.5 Understanding FAT16 and FAT32
5.6 Byte in sector, sector in cluster, cluster, and absolute sector
5.7 Root directory
5.8 FAT, File Allocation Table
5.9 Fsinfo
5.10 Long filenames
6 Using the library
6.1 Configuration
6.2 Knowing your whereabouts
6.3 The root directory
6.4 Creating new files and directories and appending to files
6.4.1 Reading a file
6.4.2 Creating a new file
6.4.3 Creating a new subdirectory
6.4.4 Appending to a pre-existing file
6.5 Write safety vs. performance
6.6 Copying a file or reading and writing concurrently
6.7 Wiping the SD card
6.8 Examples
6.8.1 Initialization sequence
6.8.2 Code size and RAM usage for some of the examples
6.9 Sdstatus
7 General information about BASCOM AVR’s use of RAM
7.1 Hardware Stack
7.2 Software Stack
7.3 Frame
7.4 RAM organization
Complete article with source codes and support files can be found here:
Article with source code
SD lib demo (~50MB with video)
Circuit diagram in PDF
This lib have also forum for support and updates : Forum
SD lib Demo scroll :
$regfile = "m644def.dat"
$crystal = 8000000
$framesize = 40                                             ' This lib only uses ~10 $hwstack - please see the application note for more information
$hwstack = 40                                               ' This lib only uses ~10 $hwstack - please see the application note for more information
$swstack = 40                                               ' This lib only uses ~10 $hwstack - please see the application note for more information
$include "KokkeKat_FAT-free_SD_lib_decl.bas"
$include "3310decl.bas" ' <----- This is a display library I used when developing, so it's not required by the SD card lib
Dim Sdtempw2 As Word ' Only needed for the example
Dim Sddirentrynameb(12) As Byte ' Only needed for the example
Dim Sddirentrynames As String * 12 At Sddirentrynameb(1) Overlay
' Display initialization
Call D3310reset                                             ' <----- This is a display library I used when developing, so it's not required by the SD card lib
Call D3310init                                              ' <----- This is a display library I used when developing, so it's not required by the SD card lib
Call D3310clear                                             ' <----- This is a display library I used when developing, so it's not required by the SD card lib
' Here starts the mandatory SD card initialization and file system initialization:
Sdstatus = 0
Gosub Sdinit
If Sdstatus = 0 Then ' Initialization succesful. Sdcardtype = 1 -> v1.x SDSC, 2 -> v2+ SDSC, 3 -> v2+ SDHC or SDXC
 Gosub Sdinitfs
End If
 ' Here starts the Scroll demo:
 ' List root directory forward
   Sdstartdirclusterd = 0
   Sdclusterd = Sdstartdirclusterd
   Sddirlistarraycounter = 0
   Sddirlistdirection = 0
 Do ' Find next 8.3 entry
 Gosub Sddirlistloopstep
 Loop Until Sdstatus = 32 Or Sddirlistendpoint = 1        ' Loop until EOD marker found or end of directory reached
 ' List the same directory backward (from the end)
 Do ' Find preceding 8.3 entry
      Sddirlistdirection = 1
 Loop Until Sddirliststartpoint = 1                       ' Loop until start of directory reached
End If
Sddirlistloopstep:
   Sdstatus = 0
 Gosub Sddirlist
 If Sdstatus = 26 Or Sdstatus = 27 Then ' File or subdirectory found
      Sdlfns = Space(255) ' Clear the name string
 Gosub Sdlookforlfn                                    ' See if it has a long file name
 If Sdlfnfound = 1 Then ' It has a long filename
 Gosub Sdprintlfn
 End If
      Sddirlistdirection = 0                                ' Resume the position at the real 8.3 entry regardless
         Sdstatus = 0
 Gosub Sddirlist
 Loop Until Sdstatus = 26 Or Sdstatus = 27
 If Sdlfnfound = 0 Then ' No LFN found - display 8.3 name
 Gosub Sdprint83name
 End If
 Elseif Sdstatus = 34 Then ' Volume ID found
 Gosub Sdprint83name
 End If
Sdprintlfn:
 Call D3310position(, 0) ' <----- This is a display library I used when developing, so it's not required by the SD card lib
 For Sdtempw2 = 1 To 40
       Sdstr = Chr(sdlfnb(sdtempw2)) ' <----- This is a display library I used when developing, so it's not required by the SD card lib
 Call D3310print(sdstr) ' <----- This is a display library I used when developing, so it's not required by the SD card lib
 Next Sdtempw2
 Wait 1
Sdprint83name:
 Gosub Sdcondense83
 For Sdtempw2 = 1 To 12
       Sdstr = Chr(sddirentrynameb(sdtempw2)) ' <----- This is a display library I used when developing, so it's not required by the SD card lib
 Next Sdtempw2
 Wait 1
Sdcondense83:
   Sdtempb2 = 9                                             ' . position
   Sdtempb3 = 1                                             ' Continue marker
   Sddirentrynames = Space(12)
 For Sdtempb = 8 To 1 Step - 1
      Sddirentrynameb(sdtempb) = Sddirlistdirentry(sdtempb)
 If Sdtempb3 = 1 And Sddirentrynameb(sdtempb) = &H20 Then
 Decr Sdtempb2
 Else
         Sdtempb3 = 0
 End If
 Next Sdtempb
 If Sddirlistdirentry(9) <> &H20 Or Sddirlistdirentry(10) <> &H20 Or Sddirlistdirentry(11) <> &H20 Then
 If Sdstatus = 34 Then
         Sdtempb2 = 9
 Else
         Sddirentrynameb(sdtempb2) = &H2E
 Incr Sdtempb2
 End If
      Sddirentrynameb(sdtempb2) = Sddirlistdirentry(9)
 Incr Sdtempb2
      Sddirentrynameb(sdtempb2) = Sddirlistdirentry(10)
 Incr Sdtempb2
      Sddirentrynameb(sdtempb2) = Sddirlistdirentry(11)
 End If
$include "KokkeKat_FAT-free_SD_lib_code.bas"
$include "3310endshiftout.bas" ' <----- This is a display library I used when developing, so it's not required by the SD card lib
