The big difference between AVR simulator and Real hardware
dabatek
PostPosted: Sun Feb 14, 2016 9:08 pm    Post subject: The big difference between AVR simulator and Real hardware Reply with quote
Please help,
I work on some time critical project and I found that time (cycl.) need for
GETADC is not like in AVR simulator. With DSO I measured 80 times bigger value !
This is simple code for measure purpose:
$Regfile="m328pdef.dat"
$Crystal=16000000
$hwstack=32
$swstack=8
$framesize=50
Config PortD.2 = Output
Config Adc = Single , Prescaler = Auto , Reference = Avcc
Start Adc
Dim W As Word
portd.2=1
portd.2=0
W = Getadc(0) ' in AVR Simulator need 0.00125ms, BUT IN REAL HARDWARE WITH DSO I measured ~ 0.2ms !!!
portd.2=1
waitms 2
Where is the problem ?
Best regards
Z.D
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.7.8 )
PostPosted: Sun Feb 14, 2016 11:04 pm    Post subject: Reply with quote
Simulation time is likely pure execution time of ASM code and does not reflect actual conversion time.
If it's time critical, then the auto setting of config adc and the command GetADC is probably not the right thing anyway.
Reading the data sheet and manually setting the prescaler is self-evident.
The "auto" setting chooses the greatest ADC-prescaler and such the slowest conversion rate, also the GetADC always takes a dummy sample, thus needs two times a sampling cycle.
And btw., your problem whatsoever is in no way more important than others. Coloring the code in red instead of using proper code tags doesn't show most clever behavior.
dabatek
PostPosted: Mon Feb 15, 2016 12:19 am    Post subject: Reply with quote
Thank you MWS for clear and quick answer,
also is clear for coloring code...
