Posted: Mon Mar 24, 2008 4:57 am Post subject: Keyboad matrix 4*4.Little & fast code.Control butt supp
Keyboad matrix 4*4. Little & fast code. Control button support/
All question to airat_saifullin@pochta.ru
$regfile = "m128def.dat" : $crystal = 16000000 : $hwstack = 32 : $swstack = 10 : $framesize = 40 : $baud = 115200
Dim Port_tmp As Byte : Dim Bott_sh As Bit : Dim Bott_ctr As Bit : Dim Bott_tmp As Byte : Dim Bott_ent As Bit : Dim Bott_esc As Bit
Dim Bott_push As Bit : Dim Botton As Byte :
Dim Menu_col As Byte : Dim Menu_row As Byte : Dim Menu_mode_nav As Bit : Dim Menu_mode_sel As Bit : Dim Menu_data_tmp_bit As Bit :
Dim Menu_data_tmp_word As Word : Dim Menu_row_chan As Bit : Dim Menu_data_chan As Bit : Dim Menu_col_chan As Bit : Dim Menu_data_tmp_byte As Byte :
Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
Ddrc = 15
Portc = 15 : Port_tmp = Pinc : Bott_tmp = Port_tmp And 240 : If Bott_tmp = 0 Then : Reset Bott_push : Goto Bott_chek_end :
Else : Set Bott_push : Set : End If
Portc = 1 : Port_tmp = Pinc : Bott_tmp = Port_tmp And 16 : If Bott_tmp = 16 Then : Set Bott_sh : Else : Reset Bott_sh : End If : Bott_tmp = Port_tmp And 128
If Bott_tmp = 128 Then : Set Bott_ctr : Else : Reset Bott_ctr : End If : Bott_tmp = Port_tmp And 32 :
If Bott_tmp = 32 Then : Set Bott_ent : Else : Reset Bott_ent : End If :
Bott_tmp = Port_tmp And 64 : If Bott_tmp = 64 Then : Set Bott_esc : Else : Reset Bott_esc : End If
Portc = 2 : Port_tmp = Pinc : Bott_tmp = Port_tmp And 240 :
Select Case Bott_tmp
Case 16 : Botton = 1
Case 32 : Botton = 4
Case 64 : Botton = 7
Case 128 : Botton = 10
Case Else:
Portc = 4 : Port_tmp = Pinc : Bott_tmp = Port_tmp And 240 :
Case 16 : Botton = 2
Case 32 : Botton = 5
Case 64 : Botton = 8
Case 128 : Botton = 11
Case Else:
Portc = 8 : Port_tmp = Pinc : Bott_tmp = Port_tmp And 240 :
Case 16 : Botton = 3
Case 32 : Botton = 6
Case 64 : Botton = 9
Case 128 : Botton = 12
Case Else:
