kits
Posted: Fri Jan 28, 2011 1:26 pm Post subject: AVRISP-MKII Clone |
hi
i build this program
http://www.fourwalledcubicle.com/AVRISP.php
this program work fine in avr studio but i don't know how can i use in bascom avr ,in option of bascom avr in programmer tab ,what programmer must to be select?!
also i select avr isp mkii and cheek usb, but not work!
regards |
kimmi
Posted: Fri Jan 28, 2011 11:35 pm Post subject: |
If you like to use USB :
You must have the LIBSUSB drivers installed on your PC. Without it, it will not work
Did you install the LIBUSB ?
You can find it in bascom folder under \USB _________________ / Kim |
six1
Posted: Sat Jan 29, 2011 10:14 am Post subject: |
Hi Kits,
first of all: I use same programer. It's working great!
But you have to flash this programer with new Soft!
In Bascom search for FLIP
Install FLIP on your PC an follow Steps from Bascom help! after that it should work...
regards, Michael _________________ For technical reasons, the signature is on the back of this message. |
kits
Posted: Sat Jan 29, 2011 3:49 pm Post subject: |
hi six1
Quote: | But you have to flash this programer with new Soft! |
how ? and where can i find new soft ?! pls explain more
| i do that but not work
by the way in bascom avr i must select "flip" OR "usbpro program/avr isp mkii" for programmer ? |
six1
Posted: Sat Jan 29, 2011 4:25 pm Post subject: |
you have programmed it with FLIP?
In Bascom it is: USBprog Programmer / AVR ISP mkII
if you use SPI programming, select AVRISP protocol. _________________ For technical reasons, the signature is on the back of this message. |
kits
Posted: Sat Jan 29, 2011 4:49 pm Post subject: |
Quote: | you have programmed it with FLIP? |
i downloaded Flip 3.4.2 and installed it
but i don't know what do exactly!
for programmer at90usb162 i need a hex file! that's true?
i don't know how build the hex file from original file in this link but searched in internet and find a article i do that in next minute
http://www.fourwalledcubicle.com/LUFA.php
for last time my friend send hex file and program on at90usb162
kits
Posted: Sat Jan 29, 2011 4:58 pm Post subject: |
i select USBprog Programmer / AVR ISP mkII but show this message
Quote: |
avr isp mk2 detected
could not detect chip ,auto program failed
kits
Posted: Sun Jan 30, 2011 8:43 am Post subject: |
hello again
@six did you used exactly this programmer?
i update at90usb162 to last file LUFA 101122 for mkii
but bascom avr can't work with that
this is my screen shot , i think bascom not compatible by this programmer because error about data and stk500 and ....
when i want start program by this program in bascom avr after 1 second the bascom hang up and after 20 second close automatic windows of programmer |
six1
Posted: Sun Jan 30, 2011 9:30 am Post subject: |
Kits, trust me, it works!
following are instructions from Mark, to programm the Device:
Quote: |
- press reset button on programmer
- you get in Windows device manager an atmel dfu device
- in bascom, options programmer, select FLIP
- then open attached files and save on pc
- open the bas file
- press F4, it will send the hex file
- now device is programmer with avrdude (libusb) firmware.
kits
Posted: Sun Jan 30, 2011 10:03 am Post subject: |
hi six
thank you very much i will be try today , i appreciate your help
best regards |
kits
Posted: Sun Jan 30, 2011 7:04 pm Post subject: |
hi sex1 finally work
thanks especially six1
so, in next day i write a full article about this programmer and link here until other user can used easily
regards |
six1
Posted: Sun Jan 30, 2011 7:57 pm Post subject: |
