How to use "Setipprotocol" function ?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive
odinfang68
PostPosted: Mon Jun 05, 2006 7:43 am    Post subject: How to use "Setipprotocol" function ? Reply with quote
I find the "setipprotocol" function in the sample program "Ping.Bas" ,but I can't find the explaination on Help file. Is there any body can tell me ? Thank you.
bfdegraaff
PostPosted: Tue Jun 06, 2006 9:13 am    Post subject: Reply with quote
Dear odinfang68,
It appears that the help description for setipprotocol has been forgotten,
I will send a message to mcs support. This will take me about a week
and then I will post the description here.
Regards, Barry
______
Barry de Graaff is a micro electronics student,
formerly on work emplacement at MCS Electronics.
www.barrydegraaff.tk/edb
PostPosted: Mon Jun 12, 2006 12:41 pm    Post subject: Reply with quote
hi,
yes, this was forgotten.
the setipprotocl sets the IPR register. This is needed when you use the socket in RAW mode such as in ICMP mode.
The W3100A PDF does not show too much info about it. I found out you must write '1' to this register in order to use ICMP mode that is needed for PING.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive All times are GMT + 1 Hour
