Can this code make a stack overflow?
P_Santos
PostPosted: Thu Apr 28, 2016 2:44 pm    Post subject: Can this code make a stack overflow? Reply with quote
Hello,
Need know if this code is a problem for stack overflow?
_start:
If _counter >= 14 Then
Incr Temp
If Var1 <> 0 Then
Incr Var2
If Var3 <> 200 Then Goto _start 'jump out of a, if structure!!
Best regards
Pedro
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.7.8 )
PostPosted: Thu Apr 28, 2016 7:06 pm    Post subject: Reply with quote
I did'nt test it but this code will give a overflow for the variables because it seems to be a loop without exit
you dont make any control of the increasing
ex : if you use byte the var temp will go to 255 then 0 and so on
JP
PostPosted: Thu Apr 28, 2016 7:15 pm    Post subject: Reply with quote
no that can not result in a stack overflow.
a problem is something like this:
main:
gosub abc
abc:
goto main
return
main:
gosub abc
abc:
goto main
return
toto
PostPosted: Fri Apr 29, 2016 12:03 am    Post subject: Reply with quote
Thank you both
Best regards
Toto
