Author
Message
psoft Joined: 15 Apr 2016 Posts: 3
Posted: Thu Apr 28, 2016 10:00 am Post subject: External interrupt Xmega
Hi i have problem with interrupt on pine.1 (xmega128a1u). The event must be low but there is no reaction .
configure example:
Config Pine.1 = Input
On Porte_int1 Touch_event
Enable Porte_int1 , Lo
Porte_pin1ctrl = &B00_011_010
Porte_int0mask = &B0000_0010
do
loop
touch_event:
return
Where is problem?
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.7.8 )
MWS Joined: 22 Aug 2009 Posts: 2262
Posted: Thu Apr 28, 2016 12:21 pm Post subject:
Where do you enable interrupts globally for Lo?
Mind to read the help?
Posted: Thu Apr 28, 2016 1:58 pm Post subject:
MWS wrote: Where do you enable interrupts globally for Lo?
Yes , this is completly code:
$regfile = "xm128a1def.dat"
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
$hwstack = 1024
$swstack = 1024
$framesize = 1024
$crystal = 48000000
Osc_pllctrl = &B11_0_01100
Config Osc = Disabled , Pllosc = Enabled , Extosc = Enabled , 32khzosc = Disabled , 32mhzosc = Disabled , _
Range = 9mhz_12mhz , 32khzpowermode = Low_power , Startup = Xtal_256clk
do
loop
touch_event:
return
OK i see problem, mask is on int0 I use int1, thank yuo.
