hobby
Posted: Mon Jul 13, 2015 7:05 pm Post subject: OLED with SH1106 in i2c |
I try to modify the new lib glcdSSD1306-I2C.lib for working with the driver SH1106.
'Normaly' is very similar.
I have change only the init_lcd_data:
.db &H78, &HAE ; -,- DISPLAYOFF
.db &HD5, &H80 ; -,- SETDISPLAYCLOCKDIV , ratio 0x80
.db &HA8, &H3F ; *,- SETMULTIPLEX , 1f 128x32
.db &HD3, &H00 ; -,- SETDISPLAYOFFSET , 00
.db &H40, &H32 ; -,* SETSTARTLINE , CHARGEPUMP
.db &H14, &HA1 ; -,- vccstate 14, SEGREMAP
.db &HC8, &HDA ; -,- COMSCANDEC , SETCOMPINS
.db &H12, &H81 ; -,- 02 128x32 12 , SETCONTRAST
.db &HFF, &HD9 ; -,- constrast value 255, SETPRECHARGE,
.db &HF1, &HDB ; -,* vccstate f1 , SETVCOMDETECT
.db &H40, &HA4 ; -,- &H40 , DISPLAYALLON_RESUME
.db &HA6, &HAF ; -,- NORMALDISPLAY, Display ON
The change is mark by *
SETMULTIPLEX
CHARGEPUMP
SETVCOMDETECT
and delete MEMORYMODE and A0 upside down , not exist in sh1106.
i have change the value ldi r21,24 ; 26 bytes to 24 bytes.
But not works.
Any idea for what ?
Best regards
Olivier
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.7.8 ) |
Posted: Mon Jul 13, 2015 9:38 pm Post subject: |
you might want to try this :
_lcd_init_data:
.db &H78, &HAE ; DISPLAYOFF
.db &H20, &H10 ; MEMORY MODE, SETHIGHCOL
.db &HB0, &HC8 ; high col values
.db &H00, &H10 ; low col values
.db &H40, &H81 ; set contrast
.db &H7F, &HA1 ; contrast value, segmentremap
.db &HA6, &HA8 ; normal display, setmultiplex
.db &H3F, &HA4 ; mul value, displayallon resume
.db &HD3, &H00 ; SETDISPLAYOFFSET , 00
.db &HD5, &HF0 ; SETDISPLAYCLOCKDIV , ratio 0x80
.db &HD9, &H22 ; precharge, value
.db &HDA, &H12 ; setcompins
.db &HDB, &H20 ; setvcomdetect
.db &H8D, &H14 ; chargepump
.db &HA6, &HAF ; NORMALDISPLAY
and change to 30 _________________ Mark |
hobby
Posted: Tue Jul 14, 2015 8:27 am Post subject: |
Thanks Mark,
I have tested the screen remains black.
Olivier |
Posted: Tue Jul 14, 2015 3:52 pm Post subject: |
just check the i2c address of the lcd. maybe it is different?
use the i2cscanner sample app to test it _________________ Mark |
hobby
Posted: Tue Jul 14, 2015 4:13 pm Post subject: |
It's the same 78h.
Thanks
Olivier |
Posted: Wed Jul 15, 2015 12:33 pm Post subject: |
i do not have this controller. i advise to ask the manufacturer. it is a nice chip since this I2C supports the READ as well which would allow to use all graphic commands. _________________ Mark |
mpromark
Joined: 29 Jul 2004 Posts: 13 Location: Wroclaw , Poland
Posted: Wed Nov 30, 2016 3:04 am Post subject: |
I have the same problem with SH1106 and I2C interface.
I have tried many settings and no succes...
The screen remains black
Best regards
Mark |
Hkipnik
Posted: Sun Dec 04, 2016 4:13 pm Post subject: |
Hello
SSD1306 lib has changed something
The SH1106 chip is little different.
Hkipnik |
mpromark
Posted: Mon Dec 05, 2016 2:19 am Post subject: |
thanks a lot...
I will check it of course .!
My OLED displays (smaller and bigger) with SSD1306 work
in Bascom perfect.!
..but the new one 1.3" OLED with SH1106 does not want to work.
mark |
mpromark
Posted: Mon Dec 05, 2016 4:37 am Post subject: |
I see that it starts to work..!!
Thanks once again.!
mark |
