Posted: Tue Feb 16, 2016 5:43 am Post subject: Looking for an updated m32U4def.dat
I wanted to build something using the Mega32U4. However, even sample code fails to compile when using the m32U4def.dat file. For instance, loading the clock sample gives compiler errors about AS2 Bit Definition Not Found. I added the line AS2 = 1 into the dat file, but still get the same error. Using the m32def.dat file works.
So, does anyone have an updated/tweaked dat file for the M32U4?
Posted: Tue Feb 16, 2016 9:19 am Post subject: Re: Looking for an updated m32U4def.dat
That's ok.
It's a world of wonders.
One of them is, there's not AS2 bit within ATM32U4, the same as there's no asynchronous RTC clocked by an external 32kHz crystal, which would be needed by the clock sample.
No wonder here.
Sure, if you also use an ATMega32 then, the code will even run on the hardware and won't crash immediately.
